Open Propeller Project #3: Propeller IDE V0.1 Package Available - Page 15 — Parallax Forums
1121315171829
  • dgatelydgately Posts: 1,641
    edited 2014-03-04 17:35
    Well, what diya know...
    Here's XCode building and debugging PropellerIDE!
    Whilst debugging a crash that was happening every time the project called "QuaZip zip(dstPath);", while debugging in Qt Creator, I found some info on having qmake build an XCode project from a Qt project file! Since I'm familiar with XCode, I was able to figure out that PropellerIDE was calling an older qua zip lib buried in /opt/local/qt5/. Resetting $PATHS to include current qt bin & lib directories got this working.
    Notes on Qt & XCode:
    https://qt-project.org/doc/qt-5.0/qtdoc/qmake-platform-notes.html
    Look for: "Creating and Moving Xcode Projects" and specifically:
    [COLOR=#363534]qmake -spec macx-xcode project.pro[/COLOR]
    As you were...
    dgately
    1024 x 693 - 125K
  • ersmithersmith Posts: 6,231
    edited 2014-03-05 03:05
    Heater. wrote: »
    But there are advantages to having the ability to use the compiler as a library as well. It can then provide functions to the IDE that provide a lot more information about the source code.
    True... but there are also advantages to being easily able to swap out backends. For example, it might be nice to be able to compile the Spin code to LMM with spin2cpp, or to use bstc's optimizer.
    Can we use the DLL for syntax highlighting and such, but still have the option to call an external program for the actual compilation?
    Eric
  • RsadeikaRsadeika Posts: 3,864
    edited 2014-03-05 04:55
    What to do WITH the terminal aspect of Propeller IDE? I know that in SimpleIDE you would use print()/printf() to display in the terminal, but Propeller IDE is different. I remember that JonnyMac had at one time a debug object which used the TV as a terminal, should an idea like that be implemented in Propeller IDE? Should this IDE have a built in debug command, when used it would automatically bring up the terminal and display the contents of the debug command.
    The only other way to use the terminal is too implement the FDS object, but isn't that a little overkill for use as a debug tool? Is there a simpler object or way too accomplish this? I know there are quite a few people that want the terminal program to be a stand alone, but even then how would you use that for the best use with the IDE? Just curious as to how people plan too use the terminal feature of Propeller IDE?
    Ray
    edited 2014-03-05 05:43
    Ray,
    Using a terminal as a debug tool is quite common with Spin programmers. The Propeller Tool comes with a serial terminal (Parallax Serial Terminal) and the standard libraries that ship with it (and presumably will be bundled with PropellerIDE) contain the Parallax Serial Terminal object which is used quite often for basic debugging and interfacing to a user. I believe there are also debug oriented variations of the PST object. Don't fear, it will get used and if it also shows up as a standalone Terminal/Loader, it will be used even more! :smile:
  • JonnyMacJonnyMac Posts: 9,545
    edited 2014-03-05 06:58
    No, I didn't. I have always used a terminal window for debugging. Others have used TV and VGA output, but not me -- those objects consume too many resources.
    edited 2014-03-05 07:18
    Sorry JonnyMac, maybe I was remembering the Debug to LCD, and it became TV in my mind. So, the question still remains if a form of debug should be part of the IDE or do we just still rely on FDS.spin as the preferred method for using the terminal for debug?
    Ray
    edited 2014-03-05 07:23
    As the Propeller doesn't have any special debugging hooks built in, serial debugging seems the most logical/practical solution. Even those specialty programs that spy on the Propeller are communicating to the application through a serial link.
  • jazzedjazzed Posts: 11,803
    edited 2014-03-05 07:39
    Since Terminal was mentioned, It should be noted that the SimpleIDE terminal has been added to the project. The terminal is supposed to support the PST movement commands. One issue left is that the baud-rate is not persistent yet.
    Regarding the PST movement features, I've been searching for spin code used to test them but can't find anything at the moment. The test code for SimpleIDE is written in C. If anyone has some PST movement command test code, please post it here.
    There was also an issue on Mac with propeller load failing after adding the blinky COG status window. Please test loading on all platforms and let me know if there is any issue.
    One thing that the IDE is having trouble with at the moment is parsing a huge file for the method browser. This is most annoying at startup, and is a good reason for me to go ahead and look at adding a tree drop down from the file name. That means that the IDE will startup without the list of functions, and the user will get to click the file name to see the methods. There are other options in this idea to consider, but I'll save that for another time.
    edited 2014-03-05 07:57
    jazzed wrote: »
    Coolio! I can rebuild and test on my Mac this afternoon.
    Thanks!
    edited 2014-03-05 09:05
    Windows 7 box.
    Below is a quick and dirty, just too see what if anything is working. Positioning (X value) of the char "A" is not working, and that was the same problem back some time ago when I tried it with SimpleIDE. The term.Tx(13) is not acting like a real carriage return, but a new line. Later on I will try some more things, but I did notice that a pause is no longer needed for the terminal catch up.
    Ray
    '' terminal.spin
    CON
      _clkmode   = xtal1 + pll16x
      _xinfreq   = 5_000_000
    rxPin    = 31
    txPin    = 30
    mode     = 0
    baudrate = 115200
    OBJ
      misc : "tools" ''This contains waitms which not needed.
      term : "FullDuplexSerial"
    PUB Start
      term.Start(rxPin, txPin, mode, baudrate)
      main
    '' Main
    PUB main
      term.Tx(13)
      term.str(string("This is a line."))
      term.Tx(13)
      term.Tx(14)  ''cursor X
      term.Tx(10)
      term.Tx(15)  ''cursor Y
      term.Tx(10)
      term.Tx("A")
    edited 2014-03-05 09:46
    Is it just me, or has anyone noticed that the closing paren is missing on method calls in the editor?
    Rsadeika wrote: »
    Windows 7 box.
    Hmm. Wish I had known about that before today! :)
    Rsadeika wrote: »
    Unfortunately, this is a problem caused by interpreting what 10 and 13 means. Windows and Linux (or Unix) interpret these things differently. Hardcoding them is a mistake for multi-os use, but windows only use, it's perfectly fine :) We can't complain much about this mistake as Spin fans any more than Apple fans can complain about that silly, though historical, global application menu bar on the Mac.
    As it is, "Spinny" is "Windowy" and we just just have to live with it.
    edited 2014-03-05 11:27
    So, there is a couple of more problems. To make the individual cursor moves you have to lead with Y, then X. So, that makes (2)-Position cursor X,Y completely useless. When you want too move to position 0, it does not work, because when you use Tx(0), it clears the screen.
    I briefly tested the cursor up and down, that seems to work, also (11)-Clear to end of line, seems to work. The other problem I ran into is maybe something to do with Qt Create, it seems like there is a program size limit. The test program that I did had maybe 40 lines of code, and it did not run all of the code lines.
    Ray
    edited 2014-03-05 11:42
    Rsadeika wrote: »
    Ray
    Ray, please provide an updated file demonstrating issues as you find them. It's much easier to fix things when they can be reproduced. The second paragraph has an interesting statement that I have no idea how to reproduce unless you provide code.
    edited 2014-03-05 12:30
    Now this q&d snippet, sometimes it runs completely and sometimes it doesn't, if you keep hitting the run in terminal consistently. There is also a problem with cursor right cursor left. What I was expecting is the cursor too move around the letter "A". Hope this helps.
    Ray
    '' terminal.spin
    CON
    rxPin    = 31
    txPin    = 30
    mode     = 0
    baudrate = 115200
    OBJ
      misc : "tools"
    PUB Start
      main
    '' Main
    PUB main
      term.Tx(13)
      term.Tx(10)
      term.Tx(15) ''Y
      term.Tx(1)
      term.Tx(14)  ''X
      term.Tx(7)
      term.Tx(11)  ''Clear to end of line
      term.Tx(15)  ''Y
      term.Tx(9)
      term.Tx(14)  ''X
      term.Tx(5)
      term.Tx("A")
    ''  term.Tx(15)  ''Y
    ''  term.Tx(9)
    ''  term.Tx()
    ''  misc.waitms(1000)
      term.Tx(5)  ''cursor up
      misc.waitms(1000)
      term.Tx(6)  ''cursor down
      misc.waitms(1000)
      misc.waitms(1000)
      term.Tx(3)  ''cursor left
      misc.waitms(1000)
      term.Tx(4)  ''cursor right
      misc.waitms(1000)
    tools.spin
    '' tools.spin
    PUB wait(time)
      waitcnt((80_000_000 * time) + cnt)
    PUB waitms(time)
      waitcnt(((80_000_000 / 1000) * time) + cnt)
    PUB high(pin)
      DIRA[pin] := %1
      OUTA[pin] := 1
    PUB low(pin)
      DIRA[pin] := %1
      OUTA[pin] := 0
    edited 2014-03-05 13:01
    Here's another test of cursor movement in the terminal... (Part of an overall PropellerIDE test suite)
    testPropIDE.spin
    testPropIDEPause.spin
    It fails to do the Position(x,y) and Char(console#PC) correctly at several points in the code. (Failure is noted in the Terminal during testing and within the spin source code)
    The "project" (I know, the P-word is not normally to be used in PropellerIDE, but it helps to explain my test "suite") includes 2 .spin files but also uses the Parallax Serial Terminal object. I set the Preferences Libraries directory to where I have placed PST and leave the testPropIDEPause.spin file in the same directory as the main .spin (testPropIDE.spin) file. This is to test the use of objects that are local as well as in a specified directory of libs.
    BTW: When testing is complete, the Activity Board pins 26 & 27 LEDs will flash...
    Two other issues about the terminal implementation:
    1. The Terminal window starts out kinda small. Could the default be A) larger and B) saved if the user changes the window size?
    2. The "Propeller Programming OK" dialog sometimes appears in front of the terminal window and remains there for several seconds after text is starting to display
    dgately
    edited 2014-03-05 19:26
    I'm currently working on bringing Find & Replace into PropellerIDE. Taking the current Find & Replace from SimpleIDE, I'm thinking about using a drop-down dialog at the top of the editor box in place of the SimpleIDE Find & Replace dialog box.
    My thoughts:
    1. The dialog gets in the way of the editor and always needs to be moved out of the way by the user. New method should not hinder editing view while search/replace is under way.
    2. The dialog only allows clicking on arrows buttons to search forward or backward. Allow Cntl/Cmd keys (Cntl-G Cntl-SHIFT-G AND Cmd-G & Cmd-SHIFT-G for Mac OS X) for searching forward and backward.
    Heres a few mockups of a roll-down/pop-up panel for Find & Replace:
    Layout and Usage
    Find alone:
    Find & Replace:
    Let me know what you think about these solutions. Probably, just the Find & Replace could b used as a unit (no need for just the Find panel).
    dgately
    896 x 588 - 255K
    898 x 588 - 264K
    832 x 738 - 106K
    edited 2014-03-05 22:09
    jazzed wrote: »
    I've spent most of my available time today looking for the source of this problem! Ugh.
    Turns out that it is an issue with the parallax2.ttf font. The old parallax.ttf font and the new parallax2-bold.ttf font don't have the problem.
    I did get a chance to improve the performance of loading complicated Spin files. That is worth a new pull/upgrade and build.
    I'll look at these other posts in the morning.
    edited 2014-03-06 03:57
    Debian 64-bit box.
    The latest clone has a complie error, can not find "Terminal2.h". In Terminal2.cpp I changed #include "Terminal2.h" too #include "terminal2.h" , and that sort of allowed it too compile. Not sure what other problems that might of created.
    The terminal.spin example that I showed, in the previous post, seems too work the same way as it does in the Windows 7 box, only the last twelve lines of code are being implemented. This problem seems to be more consistent now. The Propeller Programming OK window seems too hover way too long in the Debian box also.
    I tried the properties window for a compiler type, the Files of type: shows Spin Compiler (openspin.* openspin), but the listing of the files is still blank.
    Ray
    edited 2014-03-06 10:45
    Rsadeika wrote: »
    Debian 64-bit box.
    Sorry about that. Your fix was correct. I've pushed a change to the repository.
    Rsadeika wrote: »
    Hmm, I had no problems with this. Regardless, I made a small change that lets you choose openspin*
    Rsadeika wrote: »
    Ray, your positioning code is wrong. You have to send the command first and then the argument. I.E.
      term.Tx(15) ' Y position command
      term.Tx(10) ' line number
    It's actually better to use PST "Parallax Serial Terminal" for these kinds of things because it encapsulates the sequences correctly.
    Fix your program and re-test. If you have further problems, let me know.
    edited 2014-03-06 10:51
    dgately wrote: »
    testPropIDE.spin
    Thanks Dennis. It's a good test suite program. I like the spelling correction bit :)
    dgately wrote: »
    dgately
    The terminal window now starts a bit bigger. Please remove the .plist and restart after pull/update, build to see the results.
    The "Propeller Programming OK" dialog "on time" has been reduced.
    edited 2014-03-06 10:56
    dgately wrote: »
    I like these ideas a lot. Find is one command, Replace is another command, ... then one could have the more adventurous Refactor feature as a separate command :)
    If we don't hear any objections from the Spinny Forumista Faithful crowd soon, I'd say you have Carte Blanche.
    edited 2014-03-06 14:28
    jazzed wrote: »
    Carte Blanche? Oh boy, look out! :smile:
    Thanks!
    edited 2014-03-06 16:27
    If no one speaks up, you could probably go raid Louis Vitton with your Carte Blanche.
    dgately wrote: »
    Dennis, while you certainly found a bug ... I agree that position(x,y) and Char(console#PC) were misbehaving, the expected output of U,X,D is a little off.
    Snippet showing your expectation:
       '' test cursor to x,y then move up, down
       '' should print something like:
       ''    U
       ''    X
       ''    D
       '' at col 15
       console.Char(console#PC)
       console.Char(15)
       console.Char(4)
       console.Str(string("X"))            '' FAILS TO GO TO THE X POSITION!!!
       pauseLib.Pause(200)
       console.Char(console#MU)            '' move the cursor up & print 'U'
       console.Str(string("U"))
       pauseLib.Pause(200)
       console.Char(console#MD)            '' move the cursor down 2 & print 'D'
    The problem is that move up and move down both should move from the last cursor column.
    That is, the result of your code should be this. The Parallax Serial Terminal also behaves this way.
       ''     U
       ''    X
       ''      D
    edited 2014-03-06 17:07
    I've updated the serial terminal cursor movement stuff for Linux/Mac, but it is broken for windows right now. Will get back to that soon.
    edited 2014-03-06 17:43
    jazzed wrote: »
       ''     U
       ''    X
       ''      D
    Yes, my intention was to move the cursor up 1, then back one, type a "U" then down 2, then back one, type "D" to align the text vertically, but when I realized that Position(x,y) was broken, I left out the aligning backward moves to spare some confusion until a fix was in-hand :thumb:
    I'll add back the other moves to the test code...
    dgately
    edited 2014-03-06 21:39
    dgately wrote: »
    dgately
    Ok ;) thanks for explaining.
    Yes, fix should be in hand now. I've also updated the windows console which only needed that silly LFCR/CRLF swap. As it turns out, I had a bad PST.spin on my computer causing me all kinds of grief.
    Guess what?
    I don't have anything to do now except eat dog-food :)
    Send me diffs you have for the zip thing? I'd bet find/replace is more rewarding right now.
    Actually there is the error line highlighting thing, but I don't want to interfere with Roy.
    edited 2014-03-07 09:40
    jazzed wrote: »
    A little more testing today, then I'll send the zip diffs to you. It's working, but I also want to add-in the new progress dialog as it processes the zip.
    dgately
    edited 2014-03-07 11:00
    I've got "phase 1" of background highlighting functioning locally. I just need to do a bit of cleanup before I commit it (maybe tonight?).
    I call it phase 1 because right now the colors are hard coded, and there are some minor issues, like the last line doesn't highlight the whole line if there isn't a newline on it. There's probably even more issues I haven't run into yet.
    I'll need to add the colors to the settings dialog someplace.
    edited 2014-03-07 15:27
    That's great news, Roy. One of the features I appreciate about the Propeller Tool is the context-sensitive background colors.
    edited 2014-03-07 16:00
    JonnyMac,
    Yeah, that's one of the things I really like about PropTool, and a big part of why I signed up to do it for PropellerIDE. One difference between what I have now and what PropTool does, is that I'm not changing anything about the text colors themselves. I'm only changing the background color. In PropTool, the text colors for things like comments adjust to a shade of the background color they are on. Eventually, I'll try to get that working as well, but likely only for comments and not anything else.
