LOCK Interrupts miss initial event(s)
Seairth
in Propeller 2
Chip,
It looks like initial LOCK (and possibly EDGE) events are getting lost. In the following code, the first two events are not getting triggered.
However, if I move the ISR to a separate cog, then I only seem to lose the first event:
dat org setb dirb, #0 'indicates ISR activity setb dirb, #1 'indicates main loop activity waitx ##25_000_000 'wait 1/2 second for INB to figure itself out setedg #%1_11_00_0000 'lock, set or clear, index 0 mov ijmp1, #isr 'set up ISR setint1 #3 'edge-triggered event loop lockset #0 'set lock notb outb, #1 'toggle GRN 1 waitx ##50_000_000 'wait 1sec lockclr #0 'clear lock notb outb, #1 'toggle GRN 1 waitx ##50_000_000 'wait 1sec jmp #loop 'repeat forever... isr notb outb, #0 'toggle GRN 0 reti1
dat org 0 coginit #16, #@lock_test setb dirb, #1 'indicates main loop activity waitx ##25_000_000 'wait 1/2 second for INB to figure itself out loop lockset #0 'set lock notb outb, #1 'toggle GRN 1 waitx ##50_000_000 'wait 1sec lockclr #0 'clear lock notb outb, #1 'toggle GRN 1 waitx ##50_000_000 'wait 1sec jmp #loop 'repeat forever... org 0 lock_test setb dirb, #0 'indicates ISR activity setedg #%1_11_00_0000 'lock, set or clear, index 0 mov ijmp1, #isr 'set up ISR setint1 #3 'edge-triggered event .loop jmp #.loop 'loop forever isr notb outb, #0 'toggle GRN 0 reti1
