BeMicro CV A9 - 301.000K LE - Page 2 — Parallax Forums
2
  • jmgjmg Posts: 15,200
    edited 2015-06-25 17:01
    David Betz wrote: »
    The 1-2-3 board is an expensive option. It seems to me that some people who wanted to work with the older P2 images found it difficult to justify buying even a DE0-Nano. Requiring the 1-2-3 board will probably limit the number of testers.
    Agreed, which is why the thread exists.
    The BeMicro CV A9 is a good candidate, what otherFPGA boards make the cut as well, will come down to "what fits"
    The 'use case' has improved, with Altera moving a little where the WebPACK supports
    Quite a lot can be done with one COG, but if less than one COG is needed to fit, it quickly becomes compromised too far.
    To complicate things, it sounds like the Cyclone V is a relatively large jump from Altera, and reports seem to be fitting is slower, and logic use is up.
    If Parallax have to tune too much specifically to Cyclone V, that makes other cores harder to support.
  • SeairthSeairth Posts: 2,474
    edited 2015-06-25 19:46
    Tubular wrote: »
    Better start working out a good use case Seairth, that'd solve it
    Hah! Indeed I am!
    edited 2015-06-25 21:48
    FYI Guys
    I did a test compile for this board with a single P1V with 1152K Hub ram.
    The build used 77% of the available memory bits and 8% of the ALM's!
  • TubularTubular Posts: 4,774
    edited 2015-06-25 22:18
    Awesome.
    Must be bordering on 100 cogs, enough for servicing 100 interrupts :-)
    Max 10m50 board turned up this arvo
    edited 2015-06-25 22:34
    ozpropdev wrote: »
    FYI Guys
    How long does that ~8% build take ?
    edited 2015-06-26 00:47
    Tubular wrote: »
    I had a attempt at building "Propzilla" a 12 x P1V 96 Cog beast.
    Quartus got about 45 minutes into a compile then gave up with errors.
    Turns out I exceeded the total IO pin count.
    Based on a 5 x P1V 40 cog build which took 90 minutes, "Propzilla" may take 4+ hours to compile.:(
    jmg wrote: »
    30 minutes for the 1152K hub version build, 20 minutes for a standard 32K build.
    BTW A 32K build used 5% memory bits and 8% ALM's
  • jac_goudsmitjac_goudsmit Posts: 418
    edited 2015-06-26 11:32
    Those horrible compile times for Cyclone V targets don't make me happy. My BeMicro CV is gathering dust mostly because the long build times don't leave much time for playing around. I was considering the CVA9 because $149 is a lot cheaper than the DE2-115 but the price difference and the extra features and the much faster compile time (10 minutes) just might make me save up for a DE2 anyway.
    Altera really should get their act together and do something about how big of a turn-off the Cyclone V is to potential customers. Maybe they should allow multi-CPU compilation or partial compilation on the free Quartus just for the Cyclone V or something.
    ===Jac
    edited 2015-06-26 11:46
    ===Jac
    Actually, I believe multi-cpu compile is enabled if you enable their TalkBack thing. Incremental compilation would be nice, though. I suspect that would make a big difference.
  • LeonLeon Posts: 7,620
    edited 2015-06-26 12:34
    Quartus 15.0 uses both cores on my system for the Cyclone IV and V with the free software.
    edited 2015-06-26 17:15
    I am impressed with those multi P1V builds.
    The CVA9 sounds like a cheap choice to get a big Cyclone V.
    Unfortunately, the 1-2-3 board will be way more expensive. Most likely this is because Parallax will not get the buy price of the A9 that they are getting for the BeMicro version.
    So the design loop should be check the code using a limited version for the DE0-nano and once verified, add it to the A9 build. That way development is done with short compile times.
    edited 2015-07-02 09:24
    I just ordered a BeMIcro CV A9 board in spite of the high shipping cost to the UK and our Value-Added Tax (20% on total inc. shipping), which push the price up considerably.
  • AleAle Posts: 2,363
    A9 ? Does the free Quartus support he CV A9 now ?
    My BeMicros are also gathering dust... now if I could only decide between PIC32, LPC17xx and STM32... that would be great ! :).
    edited 2015-07-02 10:21
    It does with the 15.0 version and update. All the Cyclones including the SoCs with dual-core ARM® Cortex®-A9s are now supported by the free tools.
    edited 2015-07-06 17:49
    My BeMicro CV A9 board arrived this morning. Unlike the earlier CV board with the smaller FPGA it came with a 5V power supply - the USB supply is only suitable for small designs. Unfortunately, it only has a US mains plug, I probably have a suitable PS with a UK plug somewhere.
    I tried a simple VHDL test program which lights an LED when a switch is pressed, and it built and ran OK. I can't get on with Verilog. If anyone else wants to try VHDL here is the program:
    -- Simple test program for BeMicro CV A9 kit
    -- Lights LED1 when S1 button is pressed
    -- LED1 - Pin B17
    -- Switch S1 (Tact1) - Pin H18
    LIBRARY IEEE;
    USE IEEE.STD_LOGIC_1164.all;
    ENTITY Test IS
        PORT
            LED1    : OUT    STD_LOGIC;
            S1    : IN STD_LOGIC
    END Test;
    ARCHITECTURE a OF Test IS
       attribute chip_pin : string;
       attribute chip_pin of LED1 : signal is "B17";
       attribute chip_pin of S1 : signal is "H18";
    BEGIN
        LED1 <= S1;
    END a;
    How does one include code in a post? It hasn't come out too badly, anyway.
    I've just found a US-UK adapter, so I can use the PS supplied with the kit.
    The BESCOPE is a 50 MHz oscilloscope add-on for the old CV and the new CV A9:
    http://parts.arrow.com/item/detail/arrow-development-tools/bescope#nRgG
    It only costs $45
  • I hope it installs better than the old one:
    http://forums.parallax.com/discussion/157115/bescopebundle-system-files/p1
    My older CV collects dust because of install issues. Got the scope to work once, then upgraded some files, and it broke. Very little support from Arrow last time I looked.
    edited 2015-07-06 19:37
    I probably won't bother with it as I have a perfectly good 100 MHz 4 channel Rigol scope.
    Have you tried a recent download? They might have fixed the bugs.
  • I probably won't bother with it as I have a perfectly good 100 MHz 4 channel Rigol scope.
    And my Parallax PropScope works just fine, also. :)
  • TorTor Posts: 2,010
    Where is a good place to buy the CV A9 board from? I would suffer the same extra cost issues as Leon (more, actually) if I order from Norway, but I could consider ordering one when I go back to Japan.
    (btw. where did 'Location' go? No support in Vanilla?)
    I tried a simple VHDL test program which lights an LED when a switch is pressed, and it built and ran OK. .
    Do you have build and download times for the small test pgm ?
    edited 2015-07-06 21:12
    Tor,
    They are only available from Arrow in the USA, AFAIK. I paid another £27 VAT.
    edited 2015-07-07 05:48
    Hei Leon,
    does Quartus 15 compile faster for Cyclone V than 13 or 14 did ? I kept using my MachXO2 board just because Lattice Diamond is way faster at compiling :)
    edited 2015-07-07 07:07
    I don't remember how fast they were, and I'm not going to download them to find out. :)
    I forgot. They don't support the A9 anyway.
    Total elapsed build time was 2m 55s.
    Download time was 1m 22s (JTAG).
    The BeMicro CV A9 is a great price point for P2 development, & I see Altera/Terasic have a new  offering around the MAX10
    http://www10.edacafe.com/nbc/articles/1/1364898/Altera-Showcases-Capabilities-Single-Chip-Configurable-Processors-Latest-MAX-10-FPGA-Kit
    It has a 7" CAP touch LCD, so that boosts the price to ~$373, but if you wanted to do advanced LCD work that may be tolerable.
    edited 2015-07-24 17:08
    Japan.
    Altera partnered the BeMirco CVA9 to be sold only by Arrow Electronics.  They do have offices all over the world, but you may not find them able to provide you with a single unit purchase.  If you can avoid VAT, I'd ship to Japan unless their customs gets nasty.
    Shopping for the BeMicro CV and CVA9 has been driving me nuts.  Here in Kaohsiung, Arrow Electronics is actually 3 minutes from my home --- but it seems that all sales go through the USA online office unless you are someone special.
    In the end, I have had to pay a $44USD shipping bill that I wanted to avoid.  But I did order a BeMicro CV, a BeMicro CVA9, and the BeMicro 50 Mhz twin oscilloscope card for about $286USD including shipping.
    Considering all that, it is difficult for me to support the purchase of the Propeller 1-2-3 board at $375.  And this purchase might actually get more developers actively testing the Propeller 2.  One board can be used as an oscilloscope (Windows required -- sorry), and the other board is plenty large for anything the Propeller 2 might do.  That is a lot of test bench.  And the oscilloscope board seems to include an adapter that will plug in more boards (perhaps DIY), a probe, and software.
    Sadly, I don't see how the FPGA industry will ever allow Parallax to make a competitive profit from building their own board.
    Perhaps Parallax should focus on a plug-in support board for these FPGAs and let the industry do the rest.
  • Has anyone managed to program the QSPI (x4) Flash for persistent configuration?
    My programming process stops at 60%, goes to 0% and then fails.
  • rjo__rjo__ Posts: 2,114
    Years ago, I bought a de1--- something( from Terasic). Couldn't take the first step.
    Then I got a nano... nice first step. Then a BeMicroCV... collecting dust. Then a de2-115 from Parallax... huge step, mostly because of pik33 and ozpropdev. Then the BeMicroCV9... nothing yet, but I have plans:)
    Total it all up and it is about the cost of a semester at a public college.
    The de2-115 got killed and replaced with the P123 board. I'm sitting here looking at the 1-2-3...It is absolutely gorgeous. Nice footprint. Add a little display over the top and you have a little package that you just can't beat. All for about what it would cost you to take one class at a local college.
    As a hobbyist, it is all about learning. And most importantly... how to learn the most in the least amount of time and with the most amount of fun... dust isn't fun. If you think it will collect dust
    don't do it!!!! But if you think you will learn a lot and have fun doing it... it is well worth the price.
    edited 2015-08-06 18:51
    6581 wrote: »
    "6581", are you using the files and instructions from my Github repo to download an FPGA image to the BeMicroCV-A9? There are some small differences compared to the BeMicroCV and others.
    Short version:
    1. Build it
    2. Convert program file using BeMicroCV-A9.cof (file type=.jic, config device=EPCQ256, mode=Active Serial X4; almost all these settings are different from other targets!)
    3. Open the Download dialog, make sure hardware is detected (USB-Blaster), add file output_files\bemicrocv-a9.jic, select Program/Configure, then Start. The progress bar may "go around" more than once, I'm not sure why. Also sometimes it fails right when you click Start, again I don't know why. Just select the file, delete it and add it again, then hit Start again. Most of the time that works for me.
    ===Jac
  • @jac_goudsmith: Thats exactly what I did. The configuration never succeeds. It goes to 40%, sometimes to 60%, then gets slow, then starts again and then fails. Maybe its worth saying that I am running it on Linux in Virtualbox on a OSX machine.
