SFUNC question - Page 11 — Parallax Forums
SFUNC question
17891113
  • TonyBTonyB Posts: 73
    edited 2017-05-05 16:41
    Seairth wrote: »
    Are BITAND, etc. updating D or the flag(s)? If it's the flags, maybe use "CZ" prefix instead of "BIT"?
    It must be a flag, otherwise you'd have instructions such as C & Z := D(S) AND C AND Z. This means there are 8 opcodes unused in each of the BITAND and INAND blocks (bits CZ=11) and there is room in the former for 8 new D,S instructions that don't write C or Z. Just saying...
    These latest (and final?) bit instructions seem to be excellent functionally. Adding F to the mnemonic to indicate a flag destination would help avoid confusion but that would break the 7-letter rule.
    Have WC and WZ been dropped from OUT/FLT/DRV?
    Have all the opcodes for the new MODCZ instruction been posted yet?
    edited 2017-05-05 22:02
    Great ideas, Guys!
    I've got this Hackchat thing in an hour, but after that, we'll get this syntax perfected. We are very close now. And it's looking good.
  • jmgjmg Posts: 15,193
    Seairth wrote: »
    Is the assembler going to enforce the requirement/restriction of WC/WZ based on mnemonic?
    Yes, it will need to do that.
    Seairth wrote: »
    The groups with {WC,WZ required} had a mandatory suffix and update C or Z.
    Unclear still if
    BITAND BitVar WC,WZ is valid, or remapped to another operation ?
    Seairth wrote: »
    I see BITEST/BITESTN instead of BITGET/BITGETN. Is that correct?
    I think so, but these tables need operation equations to know if the details change.
    ie present opcode table says TESTB does C/!Z = bit S[4:0] of D.
    but the !Z is now possible in BITTESTN ?
    edited 2017-05-05 20:43
    Okay. I've got everything working.
    Here is the new BITx instruction block:
    EEEE 0100000 CZI DDDDDDDDD SSSSSSSSS    *   BITAND  D,S/#       {WC,WZ required}
    EEEE 0100001 CZI DDDDDDDDD SSSSSSSSS    *   BITANDN D,S/#       {WC,WZ required}
    EEEE 0100010 CZI DDDDDDDDD SSSSSSSSS    *   BITOR   D,S/#       {WC,WZ required}
    EEEE 0100011 CZI DDDDDDDDD SSSSSSSSS    *   BITORN  D,S/#       {WC,WZ required}
    EEEE 0100100 CZI DDDDDDDDD SSSSSSSSS    *   BITXOR  D,S/#       {WC,WZ required}
    EEEE 0100101 CZI DDDDDDDDD SSSSSSSSS    *   BITXORN D,S/#       {WC,WZ required}
    EEEE 0100110 CZI DDDDDDDDD SSSSSSSSS    *   BITEST  D,S/#       {WC,WZ required}
    EEEE 0100111 CZI DDDDDDDDD SSSSSSSSS    *   BITESTN D,S/#       {WC,WZ required}
    BITAND and BITOR could be assembler aliases and don't need their own opcodes. This would free up space for bit XORs that write to D.
    Assuming C/!Z = bit S[4:0] of D in BITEST:
    	BITAND	D,S	WC  =	IF_C	BITEST	D,S	WC
    	BITANDN	D,S	WC  =	IF_C	BITESTN	D,S	WC
    	BITOR	D,S	WC  =	IF_NC	BITEST	D,S	WC
    	BITORN	D,S     WC  =	IF_NC	BITESTN	D,S	WC
    	BITAND	D,S	WZ  =	IF_Z	BITESTN	D,S	WZ
    	BITANDN	D,S	WZ  =	IF_Z	BITEST	D,S	WZ
    	BITOR	D,S	WZ  =	IF_NZ	BITESTN	D,S	WZ
    	BITORN	D,S     WZ  =	IF_NZ	BITEST	D,S	WZ
    Same applies to INAND and INOR.
    edited 2017-05-05 20:59
    dMajo wrote: »
    HeaterPin := (MinTemp < Temp < MaxTemp) AND HeaterON AND NOT ThermalTrip OR TestPin
    could be realized as:
    		CMP	Temp,MaxTemp		WC
    		CMP	MinTemp,Temp		AC
    		BIT	Flags,#HeaterOn		AC
    		BITN	Flags,#ThermalTrip	AC
    		BIT	Flags,#TestPin		OC
    		DRVC	#HeaterPin
    where
    WC sets C from instruction
    AC ands prior C with instruction C
    OC ors C with instructin C
    XC xors C with instruction C
    conditionals works the same way of course
    Same binary encoding used.
    I quite like that, easy enough to scan, and edit
    (but it might cause culture shock to those who want to see only WC WZ in that column)
    in full table and equation form this is
    Suffix      BIT                BITN
    WC          C = B,             C = !B
    AC          C = C AND B        C = C AND !B
    OC          C = C OR B         C = C OR !B
    XC          C = C XOR B        C = C XOR !B
    WZ          Z = B,             Z = !B
    AZ          Z = Z AND B        Z = Z AND !B
    OZ          Z = Z OR B         Z = Z OR !B
    XZ          Z = Z XOR B        Z = Z XOR !B
    and once you have done that, it is a very small step to this ...
    Suffix      BIT                BITN
    WC          C = B,             C = !B
    WZ          Z = B,             Z = !B
    ACB         B = B AND C        B = B AND !C
    OCB         B = B OR C         B = B OR !C
    XCB         B = B XOR C        B = B XOR !C
    AZB         B = B AND Z        B = B AND !Z
    OZB         B = B OR Z         B = B OR !Z
    XZB         B = B XOR Z        B = B XOR !Z
    and voila, just like that, you have added the variants needed to support the proven Full Bit Instructions Verilog :):)
    edited 2017-05-05 21:15
    TonyB wrote: »
    At first glance that may appear true.... but that type of alias, conflicts with using any prefix on the new apparent opcode. (breaks more rules)
    Try the alias form of
    IF_Z_EQ_C 	BITAND	D,S	WC
    IF_Z_EQ_C	BITANDN	D,S	WC
    TonyB wrote: »
    Of course, we already have opcode space for Bit ops that write to D :)
  • dMajodMajo Posts: 857
    edited 2017-05-05 21:46
    jmg wrote: »
    Suffix      BIT                BITN
    WC          C = B,             C = !B
    WZ          Z = B,             Z = !B
    Suffix      BIT                BITN
    WC          C = B,             C = !B
    WZ          Z = B,             Z = !B
    Yes, then you can have some instructions to ser and reset C and Z .... or add a few suffix more:
    SC set C regardless of what the instruction do
    RC reset C regardless of what the instruction do
    SZ set Z regardless of what the instruction do
    RZ reset Z regardless of what the instruction do
    this can be used with
    NOP        RC  to only reset the C flag, or
    ANYOP D,S  RC  execute the instruction but in any case also reset the C flag
                   so the next line can or/and a new C or Z chain
    dMajo wrote: »
    I'm not sure there is opcode space for those ?
    Instructions to Set and Clear Z and C do exist already, but not as a suffix, because there is only 4 states in the CZ bits.
    The Full Bit Instructions Verilog I mentioned, has an explicit list of what is supported. Logical OPs to BitDest are in there.
    Seairth wrote: »
    A few questions:
    What is BITRND?
    Right, the assembler is going to have to handle this case for the C/Z suffixes.
    These new instructions update the flags, not the bits. Bits can be updated through conditionals plus bit-writes.
    BITEST/BITESTN are new names, like you said, but what dMajo proposed is even better, especially with the special flag suffixes!
    BITRND writes a random bit value.
    dMajo wrote: »
    I do not know how the opcodes have to be optimized and waht is behind the production of a good working set.
    But after all this discussions, and with some inspiration from other environments, I would love it to be possible to have all this in the effect field like (taken from prior post):
    		CMP	Temp,MaxTemp		WC
    		CMP	MinTemp,Temp		AC
    		DRVC	#HeaterPin
    where
    Excellent!
    I've been thinking we could just use ANDC/ORC/XORC to make it really clear. And WC for just reading the bit. I love BIT/BITN. This is the way forward. Even jmg is happy.
    edited 2017-05-05 22:06
    TonyB wrote: »
    DIRx/OUTx/FLTx/DRVx no longer allow WC/WZ. They used to return the INA/INB bit into C/NZ, but it wasn't really that useful. Now, INTEST overlaps those encodings, but with the C and/or Z bit set.
    Here are the MODCZ operands (it's just one opcode):
    EEEE 1101011 CZ1 0cccczzzz 001101111    *   MODCZ   c,z         {WC,WZ}
    Examples:
    MODCZ   _CLR, _Z_OR_C   WC,WZ   'C = 0, Z |= C
    MODCZ   _NZ,0           WC      'C = !Z
    MODCZ   0,_SET          WZ      'Z = 1
    MODCZ constants
    _CLR                    =       %0000
    _NC_AND_NZ              =       %0001
    _NZ_AND_NC              =       %0001
    _GT                     =       %0001
    _NC_AND_Z               =       %0010
    _Z_AND_NC               =       %0010
    _NC                     =       %0011
    _GE                     =       %0011
    _C_AND_NZ               =       %0100
    _NZ_AND_C               =       %0100
    _NZ                     =       %0101
    _NE                     =       %0101
    _C_NE_Z                 =       %0110
    _Z_NE_C                 =       %0110
    _NC_OR_NZ               =       %0111
    _NZ_OR_NC               =       %0111
    _C_AND_Z                =       %1000
    _Z_AND_C                =       %1000
    _C_EQ_Z                 =       %1001
    _Z_EQ_C                 =       %1001
    _Z                      =       %1010
    _E                      =       %1010
    _NC_OR_Z                =       %1011
    _Z_OR_NC                =       %1011
    _C                      =       %1100
    _LT                     =       %1100
    _C_OR_NZ                =       %1101
    _NZ_OR_C                =       %1101
    _C_OR_Z                 =       %1110
    _Z_OR_C                 =       %1110
    _LE                     =       %1110
    _SET                    =       %1111
    Examples:
    MODCZ constants
    _CLR                    =       %0000
    Is there a typo ? _CLR looks the same as 0, but the results columns differ ?
    edited 2017-05-05 22:31
    jmg wrote: »
    In the examples, I used "0" as ignored field data. Yes, _CLR = 0, but _SET = %1111, not 1.
  • So BIT/BITN + new suffixes could replace all of
    BITAND/BITANDN/BITOR/BITORN/BITXOR/BITXORN/BITEST/BITESTN?
    Could we use BIT/BITN mnemonics to write to D with new BITNOT replacing old BITN and BITF/BITFN to write to C or Z?
    edited 2017-05-05 22:26
    dMajo had a great idea about how to handle the syntax. Here is what I think it should look like:
    EEEE 0100000 CZI DDDDDDDDD SSSSSSSSS    *   BIT     D,S/#       {ANDC,ANDZ required}
    EEEE 0100001 CZI DDDDDDDDD SSSSSSSSS    *   BITN    D,S/#       {ANDC,ANDZ required}
    EEEE 0100010 CZI DDDDDDDDD SSSSSSSSS    *   BIT     D,S/#       {ORC,ORZ required}
    EEEE 0100011 CZI DDDDDDDDD SSSSSSSSS    *   BITN    D,S/#       {ORC,ORZ required}
    EEEE 0100100 CZI DDDDDDDDD SSSSSSSSS    *   BIT     D,S/#       {XORC,XORZ required}
    EEEE 0100101 CZI DDDDDDDDD SSSSSSSSS    *   BITN    D,S/#       {XORC,XORZ required}
    EEEE 0100110 CZI DDDDDDDDD SSSSSSSSS    *   BIT     D,S/#       {WC,WZ required}
    EEEE 0100111 CZI DDDDDDDDD SSSSSSSSS    *   BITN    D,S/#       {WC,WZ required}
    EEEE 1101011 CZL DDDDDDDDD 001000000    *   INP     D/#         {ANDC,ANDZ required}
    EEEE 1101011 CZL DDDDDDDDD 001000001    *   INPN    D/#         {ANDC,ANDZ required}
    EEEE 1101011 CZL DDDDDDDDD 001000010    *   INP     D/#         {ORC,ORZ required}
    EEEE 1101011 CZL DDDDDDDDD 001000011    *   INPN    D/#         {ORC,ORZ required}
    EEEE 1101011 CZL DDDDDDDDD 001000100    *   INP     D/#         {XORC,XORZ required}
    EEEE 1101011 CZL DDDDDDDDD 001000101    *   INPN    D/#         {XORC,XORZ required}
    EEEE 1101011 CZL DDDDDDDDD 001000110    *   INP     D/#         {WC,WZ required}
    EEEE 1101011 CZL DDDDDDDDD 001000111    *   INPN    D/#         {WC,WZ required}
    edited 2017-05-05 22:28
    Do you guys like ANDC/ORC/XORC -or- AC/OC/XC best?
    I think the short ones look pretty good, once you know what they are. Spelling it out makes it clearer, but not as tidy.
    edited 2017-05-05 22:27
    Which is best?
    		CMP	Temp,MaxTemp		WC
    		CMP	MinTemp,Temp		ANDC
    		BIT	Flags,#HeaterOn		ANDC
    		BITN	Flags,#ThermalTrip	ANDC
    		BIT	Flags,#TestPin		ORC
    		DRVC	#HeaterPin
    		CMP	Temp,MaxTemp		WC
    		CMP	MinTemp,Temp		AC
    		DRVC	#HeaterPin
    In the examples, I used "0" as ignored field data. Yes, _CLR = 0, bit _SET = %1111, not 1.
    Ah, ok - using that rule, there is enough user supplied info, to simplify down to this
    Examples:
    MODCZ   _CLR, _Z_OR_C     'C = 0, Z |= C
    MODCZ   _NZ,0             'C = !Z
    MODCZ   0,_SET            'Z = 1
    and I think these are illegal/not what user intended, so should be flagged (comment is not what code actually does )
    MODCZ   _NZ,0         WZ    'C = !Z
    MODCZ   0,_SET        WC    'Z = 1
    edited 2017-05-05 22:30
    Actually, we don't have a compare that lets you AND the C output. It would have to be coded like this:
    		CMP	Temp,MaxTemp		WC
    IF_C		CMP	MinTemp,Temp		WC
    		DRVC	#HeaterPin
  • cgracey wrote: »
    So what happens when users try to use ANDC/ORC/XORC on other instructions? Rhetorical question, they'll get an error. But then they'll want to know why they can't use them in general. It seems like a trap for newbies.
    It's also more weird syntax that assemblers are going to have to handle. I don't like it. I don't have to like it, of course, and I don't want to hold back shipping P2, so just implement something... but I don't know how/when gas and fastspin are going to support these.
    Eric
    edited 2017-05-05 23:06
    Which is best?
    		CMP	Temp,MaxTemp		WC
    		DRVC	#HeaterPin
    		CMP	Temp,MaxTemp		WC
    		CMP	MinTemp,Temp		AC
    		DRVC	#HeaterPin
    Both are ok, I'd lean to the explicit form - on some MCUs AC is Auxillary Carry, and the AND makes it very clear it is an AND operation.
    Of course, once you have that, the choices can expand to
    		BIT	Flags,#ThermalTrip	ANDNC  'TT=TT AND !C  (typo fixed)
    		BITN	Flags,#ThermalTrip	ANDC   'TT=TT AND !C
    the first one of those is closer to what actually happens.
    You do realize using this approach, can support all opcodes in your Full Bit Instructions Verilog ?
  • I like the longer ones. In fact, all of them that are only useful here could be longer to help differentiate where, when used.
    edited 2017-05-05 22:55
    jmg wrote: »
    Above could be write to reg and below could be write to flag.
    	BITF	Flags,#ThermalTrip	ANDC	'C=C AND TT
    	BITFN	Flags,#ThermalTrip	ANDC	'C=C AND !TT
    TonyB wrote: »
    Yes, certainly now all forms of Full Bit Instructions Verilog can be supported.
    I made a typo above, as I think the Bit as Logical-op destination is only in the original Full Bit Instructions Verilog opcode encoding.
  • No need for the new BITNOT I suggested before.
    	BITN	Flags,#ThermalTrip		'TT=!TT
    'BIT/BITN D,S/#' read a bit for the purpose of affecting C/Z. They don't write D.
    Maybe to make this clearer, we could use:
    	RDBIT	D,{#}S	{WC/ANDC/ORC/XORC,WZ/ANDZ/ORZ/XORZ}
    	RDBITN	D,{#}S	{WC/ANDC/ORC/XORC,WZ/ANDZ/ORZ/XORZ}
    	WRBITL	D,{#}S
    	WRBITH	D,{#}S
    	WRBITC	D,{#}S
    	WRBITNC	D,{#}S
    	WRBITZ	D,{#}S
    	WRBITNZ	D,{#}S
    	WRBITN	D,{#}S
    potatohead wrote: »
    And for easy code review, it's really nice to have a column where flag writes stand out. Burying them inside the mnemonic hides where they are actually happening.
  • cgracey wrote: »
    Yeah, home run!
    Seems a form that supports all of these is needed ?
    C = B,        C = !B
    Z = B,        Z = !B
    Maybe this is better. It's shorter, and doesn't confuse with RDxxxx/WRxxxx:
    	RBIT	D,{#}S	{WC/ANDC/ORC/XORC,WZ/ANDZ/ORZ/XORZ}
    	RBITN	D,{#}S	{WC/ANDC/ORC/XORC,WZ/ANDZ/ORZ/XORZ}
    	WBITL	D,{#}S
    	WBITH	D,{#}S
    	WBITC	D,{#}S
    	WBITNC	D,{#}S
    	WBITZ	D,{#}S
    	WBITNZ	D,{#}S
    	WBITN	D,{#}S
