WRLONG events not working? — Parallax Forums
Here's my test code. Based on a comment by @cgracey, I believe the WRLONG interrupt is #5. Also, based on another comment from @cgracey, the first event-triggering LONG is now located at $FFF80.
Assuming I've written everything correctly, GRN 0 (on 1-2-3 board) should light up. But it's not. All others light up as expected. Thoughts?
dat
        org 0
        coginit #16, #@test_wrl                 ' start cog with interrupt
        setb    dirb, #2                        ' lit when WRLONG occurs
        setb    dirb, #3                        ' lit with RDLONG verified
        waitx   ##$FFFFFF                       ' wait for other cog to init
        wrlong  ##$ABADCAFE, hwr0               ' write to first event-triggering long
        setb    outb, #2
        rdlong  temp, ##$FFF80                  ' read value back and make sure it's the same
        cmp     temp, ##$ABADCAFE wz
if_z    setb    outb, #3
.loop   jmp #.loop                              ' wait forever...
hwr0    long    $FFF80
temp    long    0
        org 0
test_wrl
        setb    dirb, #0                        ' lit when ISR is called
        setb    dirb, #1                        ' lit when cog is finished initializing
        setwrl  #%0000                          ' set WRL for first event-triggering long
        mov     ijmp1, #isr                     ' set up ISR
        setint1 #5                              ' enable interrupt
        setb    outb, #1
isr     setb    outb, #0                        ' called when WRLONG event is triggered
        reti1
  • Also, I have tried using WAITWRL instead of an ISR, but it made no difference.
  • rjo__rjo__ Posts: 2,114
    Same result here... wish I could help:)
  • rjo__ wrote: »
    Confirmation is a good start. :)
  • Verified that the issue was not related to "LOCK Interrupts miss initial event(s)", though it's certainly possible that this event also has that problem.
    That code looks good. Something must have gotten broken when I moved the sensitivities near the end of hub.
    I am traveling right now, but at the end of the day I will be able to look into this.
  • Sounds good.
    As an aside (very LOW priority), if you have to make any changes to this event code, maybe consider adding the following:
    setwrl D/#, where value is %mm_iiii
    mm: mode
    00 : any written value
    01 : non-zero written
    10 : zero written
    11 : any written value
    iiii: index
    This give WRLONG events the same granularity as EDGE events.
    Great idea! That's easy to do, too.
  • Chip & Seairth,
    I like that, but change the 11 mode to be wrote 0xFFFFFFFF (-1 or TRUE in Spin).
  • Roy Eltham wrote: »
    Chip & Seairth,
    I was thinking that too, but then I wanted to generalize to tests for positive negative, zero, not zero, etc...
    My original suggestion has parity with edge/lock events, which has merit.
    In the end, I'm fine with Chip implementing it however he wants. Just as long as it doesn't delay anything. :)
    Well, I looked at the code, but it looks quite okay. I'll just need to test this when I get back home.
    I really wanted to work more on the documentation tonight, but I need to get some sleep for tomorrow.
    Sorry I'm not any more help at this time. I'll be back on top of things soon.
  • Chip,
    Is pnut loading that long with the address into the cog appropriately in Seairth's example?
    Seairth,
    Try moving the address value into the register from a long immediate (mov hwr0, ##$FFF80), instead of having it be just preset in the data.
    Chip,
    Seairth,
    That was the purpose of the RDLONG test.
    edited 2015-10-17 13:54
    Roy Eltham wrote: »
    Chip & Seairth,
    Signed/unsigned detection is important because lower bits can carry a payload.
    Roy Eltham wrote: »
    Chip,
    It all looks okay to me.
  • Keeping this alive... I also verified that pnut compiled the SETWRL instruction correctly.
    I would have already had this fixed, but I'm still traveling for a few more days and I don't have access to my whole setup. I'm glad you guys are still trying things.
  • Chip,
    What was the reasoning for making SETWRL/SETRDL long-only? Now that the instructions have the configuration bit space, could you generalize these to byte addresses instead?
    SETHWR %xx_yyyyyy 'hub write-event
    SETHRD %xx_yyyyyy 'hub read-event
    My thought is that the operation (byte/word/long) doesn't matter, just the starting address. As a result, if you had a SETHWR %00_000001 (matching $FFF81), you would get the event for "WRBYTE/WORD/LONG val, ##FFF81", but not "WRWORD/LONG val, ##FFF80".
