SimpleIDE 0-9-45 Linux ... - Page 4 — Parallax Forums
124
    edited 2014-02-26 03:01
    Loopy,
    Odd, typing "SimpleIDE" into Google gets me directly to the right page as the first hit. http://learn.parallax.com/propeller-c-set-simpleide
    Perhaps Google know me too well.
  • RsadeikaRsadeika Posts: 3,901
    edited 2014-02-26 04:46
    I just created an kubuntu 64-bit session on my VMware setup, Iinstalled SimpleIDE-0-9-47, and the results:I
    Installing ./simpleide as ray
    Found /opt/parallax/bin
    On first run ./simpleide will install ~/Documents/SimpleIDE .
    Remove ~/Documents/SimpleIDE to get a new copy of the workspace.
    Previous users should remove ~/.config/ParallaxInc/SimpleIDE.conf .
    Setup complete. To run program use: ./simpleide
    ray@ubuntu:~/Downloads/SimpleIDE-0-9-47$ ./simpleide
    ray@ubuntu:~/Downloads/SimpleIDE-0-9-47$ Cannot mix incompatible Qt library (version 0x40804) with this library (version 0x40802)
    Aborted (core dumped)
    Kubuntu 64-bit does not like too run very well in a VMware session, especially when you are trying too run Firefox at the same time you trying to do other things. More on this later.
    Ray
    edited 2014-02-26 05:12
    Ray,
    So the fun begins, anybody have a translation of what that error means? What would be the next step?
    As it says, you don't have the library "libpng12". No doubt Fedora has a different version of that library.
    Your obvious next step is Google "libpng12 fedora"
    That immediately gets you to others who have had this problem already. For example:
    http://developer.appcelerator.com/question/137812/fedora-17-64bit-libpng12
    Here we learn installing libpng-compat might help:
    $ yum install libpng-compat
    Kbuntu: Again, back to Google. Sure enough a ton of people have had that problem as well...
    Hey but wait, SimpleIDE only needs the libQtGui and libQtGui both of which are in the package. And the simpleide shell script should take care of finding them in the bin directory.
    edited 2014-02-26 05:29
    Wow, what a horrible VMware session I just had with the kubuntu 64-bit install. Either VMware does not like 64-bit installations, or kubuntu 64-bit needs a whole lot of resources to run, or a combination of both. To end the VMware session, I just had running, I had to power down the computer to get VMware to release the kubuntu 64-bit session it was running.
    I think I need to make a choice of a Linux system, looks like Debian should be the system of choice, and give up on the other versions of Linux, as far as running Propeller related software is concerned. I guess I will just stick with a Debian box, and let someone else test out Fedora, all variations of Ubuntu, and openSUSE, and the other endless list of Linux installs.
    So, Debian is the only REAL Linux system, for now.
    Ray
    edited 2014-02-26 06:05
    Rsadeika wrote: »
    Ray
    Not that I have any interest in Kubuntu, but your tales of misery make me want to try it running under Parallels on my Mac. I'll grab an image and see how it works for me.
  • dgatelydgately Posts: 1,647
    edited 2014-02-26 07:49
    Rsadeika wrote: »
    Doubtful... As you've seen, VMWare runs Debian 64-bit versions without issue. Did you install VMWare Tools? Did you try different VMWare settings? Did you check-in on the VMWare forums to see if others have run Kubuntu 64-bit and had similar problems? As others have noted, Google can help you find solutions pretty quickly.
    dgately
    edited 2014-02-26 09:45
    Ray,
    Careful there, some would say that Slackware is still the "original and best":)
    Debian is close enough for me.
    You might be interested in some notes I made on how I set up Debian starting from a small netinst CD: http://the.linuxd.org/debian-installation-log/
    I like to have KDE rather than that awful GNOME desktop.
    edited 2014-02-26 09:58
    Forgot about that one, I think I will run that with VMware, just too get a sense of what that one is all about. Maybe I will change my mind after the VMware session, and then I will start touting Slackware. All in all, their are just too many Linux versions ...
    Ray
    edited 2014-02-26 11:54
    Rsadeika wrote: »
    Ray
    ... and Linux people complain about Forths??? Sheeeesh!!! :lol:
  • jazzedjazzed Posts: 11,803
    edited 2014-02-26 12:22
    mindrobots wrote: »
    You can run a forth on Linux, but you can't run Linux on a forth. You might be able to run it on a fifth though :)
    edited 2014-02-26 12:27
    jazzed wrote: »
    You might consider it after a fifth!
  • TorTor Posts: 2,010
    edited 2014-02-26 20:35
    For Debian, Ubuntu, Kubuntu (presumably), and other .deb (APT)-based package systems, you won't need to resort to Google to find which package you need to install to get e.g. libpng12. Just do 'apt-cache search libpng12' from the command line (or from any of the Gui wrappers if you prefer). Or, if that doesn't work, use 'apt-file': apt-get install apt-file; apt-file update; apt-file search name-of-file
    -Tor
    edited 2014-02-27 05:41
    I just did a re-install of a Debian KDE box, which will be my final solution. I also just installed SimpleIDE-0-9-47, and I noticed something weird, when the hello program comes up and I run it, nothing shows up on the terminal screen. But when I change the print("Hello") to printf("hello"), then it shows on the terminal screen. Did my simpletools.h get messed up? Is anybody else seeing this?
    Ray
    edited 2014-02-27 08:14
    Rsadeika wrote: »
    Probably. I would honestly expect the opposite to happen though.
    edited 2014-02-27 08:47
    I just re installed SimpleIDE-0-9-47, and I am still getting the same problem, print() is not functioning. But strange enough the pause() works, so it seems that simpletools.h is all right, just print() is not working. Hopefully somebody with a Debian 64 will try it out and see if they get the same results. This occurs in a newly created project, and the Welcome session.
    Ray
    edited 2014-02-27 08:54
    Heater,
    Where does the SimpleIDE workspace come from in your 0-9-47 distribution?
    Which PropellerGCC version do you build?
    Thanks.
    edited 2014-02-27 09:56
    Jazzed,
    Workspace is the thing I get prompted to fetch with hg somewhere along the line. What happens to it next I have no idea.
    I'll have to check the details when I get back to my PC later today.
    edited 2014-02-27 10:34
    OK, I'm home sooner than I planned today.
    propgcc in that packager was a very recent pull of the default branch:
    ~/propeller/propgcc$ hg branch
    default
    ~/propeller/propgcc$ hg identify
    783d7ea9a07a+ tip
    propside also a recent pull of the spinside branch:
    ~/propeller/propside$ hg branch
    spinside
    ~/propeller/propside$ hg identify
    6d758a533d01 (spinside) tip
    The Works space is the default (only) branch:
    ~/propeller/propside/Workspace$ hg branch
    default
    michael@debian:~/propeller/propside/Workspace$ hg identify
    351ab4cf1a4e tip
    Does that say anything? What is the issue here?
    edited 2014-02-27 10:50
    Hi Heater.
    We haven't had a chance to run a program of testing on the default branch yet, so I'm not sure if we should be "distributing" it. That said, I doubt that has anything to do with Ray's simple library problem.
    The other "tips" look fine to me.
    I'll test that package when I have time.
    edited 2014-02-27 11:09
    There is a little problem with this.
    The first run of simpleide is supposed create a directory "SimpleIDE" in ~/Documents. Or at least that's what it says in the INSTALL.txt and it's what it does if I have a ~/Documents directory.
    However my machine does not have a ~/Documents directory and neither do I want one. So this sequence:
    $ tar -xjvf SimpleIDE-0-9-47.x86_64.debian-linux.tar.bz2
    $ cd SimpleIDE-0-9-47/
    $ ./setup.sh heater
    $ ./simpleide
    silently fails to create that ~/Documents/SimplIDE directory.
    What does it actually do?
    It creates ~/SimpleIDE instead. And when you look in the Properties dialog that is where it looks for the "Workspace Folder".
    edited 2014-02-27 11:13
    Jazzed,
    Ah, so Ray is now on the testing team. Excellent:)
    If only I had a Propeller around here to test against.
    edited 2014-02-27 11:25
    Yes, whether you guys like it or not :-) I just checked for a Documents folder, I do not have one either.
    Ray
    edited 2014-02-27 11:45
    Well, now I'm stuck.
    I don't have any board types in the "Board Type" drop down box. Can't program anything without a board type.
    I have a "/opt/parallax/propeller-load" directory full of nice .cfg and .dat files.
    And that is where SimpleIDE says it is looking in the properties dialog.
    edited 2014-02-27 11:48
    But wait...
    If I clear the "Loader Folder" setting and save that. Then go back in there and set the same thing back again it works!
    So, I now have Welcome.c running. The "print" works. No "printf" required.
    edited 2014-02-27 11:55
    Ray has always been on the testing team!
    Heater, Not sure about that clear folder stuff. It would be great if you can help understand it though. Did you remove the ~/.config/ParallaxInc properties folder before running the program? The "Clear Settings" button does the same thing.
    edited 2014-02-27 12:02
    Yep, been doing a lot of removing of ~/.config/ParallaxInc, ~/SimpleIDE and /opt/parallax just now.
    Can't get external RAM to work on my Gadget Gangster board any more:
    Loading the serial helper to hub memory9808 bytes sent
    Verifying RAM ...
    OKLoading external memory driver 'sqi_sram_xmem.dat'
    1008 bytes sent
    Loading program image to RAM
    20564 bytes sent
    Loading .xmmkernel
    1984 bytes sent
    Used to work ages ago.
    edited 2014-02-27 12:17
    I don't know. I just deleted everything and installed again.
    Again the board type was empty.
    This time I just opened the properties and hit OK, then all was well.
    Now what is the board type for the Gadget Gangster SDRAM board again? Didn't we used to have something that said SDRAM?
    edited 2014-02-27 14:22
    Heater. wrote: »
    The default branch does things differently, and that driver hasn't been ported yet.
    edited 2014-02-27 14:56
    Jazzed,
    Ah, OK. Propgcc release branch build now under way.
    edited 2014-02-28 01:50
    Heater. wrote: »
    Loopy,
    Try "SimpleIDE Linux"
    You might get off into the same weeds I did. I do try to contextualize searches as much as possible. . . not sure what Google is up to.
    Using Forth has gotten me up to speed on using PASM as Dave Hein's pfth is very clear. So GCC keeps ending up on the backburner in my tiny world.
