14 below zero (F) is just wrong!
mindrobots
....and then 31 below if you are into wind chill!
3 cheers for working from home!!
In Marysville, Ohio (30min north of Columbus) it is -17. And I had to go to work, UGH!!
Sorry! So much for my "move south" plan!!!
My "move south" plan will happen in May. I'm tired of the cold.
If southern Taiwan is too much of a change for you, Hawaii is actually one degree further south.
edit: added a couple of photos taken from my balcony. I saw several other people out taking pictures. It's extremely unusual to see snow here.
Erlend
Edit: But tomorrow it's supposed to get up to 24 ABOVE. We've had that kind of roller coaster all winter. 24 above tomorrow, then single digits and teens for highs through next week. That is still way below normal for Western Wisconsin.
You're right, -28 is wronger!
Funny, though, after a bunch of this stuff this winter, I hardly notice the difference between -14 and -28. I'm kinda bothered by that...
That was the same winter I flew from Minneapolis to Orlando - it was -54 wind chill when I left and 86 degrees when I landed in Orlando.....talk abut messing with the mind and body!
Now tell me, what's all that white stuff on the ground in the photos posted here?
LCD Operating temp range: -4 to +158 °F (-20 to +70 °C)
BOE Operating temp range: +32 to +158 °F (0 to +70 °C)
Hello!
Here in Astoria Queens it is 17 degrees. And we still have some snow on the ground from the last big snow storm that nearly toppled the guy who claims to run the sanitation department.
Now if you want snow erco, I can recommend a location in the Cascade mountains. Just be careful of the owner, he's a very bored Siberian Tiger.
This isn't today but this is what SNOW really looks like in Ohio. (I'm not sure what that stuff you are seeing is!
This was from March 8, 2008 - about 5AM, the dog needed to go out.
Probably "The Great Blizzard of1978" I remember it well. In Louisville, there was a (then) record snowfall on January 17, but less than a week later another huge blizzard hit the upper Midwest. Louisville didn't get quite as much snow from that one but farther north it was pretty bad.
Strangely enough on January 17, 1994, exactly 16 years to the day after the 1978 record snowfall, that record was broken (but just barely). I also remember another winter in between those, maybe 1985, when there was another huge snowstorm that brought extremely low temperatures, around -24 F. I think that was in January also.
(Working with firewood)
We only worked about 45 - 50 minutes at a time, then had a coffee/tea-break and a chance to swap out wet glowes and stuff.
is when it is cold we want it hot
and when it is hot we want it cold
whatever it is we want it is not.
Last fall, I was yukking it up when I paid only $1.44/gallon for my propane pre-buy. Now I'm really sweating to stay within the 1200 gallons that I bought so I don't have to pay the current $4.00+/gallon. My supplier says I have about 1 1/2 fills left so I think I'll be in good shape. Knock on wood!
Not wrong! I think its kind of cool!
Anyway, now its a blistering 266 K
