SFUNC question - Page 12 — Parallax Forums
SFUNC question
17891012
  • cgraceycgracey Posts: 14,312
    Or, this:
    	TESTB	D,{#}S	{WC/ANDC/ORC/XORC,WZ/ANDZ/ORZ/XORZ}
    	TESTBN	D,{#}S	{WC/ANDC/ORC/XORC,WZ/ANDZ/ORZ/XORZ}
    	CLRB	D,{#}S
    	SETB	D,{#}S
    	SETBC	D,{#}S
    	SETBNC	D,{#}S
    	SETBZ	D,{#}S
    	SETBNZ	D,{#}S
    	NOTB	D,{#}S
    edited 2017-05-05 23:35
    jmg wrote: »
    And for easy code review, it's really nice to have a column where flag writes stand out. Burying them inside the mnemonic hides where they are actually happening.
    Seems a form that supports all of these is needed ?
    C = B,        C = !B
    C = C AND B   C = C AND !B
    C = C OR B    C = C OR !B
    C = C XOR B   C = C XOR !B
    Z = B,        Z = !B
    Z = Z AND B   Z = Z AND !B
    Z = Z OR B    Z = Z OR !B
    Z = Z XOR B   Z = Z XOR !B
    B = B AND C   B = B AND !C
    B = B OR C    B = B OR !C
    B = B XOR C   B = B XOR !C
    B = B AND Z   B = B AND !Z
    B = B OR Z    B = B OR !Z
    B = B XOR Z   B = B XOR !Z
    B = 0         B = 1
    B = C         B = !C
    B = Z         B = !Z
    B = !B
    I added seven more.
    And here are some other requirements:
    - keep flag alterations in the far right column without forcing redundancy of flag expressions
    - keep the operand only "D/{#}S'
  • jmgjmg Posts: 15,200
    edited 2017-05-05 23:31
    Maybe this is better. It's shorter, and doesn't confuse with RDxxxx/WRxxxx:
    That's quite good, because it can become as below, and the R/W prefixes make it clear which 'direction' things occur
    	RBIT	D,{#}S	{WC/ANDC/ORC/XORC,WZ/ANDZ/ORZ/XORZ}  F = F AND B  group
    	RBITN	D,{#}S	{WC/ANDC/ORC/XORC,WZ/ANDZ/ORZ/XORZ}  F = F AND !B group
    	WBITF	D,{#}S 	{ANDC/ORC/XORC, ANDZ/ORZ/XORZ}  B = B AND F    group
    	WBITNF	D,{#}S 	{ANDC/ORC/XORC ,ANDZ/ORZ/XORZ}  B = B AND !F   group
    	WBITL	D,{#}S B = 0
    	WBITH	D,{#}S B = 1
    	WBITC	D,{#}S B = C
    	WBITNC	D,{#}S B = !C
    	WBITZ	D,{#}S B = Z
    	WBITNZ	D,{#}S B = !Z
    	WBITN	D,{#}S B = !B
    Jmg, you'd be using flag suffixes in flag-read situations. Better to have them appear only when a flag write is occurring.
  • TonyBTonyB Posts: 73
    edited 2017-05-05 23:38
    There are some opcodes spare for XORing WBIT.
    (ANDing and ORing WBIT can be done with conditionals.)
    What will the mnemonics be for the INAND block?
    edited 2017-05-05 23:43
    These would do EVERYTHING:
    	CLRB	D,{#}S
    	SETB	D,{#}S
    	RNDB	D,{#}S
    	NOTB	D,{#}S
    	SETBC	D,{#}S
    	SETBNC	D,{#}S
    	SETBZ	D,{#}S
    	SETBNZ	D,{#}S
    	ANDBC	D,{#}S
    	ANDBNC	D,{#}S
    	ANDBZ	D,{#}S
    	ANDBNZ	D,{#}S
    	ORBC	D,{#}S
    	ORBNC	D,{#}S
    	ORBZ	D,{#}S
    	ORBNZ	D,{#}S
    	XORBC	D,{#}S
    	XORBNC	D,{#}S
    	XORBZ	D,{#}S
    	XORBNZ	D,{#}S
    To further clarify it is Flag Read, maybe follow your R.W convention like this
    	WBITRF	D,{#}S 	{ANDC/ORC/XORC,/ANDZ/ORZ/XORZ}  B = B AND F    group
    	WBITRNF	D,{#}S 	{ANDC/ORC/XORC,/ANDZ/ORZ/XORZ}  B = B AND !F   group
    	WBITL	D,{#}S B = 0
    	WBITH	D,{#}S B = 1
    	WBITC	D,{#}S B = C
    	WBITZ	D,{#}S B = Z
    	WBITN	D,{#}S B = !B
    WBITRF = Write Bit Read Flag
    WBITRNF = Write Bit Read !Flag
    ANDC means AND with Carry, so that is still valid and ok, the final destination is set by the R.W starting the opcodes.
  • cgracey wrote: »
    	CLRB	D,{#}S
    	SETB	D,{#}S
    	RNDB	D,{#}S
    	NOTB	D,{#}S
    	SETBC	D,{#}S
    	SETBNC	D,{#}S
    	SETBZ	D,{#}S
    	SETBNZ	D,{#}S
    	ANDBC	D,{#}S
    	ANDBNC	D,{#}S
    	ANDBZ	D,{#}S
    	ANDBNZ	D,{#}S
    	ORBC	D,{#}S
    	ORBNC	D,{#}S
    	ORBZ	D,{#}S
    	ORBNZ	D,{#}S
    	XORBC	D,{#}S
    	XORBNC	D,{#}S
    	XORBZ	D,{#}S
    	XORBNZ	D,{#}S
    How about MOV instead of SET?
    Are there enough opcodes available?
    What about compatibility with DIR/OUT/FLT/DRV mnemonics?
    edited 2017-05-06 01:30
    I like the sound of These would do EVERYTHING :)
    Looks good, very close, only the SETBC sounds too much like MAKE ONE, when it really means move... maybe this ?
    	CLRB	D,{#}S
    	SETB	D,{#}S
    	RNDB	D,{#}S
    	NOTB	D,{#}S
    	MOVBC	D,{#}S
    	MOVBNC	D,{#}S
    	MOVBZ	D,{#}S
    	MOVBNZ	D,{#}S
    	ANDBC	D,{#}S
    	ANDBNC	D,{#}S
    	ANDBZ	D,{#}S
    	ANDBNZ	D,{#}S
    	ORBC	D,{#}S
    	ORBNC	D,{#}S
    	ORBZ	D,{#}S
    	ORBNZ	D,{#}S
    	XORBC	D,{#}S
    	XORBNC	D,{#}S
    	XORBZ	D,{#}S
    	XORBNZ	D,{#}S
    TonyB,
    The trouble with MOV (or MOVB) is that you start needing a 3rd operand. And that 3rd operand is going to need to be C or Z (which I'd rather not tie up, as names) or CF or ZF, or 0 or 1, etc., along with ways to show !C and !Z. The syntax gets ugly really fast. But, if you had MOVB, you could also have ANDB/ORB/XORB with a standard operand format.
    TonyB wrote: »
    Snap.
    edited 2017-05-06 10:45
    Sorry I meant the SET in SETBC/SETBNC/etc., as shown by jmg. It's best to get these bit mnemonics right and not worry about compatibility with DIR/OUT/FLT/DRV.
    I know I keep asking but can all of the ANDB, ORB, XORB fit in?
    They can all fit.
    edited 2017-05-06 01:40
    	CLRB	D,{#}S
    	SETB	D,{#}S
    	RNDB	D,{#}S
    	NOTB	D,{#}S
    	SETBC	D,{#}S
    	SETBNC	D,{#}S
    	SETBZ	D,{#}S
    	SETBNZ	D,{#}S
    	ANDBC	D,{#}S
    	ANDBNC	D,{#}S
    	ANDBZ	D,{#}S
    	ANDBNZ	D,{#}S
    	ORBC	D,{#}S
    	ORBNC	D,{#}S
    	ORBZ	D,{#}S
    	ORBNZ	D,{#}S
    	XORBC	D,{#}S
    	XORBNC	D,{#}S
    	XORBZ	D,{#}S
    	XORBNZ	D,{#}S
    To summarize/simplify they become...
            TEST{B/BN}                     D,{#}S  {WC/ANDC/ORC/XORC,WZ/ANDZ/ORZ/XORZ}
            {CLR/SET/RND/NOT}B             D,{#}S
            {SET/AND/OR/XOR}B{C/NC/Z/NZ}   D,{#}S
    Nice!
    Cluso99,
    I'm thinking now that BIT{L/H/C/NC/Z/NZ/RND/NOT} is actually quite sufficient, because we can do even more with conditionals to achieve things like ANDBC (IF_NC BITL). Plus, and importantly, we stay akin to the numerous {DIR/OUT/FLT/DRV}{L/H/C/NC/Z/NZ/RND/NOT} instructions, which are simple to look at and understand.
    Sorry for all this fidgeting, Everyone. It's almost through.
    Cluso99,
    I'm thinking now that BIT{L/H/C/NC/Z/NZ/RND/NOT} is actually quite sufficient, ....
    Not quite, shortfalls are :
    * Conditionals may manage AND,OR,XOR to Bit but they cannot manage MOV
    * Once you alias Logic via a Conditional, you lose free use of that field, for actual conditional operation.
    One detail that appeals, is the ability to use both C and Z as parallel boolean accumulators, allowing more complex expressions to evaluate in boolean logic.
    Jmg,
    Don't we have BIT{L/H/C/NC/Z/NZ/RND/NOT} for move? Isn't that everything?
    Jmg,
    Yes, if those are included. I've got a little lost at what is 'in' and what is 'out' across all the many permutations, & renamings, but I do remember that the Full Bit Instructions had no operational blind spots, so it becomes an exercise in mnemonic naming to cover that.
    To keep track, I like to include the boolean equation alongside the opcode when I post.
    edited 2017-05-06 04:01
    We have no blind spots now, with a few extras:
    * 'BIT{L/H/C/NC/Z/NZ/RND/NOT} WC,WZ' will write the original bit to C and NZ.
    * Conditionals allow complex operations: 'IF_C_NE_Z BITNOT D,{#}S WC,WZ' writes C^Z^bit into bit and returns the original bit value into C and NZ.
    * MODCZ allows simultaneous operations on both C and Z for all purposes except register-bit-related.
    With the "full" set I made, at first, you could do anything, as well, but you could only do ONE thing at a time. Period. This is richer, but there are three different ways things happen: TESTB{N}, BIT{x}, and MODCZ.
    Also, we stay harmonized with the pin operators: TESTP/TESTPN is like TESTB/TESTBN and DIRx/OUTx/FLTx/DRVx is like BITx. I think it all fits together about as well as it can, this way.
    edited 2017-05-06 04:47
    That would be very good.
    Which opcodes now cover these operations, and how do they present to the user ?
    B = B AND F group
    B = B AND !F group
    eg
    IF_Z_EQ_C B = B AND C
    IF_LE B = B AND !Z
    Keep in mind too much gymnastics makes code harder to read, and simply ends up not being used by Compilers..
    edited 2017-05-06 08:59
    I am actually happy with anything that converts to silicon.
    The P2 doesn't have to be an 8051. They are < $1.00 so P2 won't be competing with the 8051.
    Chipmas 2017 isn't looking likely anymore :(
    The P1B or P2HOT is looking better all the time.
    edited 2017-05-06 08:41
    jmg wrote: »
    B = B AND F group
    B = B AND !F group
    eg
    IF_LE B = B AND !Z
    Here are the basic combinatorial logic functions between flags and bits:
    IF_NC	BITL	D,{#}S		'B = B AND C
    IF_C	BITL	D,{#}S		'B = B AND !C
    IF_NZ	BITL	D,{#}S		'B = B AND Z
    IF_Z	BITL	D,{#}S		'B = B AND !Z
    IF_C	BITH	D,{#}S		'B = B OR C
    IF_NC	BITH	D,{#}S		'B = B OR !C
    IF_Z	BITH	D,{#}S		'B = B OR Z
    IF_NZ	BITH	D,{#}S		'B = B OR !Z
    IF_C	BITNOT	D,{#}S		'B = B XOR C
    IF_NC	BITNOT	D,{#}S		'B = B XOR !C
    IF_Z	BITNOT	D,{#}S		'B = B XOR Z
    IF_NZ	BITNOT	D,{#}S		'B = B XOR !Z
    	TESTB	D,{#}S	ANDC	'C = C AND B
    	TESTBN	D,{#}S	ANDC	'C = C AND !B
    	TESTB	D,{#}S	ANDZ	'Z = Z AND B
    	TESTBN	D,{#}S	ANDZ	'Z = Z AND !B
    	TESTB	D,{#}S	ORC	'C = C OR B
    	TESTBN	D,{#}S	ORC	'C = C OR !B
    	TESTB	D,{#}S	ORZ	'Z = Z OR B
    	TESTBN	D,{#}S	ORZ	'Z = Z OR !B
    	TESTB	D,{#}S	XORC	'C = C XOR B
    	TESTBN	D,{#}S	XORC	'C = C XOR !B
    	TESTB	D,{#}S	XORZ	'Z = Z XOR B
    	TESTBN	D,{#}S	XORZ	'Z = Z XOR !B
    Here are the assign-to-bits and assign-to-flags:
    	BITL	D,{#}S		'B = 0
    	BITH	D,{#}S		'B = 1
    	BITC	D,{#}S		'B = C
    	BITNC	D,{#}S		'B = !C
    	BITZ	D,{#}S		'B = Z
    	BITNZ	D,{#}S		'B = !Z
    	BITRND	D,{#}S		'B = RND
    	BITNOT	D,{#}S		'B = !B
    	TESTB	D,{#}S	WC	'C = B
    	TESTBN	D,{#}S	WC	'C = !B
    	TESTB	D,{#}S	WZ	'Z = B
    	TESTBN	D,{#}S	WZ	'Z = !B
    You can get more out of those using conditionals.
    I've got all this stuff redone using the flag suffixes and it works. I don't know how to do this any better.
    Here are the bit operations. Note that for the TESTB{N} (read) instructions, you must pick either a C or Z suffix to affect a flag, causing one of the CZ bits to be set in the opcode.
    For the BITx (write) instructions, you must use both WC and WZ, or neither. This allows the previous bit state to be optionally loaded into C and NZ.
    EEEE 0100000 CZI DDDDDDDDD SSSSSSSSS    *   TESTB   D,S/#         WC or   WZ
    EEEE 0100001 CZI DDDDDDDDD SSSSSSSSS    *   TESTBN  D,S/#         WC or   WZ
    EEEE 0100010 CZI DDDDDDDDD SSSSSSSSS    *   TESTB   D,S/#       ANDC or ANDZ
    EEEE 0100011 CZI DDDDDDDDD SSSSSSSSS    *   TESTBN  D,S/#       ANDC or ANDZ
    EEEE 0100100 CZI DDDDDDDDD SSSSSSSSS    *   TESTB   D,S/#        ORC or  ORZ
    EEEE 0100101 CZI DDDDDDDDD SSSSSSSSS    *   TESTBN  D,S/#        ORC or  ORZ
    EEEE 0100110 CZI DDDDDDDDD SSSSSSSSS    *   TESTB   D,S/#       XORC or XORZ
    EEEE 0100111 CZI DDDDDDDDD SSSSSSSSS    *   TESTBN  D,S/#       XORC or XORZ
    EEEE 0100000 CZI DDDDDDDDD SSSSSSSSS    *   BITL    D,S/#       WC,WZ or neither
    EEEE 0100001 CZI DDDDDDDDD SSSSSSSSS    *   BITH    D,S/#       WC,WZ or neither
    EEEE 0100010 CZI DDDDDDDDD SSSSSSSSS    *   BITC    D,S/#       WC,WZ or neither
    EEEE 0100011 CZI DDDDDDDDD SSSSSSSSS    *   BITNC   D,S/#       WC,WZ or neither
    EEEE 0100100 CZI DDDDDDDDD SSSSSSSSS    *   BITZ    D,S/#       WC,WZ or neither
    EEEE 0100101 CZI DDDDDDDDD SSSSSSSSS    *   BITNZ   D,S/#       WC,WZ or neither
    EEEE 0100110 CZI DDDDDDDDD SSSSSSSSS    *   BITRND  D,S/#       WC,WZ or neither
    EEEE 0100111 CZI DDDDDDDDD SSSSSSSSS    *   BITNOT  D,S/#       WC,WZ or neither
    That should be pretty understandable.
    Here are the pin instructions. They work the same as those above and have identical syntax.
    TESTP{N} is like TESTB{N}, but just needs a pin number to read an INA/INB bit.
    DIRx is like BITx above, but just needs a pin number to write a DIRA/DIRB bit.
    OUTx is like BITx above, but just needs a pin number to write an OUTA/OUTB bit.
    FLTx is like BITx above, but just needs a pin number to write an OUTA/OUTB bit and clear a DIRA/DIRB bit.
    DRVx is like BITx above, but just needs a pin number to write an OUTA/OUTB bit and set a DIRA/DIRB bit.
    If "WC,WZ" is used with DIRx, the original DIRA/DIRB bit will be written to C and NZ. For OUTx/FLTx/DRVx, the original OUTA/OUTB bit will be written to C and NZ.
    EEEE 1101011 CZL DDDDDDDDD 001000000    *   TESTP   D/#           WC or   WZ
    EEEE 1101011 CZL DDDDDDDDD 001000001    *   TESTPN  D/#           WC or   WZ
    EEEE 1101011 CZL DDDDDDDDD 001000010    *   TESTP   D/#         ANDC or ANDZ
    EEEE 1101011 CZL DDDDDDDDD 001000011    *   TESTPN  D/#         ANDC or ANDZ
    EEEE 1101011 CZL DDDDDDDDD 001000100    *   TESTP   D/#          ORC or  ORZ
    EEEE 1101011 CZL DDDDDDDDD 001000101    *   TESTPN  D/#          ORC or  ORZ
    EEEE 1101011 CZL DDDDDDDDD 001000110    *   TESTP   D/#         XORC or XORZ
    EEEE 1101011 CZL DDDDDDDDD 001000111    *   TESTPN  D/#         XORC or XORZ
    EEEE 1101011 CZL DDDDDDDDD 001000000    *   DIRL    D/#         WC,WZ or neither
    EEEE 1101011 CZL DDDDDDDDD 001000001    *   DIRH    D/#         WC,WZ or neither
    EEEE 1101011 CZL DDDDDDDDD 001000010    *   DIRC    D/#         WC,WZ or neither
    EEEE 1101011 CZL DDDDDDDDD 001000011    *   DIRNC   D/#         WC,WZ or neither
    EEEE 1101011 CZL DDDDDDDDD 001000100    *   DIRZ    D/#         WC,WZ or neither
    EEEE 1101011 CZL DDDDDDDDD 001000101    *   DIRNZ   D/#         WC,WZ or neither
    EEEE 1101011 CZL DDDDDDDDD 001000110    *   DIRRND  D/#         WC,WZ or neither
    EEEE 1101011 CZL DDDDDDDDD 001000111    *   DIRNOT  D/#         WC,WZ or neither
    EEEE 1101011 CZL DDDDDDDDD 001001000    *   OUTL    D/#         WC,WZ or neither
    EEEE 1101011 CZL DDDDDDDDD 001001001    *   OUTH    D/#         WC,WZ or neither
    EEEE 1101011 CZL DDDDDDDDD 001001010    *   OUTC    D/#         WC,WZ or neither
    EEEE 1101011 CZL DDDDDDDDD 001001011    *   OUTNC   D/#         WC,WZ or neither
    EEEE 1101011 CZL DDDDDDDDD 001001100    *   OUTZ    D/#         WC,WZ or neither
    EEEE 1101011 CZL DDDDDDDDD 001001101    *   OUTNZ   D/#         WC,WZ or neither
    EEEE 1101011 CZL DDDDDDDDD 001001110    *   OUTRND  D/#         WC,WZ or neither
    EEEE 1101011 CZL DDDDDDDDD 001001111    *   OUTNOT  D/#         WC,WZ or neither
    EEEE 1101011 CZL DDDDDDDDD 001010000    *   FLTL    D/#         WC,WZ or neither
    EEEE 1101011 CZL DDDDDDDDD 001010001    *   FLTH    D/#         WC,WZ or neither
    EEEE 1101011 CZL DDDDDDDDD 001010010    *   FLTC    D/#         WC,WZ or neither
    EEEE 1101011 CZL DDDDDDDDD 001010011    *   FLTNC   D/#         WC,WZ or neither
    EEEE 1101011 CZL DDDDDDDDD 001010100    *   FLTZ    D/#         WC,WZ or neither
    EEEE 1101011 CZL DDDDDDDDD 001010101    *   FLTNZ   D/#         WC,WZ or neither
    EEEE 1101011 CZL DDDDDDDDD 001010110    *   FLTRND  D/#         WC,WZ or neither
    EEEE 1101011 CZL DDDDDDDDD 001010111    *   FLTNOT  D/#         WC,WZ or neither
    EEEE 1101011 CZL DDDDDDDDD 001011000    *   DRVL    D/#         WC,WZ or neither
    EEEE 1101011 CZL DDDDDDDDD 001011001    *   DRVH    D/#         WC,WZ or neither
    EEEE 1101011 CZL DDDDDDDDD 001011010    *   DRVC    D/#         WC,WZ or neither
    EEEE 1101011 CZL DDDDDDDDD 001011011    *   DRVNC   D/#         WC,WZ or neither
    EEEE 1101011 CZL DDDDDDDDD 001011100    *   DRVZ    D/#         WC,WZ or neither
    EEEE 1101011 CZL DDDDDDDDD 001011101    *   DRVNZ   D/#         WC,WZ or neither
    EEEE 1101011 CZL DDDDDDDDD 001011110    *   DRVRND  D/#         WC,WZ or neither
    EEEE 1101011 CZL DDDDDDDDD 001011111    *   DRVNOT  D/#         WC,WZ or neither
    I think this covers things really well and gets us a lot more flag logic than we had before. Thanks to all you guys for fretting over this and thinking about how this could work best. I know jmg would like more discrete operations, but this is quite sufficient, I think.
    edited 2017-05-06 09:22
    Cluso99 wrote: »
    I'm compiling v19 now, for what it's worth.
    edited 2017-05-06 09:53
    DOCS: Maybe that must use both WC and WZ can be simplified to a WPV or WLV or similar (Write Previous Value, Write Last Value etc), or even a WPCNZ if you want to be accurate ?
    "WC,WZ or neither" is going to be hard to document, made more confusing by the fact WZ is not actually what happens, but WNZ.
    Is that NOT Z effect still needed ? Was it there to allow a means to extract NOTBIT for later testing ? What code uses WPCNZ ?
    Will encodings for
    B = B OR !C
    B = B XOR !Z
    etc be given clearer, alias opcodes ?
    edited 2017-05-06 09:56
    DOCS: These encodings give no indications of the 'reach' of these opcodes, but seem to imply they can do more than they actually can.
    TESTP I think is limited to 32bool or a 5b active index, and TESTP is limited to a 64bool or 6b active index.
    Would the DOCS be better written like this, to show that ?
    EEEE 0100000 CZI DDDDDDDDD ~~~~sssss    *   TESTB   D,S/#         WC or   WZ
    EEEE 1101011 CZL ~~~dddddd 001000000    *   TESTP   D/#           WC or   WZ
    Where
    ~~~~sssss means 5 bit immediate, or lower 5 bits of S Reg
    ~~~dddddd means 6 bit immediate, or lower 6 bits of D Reg
    (which opcode bit selects D/# in TESTP ?)
  • cgracey wrote: »
    It's worth plenty Chip! :)
    Looking forward to taking V19 for a SPIN
  • cgracey wrote: »
    Cluso99 wrote: »
    Thank you Chip! Here's hoping that v19 is the final version prior to going to silicon.
    edited 2017-05-06 22:19
    jmg wrote: »
    Good point. I prefer WPCZ.
    jmg wrote: »
    Where
    I've tried "~" and "." and "X" for don't care bits, but best one to me is "-".
    I think TESTB would be best documented as
    TESTB D,S/# WC|WZ|ANDC|ANDZ|ORC|ORZ|XORC|XORZ
    to show that a suffix is required.
    Putting these various ideas together:
    EEEE 0100000 CZI DDDDDDDDD ----SSSSS	TESTB   D,S/#	  WC|WZ
    EEEE 0100001 CZI DDDDDDDDD ----SSSSS    TESTBN  D,S/#	  WC|WZ
    EEEE 0100010 CZI DDDDDDDDD ----SSSSS    TESTB   D,S/#	ANDC|ANDZ
    EEEE 0100011 CZI DDDDDDDDD ----SSSSS    TESTBN  D,S/#	ANDC|ANDZ
    EEEE 0100100 CZI DDDDDDDDD ----SSSSS    TESTB   D,S/#	 ORC|ORZ
    EEEE 0100101 CZI DDDDDDDDD ----SSSSS    TESTBN  D,S/#	 ORC|ORZ
    EEEE 0100110 CZI DDDDDDDDD ----SSSSS    TESTB   D,S/#	XORC|XORZ
    EEEE 0100111 CZI DDDDDDDDD ----SSSSS    TESTBN  D,S/#	XORC|XORZ
    EEEE 0100000 CZI DDDDDDDDD ----SSSSS    BITL    D,S/#	{WPCZ}
    EEEE 0100001 CZI DDDDDDDDD ----SSSSS    BITH    D,S/#	{WPCZ}
    EEEE 0100010 CZI DDDDDDDDD ----SSSSS    BITC    D,S/#	{WPCZ}
    EEEE 0100011 CZI DDDDDDDDD ----SSSSS    BITNC   D,S/#	{WPCZ}
    EEEE 0100100 CZI DDDDDDDDD ----SSSSS    BITZ    D,S/#	{WPCZ}
    EEEE 0100101 CZI DDDDDDDDD ----SSSSS    BITNZ   D,S/#	{WPCZ}
    EEEE 0100110 CZI DDDDDDDDD ----SSSSS    BITRND  D,S/#	{WPCZ}
    EEEE 0100111 CZI DDDDDDDDD ----SSSSS    BITNOT  D,S/#	{WPCZ}
    EEEE 1101011 CZL ---DDDDDD 001000000    TESTP   D/#	  WC|WZ
    EEEE 1101011 CZL ---DDDDDD 001000001    TESTPN  D/#	  WC|WZ
    EEEE 1101011 CZL ---DDDDDD 001000010    TESTP   D/#	ANDC|ANDZ
    EEEE 1101011 CZL ---DDDDDD 001000011    TESTPN  D/#	ANDC|ANDZ
    EEEE 1101011 CZL ---DDDDDD 001000100    TESTP   D/#	 ORC|ORZ
    EEEE 1101011 CZL ---DDDDDD 001000101    TESTPN  D/#	 ORC|ORZ
    EEEE 1101011 CZL ---DDDDDD 001000110    TESTP   D/#	XORC|XORZ
    EEEE 1101011 CZL ---DDDDDD 001000111    TESTPN  D/#	XORC|XORZ
    EEEE 1101011 CZL ---DDDDDD 001000000    DIRL    D/#	{WPCZ}
    EEEE 1101011 CZL ---DDDDDD 001000001    DIRH    D/#	{WPCZ}
    EEEE 1101011 CZL ---DDDDDD 001000010    DIRC    D/#	{WPCZ}
    EEEE 1101011 CZL ---DDDDDD 001000011    DIRNC   D/#	{WPCZ}
    EEEE 1101011 CZL ---DDDDDD 001000100    DIRZ    D/#	{WPCZ}
    EEEE 1101011 CZL ---DDDDDD 001000101    DIRNZ   D/#	{WPCZ}
    EEEE 1101011 CZL ---DDDDDD 001000110    DIRRND  D/#	{WPCZ}
    EEEE 1101011 CZL ---DDDDDD 001000111    DIRNOT  D/#	{WPCZ}
    EEEE 1101011 CZL ---DDDDDD 001001000    OUTL    D/#	{WPCZ}
    EEEE 1101011 CZL ---DDDDDD 001001001    OUTH    D/#	{WPCZ}
    EEEE 1101011 CZL ---DDDDDD 001001010    OUTC    D/#	{WPCZ}
    EEEE 1101011 CZL ---DDDDDD 001001011    OUTNC   D/#	{WPCZ}
    EEEE 1101011 CZL ---DDDDDD 001001100    OUTZ    D/#	{WPCZ}
    EEEE 1101011 CZL ---DDDDDD 001001101    OUTNZ   D/#	{WPCZ}
    EEEE 1101011 CZL ---DDDDDD 001001110    OUTRND  D/#	{WPCZ}
    EEEE 1101011 CZL ---DDDDDD 001001111    OUTNOT  D/#	{WPCZ}
    EEEE 1101011 CZL ---DDDDDD 001010000    FLTL    D/#	{WPCZ}
    EEEE 1101011 CZL ---DDDDDD 001010001    FLTH    D/#	{WPCZ}
    EEEE 1101011 CZL ---DDDDDD 001010010    FLTC    D/#	{WPCZ}
    EEEE 1101011 CZL ---DDDDDD 001010011    FLTNC   D/#	{WPCZ}
    EEEE 1101011 CZL ---DDDDDD 001010100    FLTZ    D/#	{WPCZ}
    EEEE 1101011 CZL ---DDDDDD 001010101    FLTNZ   D/#	{WPCZ}
    EEEE 1101011 CZL ---DDDDDD 001010110    FLTRND  D/#	{WPCZ}
    EEEE 1101011 CZL ---DDDDDD 001010111    FLTNOT  D/#	{WPCZ}
    EEEE 1101011 CZL ---DDDDDD 001011000    DRVL    D/#	{WPCZ}
    EEEE 1101011 CZL ---DDDDDD 001011001    DRVH    D/#	{WPCZ}
    EEEE 1101011 CZL ---DDDDDD 001011010    DRVC    D/#	{WPCZ}
    EEEE 1101011 CZL ---DDDDDD 001011011    DRVNC   D/#	{WPCZ}
    EEEE 1101011 CZL ---DDDDDD 001011100    DRVZ    D/#	{WPCZ}
    EEEE 1101011 CZL ---DDDDDD 001011101    DRVNZ   D/#	{WPCZ}
    EEEE 1101011 CZL ---DDDDDD 001011110    DRVRND  D/#	{WPCZ}
    EEEE 1101011 CZL ---DDDDDD 001011111    DRVNOT  D/#	{WPCZ}
  • Is the P2 becoming one of the most advanced processors out there ?
