Propeller II update - BLOG - Page 92 — Parallax Forums
18990929495223
    edited 2013-10-11 12:58
    Big change underway here.
    You guys might have noticed how adding all these new instructions was introducing many caveats into the op-code mapping. It had become a big Swiss cheese. A lot of waste was occurring, too because of WR bits (R) that never practically changed, effectively cutting the number of possible instructions in half. There needs to be individual control of Z and C writing, but only a few cases of controlling D writing offered any value, like SUB versus CMP.
    I'm combing through the op-codes now, grouping them by D-writing and flag-affecting. It's freed up tons of instruction space we can now have D,S instructions wherever they're beneficial. I'll post the list a little later today when it's more final.
    edited 2013-10-11 13:04
    jmg wrote: »
    Ah ok, so the structure is a 128:1 mux and then a local edge detector ?
    This would have a leading edge blanking scheme, to avoid false-triggering when activated on a pin already hi ?
    That's right.
    By the way, I added the timeout via WC, just like WAITPEQ/WAITPNE.
  • jmgjmg Posts: 15,200
    edited 2013-10-11 13:07
    David Betz wrote: »
    How about if the first time you execute one of these edge detection instructions it always fails to detect an edge no matter what the state of the pin but it remembers what pin is being monitored so it can constantly sample it until the instruction comes around again at which time you return the real result. So, if the pin in the instruction matches the one that is being remembered then you return a real value. If not, you change the pin being remembered and start monitoring that new pin until encountering another instruction checking the same pin. I guess that's a bit convoluted though.
    Interesting idea :
    Then the edge detector becomes a mini cell (one per COG) that always operates, but discards any history if Index changes.
    That would allow a sticky/not-sticky option however starting it could get tricky ?
    One pin value would need to be illegal/reset value, and to set the pin index, you would need to execute the opcode.
    [ with 3 choices already, Rise, Fall, Change, is there a free 4th value, that can be used to set the pin index, but not wait ? ]
    That would allow SW to prime the detector, then do other stuff then check /wait when it was ready.
    A loop tail case that took longer, would still proceed with some jitter, (but no missing edges) and as long as the next loop was shorter, re-sync would resume.
    If someone used in this in 2 threads, I think it proceeds on an interleave-stall basis ?
    edited 2013-10-11 13:08
    Magic :)
  • pjvpjv Posts: 1,903
    edited 2013-10-11 14:28
    Chip;
    I'm doing a lot of work in P1 using the global clock, and keeping track of individual threads' timings relative to that. Very frequently I need to know whether or not the global counter is ahead or behind a target value, and I do that with a subtract. Trouble always is what to do about roll-overs. So the answer is to do a subtract, and examine the most significant bit (31) of the result, because just looking at the subtract's borrow will not work when rollovers are present. A left shift puts bit31 into the carry, and this works great, but takes more instructions than is desired for fast operations.
    For the P2, could you invent a single cycle instruction that does a subtract, and copies bit31 into the carry ? It will reduce 3 instructions down to 1 for many locations in my code.
    Cheers,
    Peter (pjv)
    edited 2013-10-11 14:59
    pjv wrote: »
    For the P2, could you invent a single cycle instruction that does a subtract, and copies bit31 into the carry ? It will reduce 3 instructions down to 1 for many locations in my code.[\QUOTE]
    'Already did that, as it turns out. I saw the same need. It's called CMPCNT. I think it copies !bit31 to C, so that C is set if you are past the goal.
    edited 2013-10-11 15:14
    Chip
    I'd posted this question on another thread, but since it's important to me to know, I'll repeat it here:
    On the subject of QUAD-related instructions operation, despite the last documents doesn't describe it that way, could you confirm or deny, if a SETQUAD or SETQUAZ instruction execution, inherently implies a CACHEX-like operation too?
    Yanomani
    P.S. Answered by Chip, at the original thread.
    "No, only CACHEX causes the cache to be invalidated."
    edited 2013-10-12 00:28
    KC_Rob,
    Event-driven is certainly the ideal. I suppose its zenith might be an automated system which can launch a cog to process an event.
    "Even driven" seems to be quite a woolly term. So what I meant by it is a bit different. What you have described there sounds like traditional interrupt handling except instead of jumping to an interrupt routine a whole new COG is started to handle it.
    What I had in mind my "event driven" is a bit more fine grained. A single program might have many things it needs to wait for at different stages of it's processing. A UART for example needs to wait on:
    a) Arrival of a character from the user program to be transmitted.
    b) A timer so that it can bit-bang the TX at the right time.
    c) An input pin so it can respond to incoming start bits.
    d) Another timer so it can clock in the Rx bits on time.
    e) Perhaps other signals for flow control.
    Here we have code halting exection and waiting for the next event, when the event arrives it ressumes execution immediately. No context saving and jumping to an interrupt routine, no loading of a COG, it's just ready to run.
    This kind of event driven processing can be done by having many processors each of which can wait on anything when ever it likes without blocking others. Or it can be be done with hardware scheduled threads.
  • KC_RobKC_Rob Posts: 465
    edited 2013-10-12 09:26
    Heater. wrote: »
    KC_Rob,
    When you think about it, though, these are merely different ways to get at the same thing. What I describe is not an "interrupt" in the traditional sense, since nothing in truth is being interrupted/blocked. It too uses multiple processors to handle events but has the potential advantage of not burning a processor (power) until the event actually occurs; ie, no software churning doing essentially nothing in the meantime. As for your UART example, bits would best be handled at the hardware level - though I would argue for a generalized SerDes implementation. Characters, or multiple characters, if there is hardware buffering, would be processed in software as "events." Hardware scheduled threads or hardware managed cogs to process events - different ways to get the same end result, each with its own advantages and disadvantages.
    edited 2013-10-12 09:40
    KC_Rob,
    The UART is better done in hardware, it was only an example of what I mean by "event driven programming". The same style can be used for many other things. The idea is a code goes around it can have many points where it has to wait for some condition to become true, an event.
    Now interrupts are a way to respond to events but they do have the problem that whatever is running is stopped whilst the interrupt handler run. They can also suffer form latency issues as you have to save processor context prior to executing the handler.
    On a single processor machine an RTOS is what is used to get processes to wait on events, and interrupts are used to kick the RTOS around. Here we have all the problems of interrupts plus the latency and overheads of an OS and it thread switching etc.
    You solution, starting a COG to handle an even, can no doubt work but how do we get around the huge latency of loading a COG and starting it?
    ...the potential advantage of not burning a processor (power) until the event actually occurs; ie, no software churning doing essentially nothing in the meantime.
    Good point. An ideal implementation of events would have the instruction waiting for an event halt until the event occurs. Thus consuming a lot less power. Isn't this what happens with WAITPxx, WAITVID etc. Not sure how it works with multi-threading on the Prop II.
    edited 2013-10-12 09:58
    Heater. wrote: »
    KC_Rob,
    What is it now for COGINIT, 7-22 clocks? Perhaps something can be done, in hardware, to speed this up. Now is that really huge? I guess it depends on what you're doing.
    Are those instructions the eq. to a dormant cog, in terms of power consumption? As for P2 and threads, I'm not sure either. I suspect, though, that power will be squandered to some degree.
    edited 2013-10-12 10:22
    It must take some thousands of cycles to load a COG still on PII.
    edited 2013-10-12 10:26
    It should take something like 500*8/4 = 1000 cycles, shouldn't it?
    edited 2013-10-12 11:26
    Dave Hein wrote: »
    I'm guessing this is about the correct number, most of it chewed up by getting code in the cog, right? So, what I propose would have to be done some way outside the current, normal method for launching cogs. I had assumed this is doable somehow with hardware mods. Perhaps not, though.
    edited 2013-10-12 11:48
    KC_Rob wrote: »
    I had assumed this is doable somehow...
    For instance, by launching the cog with a pointer to PASM code (located in a memory dedicated to this) rather than the usual copying etc. Then, launch time should in the dozens of cycles max - ie, apprx. what COGINIT is now. That was the idea anyway.
    edited 2013-10-16 02:28
    I've been busy for the last few days reorganizing the op-code mapping and I think I've got it about done. In the new scheme, instructions' result-writing is fixed. For the cases where it was useful to not write the result (SUB NR = CMP), there are now dedicated non-result-writing instructions. Z and C writing is still controllable, of course, since that is mission critical.
    By getting rid of the R bit, the instruction set was able to expand, so that things like unary operations can have separate source and destination registers. This new instruction coding is much simpler and more regular than before. It will make assemblers and compilers easier to write. Also, a lot of configuration operations take fewer instructions now, since both D and S can convey immediate or register data. For example: SETSERA D,S (config,baud). It now takes 4 instructions to configure the texture mapper, where it used to take 8.
    Roy Eltham and I have been talking about what can be done to improve the texture mapper and he suggested quite a few byte/pixel transforms and new blending methods, such as additive and multiplicative (both 1x and 2x). All these pixel blends will now be able to be done directly, without engaging the texture mapper, through simple instructions.
    Propeller II Revised Op-Codes (16 October 2013)
    ZCDS (for D column: W=write, M=modify, R=read, L=read/immediate)
    ZCWS			0000000 ZC I CCCC DDDDDDDDD SSSSSSSSS		RDBYTE	D,S/PTRx		(waits for hub)
    ZCWS			0000001 ZC I CCCC DDDDDDDDD SSSSSSSSS		RDBYTEC	D,S/PTRx		(waits for hub if cache miss)
    ZCWS			0000010 ZC I CCCC DDDDDDDDD SSSSSSSSS		RDWORD	D,S/PTRx		(waits for hub)
    ZCWS			0000011 ZC I CCCC DDDDDDDDD SSSSSSSSS		RDWORDC	D,S/PTRx		(waits for hub if cache miss)
    ZCWS			0000100 ZC I CCCC DDDDDDDDD SSSSSSSSS		RDLONG	D,S/PTRx		(waits for hub)
    ZCWS			0000101 ZC I CCCC DDDDDDDDD SSSSSSSSS		RDLONGC	D,S/PTRx		(waits for hub if cache miss)
    ZCWS			0000110 ZC I CCCC DDDDDDDDD SSSSSSSSS		RDAUX	D,S/#/SPx
    ZCWS			0000111 ZC I CCCC DDDDDDDDD SSSSSSSSS		RDAUXR	D,S/#/SPx
    ZCMS			0001000 ZC I CCCC DDDDDDDDD SSSSSSSSS		ISOB	D,S
    ZCMS			0001001 ZC I CCCC DDDDDDDDD SSSSSSSSS		NOTB	D,S
    ZCMS			0001010 ZC I CCCC DDDDDDDDD SSSSSSSSS		CLRB	D,S
    ZCMS			0001011 ZC I CCCC DDDDDDDDD SSSSSSSSS		SETB	D,S
    ZCMS			0001100 ZC I CCCC DDDDDDDDD SSSSSSSSS		SETBC	D,S
    ZCMS			0001101 ZC I CCCC DDDDDDDDD SSSSSSSSS		SETBNC	D,S
    ZCMS			0001110 ZC I CCCC DDDDDDDDD SSSSSSSSS		SETBZ	D,S
    ZCMS			0001111 ZC I CCCC DDDDDDDDD SSSSSSSSS		SETBNZ	D,S
    ZCMS			0010000 ZC I CCCC DDDDDDDDD SSSSSSSSS		ANDN	D,S
    ZCMS			0010001 ZC I CCCC DDDDDDDDD SSSSSSSSS		AND	D,S
    ZCMS			0010010 ZC I CCCC DDDDDDDDD SSSSSSSSS		OR	D,S
    ZCMS			0010011 ZC I CCCC DDDDDDDDD SSSSSSSSS		XOR	D,S
    ZCMS			0010100 ZC I CCCC DDDDDDDDD SSSSSSSSS		MUXC	D,S
    ZCMS			0010101 ZC I CCCC DDDDDDDDD SSSSSSSSS		MUXNC	D,S
    ZCMS			0010110 ZC I CCCC DDDDDDDDD SSSSSSSSS		MUXZ	D,S
    ZCMS			0010111 ZC I CCCC DDDDDDDDD SSSSSSSSS		MUXNZ	D,S
    ZCMS			0011000 ZC I CCCC DDDDDDDDD SSSSSSSSS		ROR	D,S
    ZCMS			0011001 ZC I CCCC DDDDDDDDD SSSSSSSSS		ROL	D,S
    ZCMS			0011010 ZC I CCCC DDDDDDDDD SSSSSSSSS		SHR	D,S
    ZCMS			0011011 ZC I CCCC DDDDDDDDD SSSSSSSSS		SHL	D,S
    ZCMS			0011100 ZC I CCCC DDDDDDDDD SSSSSSSSS		RCR	D,S
    ZCMS			0011101 ZC I CCCC DDDDDDDDD SSSSSSSSS		RCL	D,S
    ZCMS			0011110 ZC I CCCC DDDDDDDDD SSSSSSSSS		SAR	D,S
    ZCMS			0011111 ZC I CCCC DDDDDDDDD SSSSSSSSS		REV	D,S
    ZCWS			0100000 ZC I CCCC DDDDDDDDD SSSSSSSSS		MOV	D,S
    ZCWS			0100001 ZC I CCCC DDDDDDDDD SSSSSSSSS		NOT	D,S
    ZCWS			0100010 ZC I CCCC DDDDDDDDD SSSSSSSSS		ABS	D,S
    ZCWS			0100011 ZC I CCCC DDDDDDDDD SSSSSSSSS		NEG	D,S
    ZCWS			0100100 ZC I CCCC DDDDDDDDD SSSSSSSSS		NEGC	D,S
    ZCWS			0100101 ZC I CCCC DDDDDDDDD SSSSSSSSS		NEGNC	D,S
    ZCWS			0100110 ZC I CCCC DDDDDDDDD SSSSSSSSS		NEGZ	D,S
    ZCWS			0100111 ZC I CCCC DDDDDDDDD SSSSSSSSS		NEGNZ	D,S
    ZCMS			0101000 ZC I CCCC DDDDDDDDD SSSSSSSSS		ADD	D,S
    ZCMS			0101001 ZC I CCCC DDDDDDDDD SSSSSSSSS		SUB	D,S
    ZCMS			0101010 ZC I CCCC DDDDDDDDD SSSSSSSSS		ADDX	D,S
    ZCMS			0101011 ZC I CCCC DDDDDDDDD SSSSSSSSS		SUBX	D,S
    ZCMS			0101100 ZC I CCCC DDDDDDDDD SSSSSSSSS		ADDS	D,S
    ZCMS			0101101 ZC I CCCC DDDDDDDDD SSSSSSSSS		SUBS	D,S
    ZCMS			0101110 ZC I CCCC DDDDDDDDD SSSSSSSSS		ADDSX	D,S
    ZCMS			0101111 ZC I CCCC DDDDDDDDD SSSSSSSSS		SUBSX	D,S
    ZCMS			0110000 ZC I CCCC DDDDDDDDD SSSSSSSSS		SUMC	D,S
    ZCMS			0110001 ZC I CCCC DDDDDDDDD SSSSSSSSS		SUMNC	D,S
    ZCMS			0110010 ZC I CCCC DDDDDDDDD SSSSSSSSS		SUMZ	D,S
    ZCMS			0110011 ZC I CCCC DDDDDDDDD SSSSSSSSS		SUMNZ	D,S
    ZCMS			0110100 ZC I CCCC DDDDDDDDD SSSSSSSSS		MINS	D,S
    ZCMS			0110101 ZC I CCCC DDDDDDDDD SSSSSSSSS		MAXS	D,S
    ZCMS			0110110 ZC I CCCC DDDDDDDDD SSSSSSSSS		MIN	D,S
    ZCMS			0110111 ZC I CCCC DDDDDDDDD SSSSSSSSS		MAX	D,S
    ZCMS			0111000 ZC I CCCC DDDDDDDDD SSSSSSSSS		ADDABS	D,S
    ZCMS			0111001 ZC I CCCC DDDDDDDDD SSSSSSSSS		SUBABS	D,S
    ZCMS			0111010 ZC I CCCC DDDDDDDDD SSSSSSSSS		INCMOD	D,S
    ZCMS			0111011 ZC I CCCC DDDDDDDDD SSSSSSSSS		DECMOD	D,S
    ZCMS			0111100 ZC I CCCC DDDDDDDDD SSSSSSSSS		CMPSUB	D,S
    ZCMS			0111101 ZC I CCCC DDDDDDDDD SSSSSSSSS		SUBR	D,S
    ZCMS			0111110 ZC I CCCC DDDDDDDDD SSSSSSSSS		MUL	D,S			(waits one clock)
    ZCMS			0111111 ZC I CCCC DDDDDDDDD SSSSSSSSS		SCL	D,S			(waits one clock)
    ZCWS			1000000 ZC I CCCC DDDDDDDDD SSSSSSSSS		DECOD3	D,S
    ZCWS			1000001 ZC I CCCC DDDDDDDDD SSSSSSSSS		DECOD4	D,S
    ZCWS			1000010 ZC I CCCC DDDDDDDDD SSSSSSSSS		DECOD5	D,S
    Z-WS			1000011 Z0 I CCCC DDDDDDDDD SSSSSSSSS		ENCOD	D,S
    Z-WS			1000011 Z1 I CCCC DDDDDDDDD SSSSSSSSS		BLMASK	D,S
    Z-WS			1000100 Z0 I CCCC DDDDDDDDD SSSSSSSSS		ONECNT	D,S			(waits one clock)
    Z-WS			1000100 Z1 I CCCC DDDDDDDDD SSSSSSSSS		ZERCNT	D,S			(waits one clock)
    -CWS			1000101 0C I CCCC DDDDDDDDD SSSSSSSSS		INCPAT	D,S			(waits three clocks)
    -CWS			1000101 1C I CCCC DDDDDDDDD SSSSSSSSS		DECPAT	D,S			(waits three clocks)
    --WS			1000110 00 I CCCC DDDDDDDDD SSSSSSSSS		SPLITW	D,S
    --WS			1000110 01 I CCCC DDDDDDDDD SSSSSSSSS		MERGEW	D,S
    --WS			1000110 10 I CCCC DDDDDDDDD SSSSSSSSS		ESWAP4	D,S
    --WS			1000110 11 I CCCC DDDDDDDDD SSSSSSSSS		ESWAP8	D,S
    --WS			1000111 00 I CCCC DDDDDDDDD SSSSSSSSS		SEUSSF	D,S
    --WS			1000111 01 I CCCC DDDDDDDDD SSSSSSSSS		SEUSSR	D,S
    --WS			1000111 10 I CCCC DDDDDDDDD SSSSSSSSS		BINGRY	D,S
    --WS			1000111 11 I CCCC DDDDDDDDD SSSSSSSSS		GRYBIN	D,S			(waits one clock)
    --MS			10010nn n0 I CCCC DDDDDDDDD SSSSSSSSS		GETNIB	D,S,#n
    --MS			10010nn n1 I CCCC DDDDDDDDD SSSSSSSSS		SETNIB	D,S,#n
    --MS			1001100 n0 I CCCC DDDDDDDDD SSSSSSSSS		GETWORD	D,S,#n
    --MS			1001100 n1 I CCCC DDDDDDDDD SSSSSSSSS		SETWORD	D,S,#n
    --MS			1001110 00 I CCCC DDDDDDDDD SSSSSSSSS		ROLNIB	D,S
    --MS			1001110 01 I CCCC DDDDDDDDD SSSSSSSSS		ROLBYTE	D,S
    --MS			1001110 10 I CCCC DDDDDDDDD SSSSSSSSS		ROLWORD	D,S
    --MS			1001110 11 I CCCC DDDDDDDDD SSSSSSSSS		SWBYTES	D,S			(switch/copy bytes in D, S = %11_10_01_00 = D same)
    --MS			1001111 00 I CCCC DDDDDDDDD SSSSSSSSS		PACKRGB	D,S			(8:8:8 -> 5:5:5 << 16 | D >> 16)
    --MS			1001111 01 I CCCC DDDDDDDDD SSSSSSSSS		SETS	D,S
    --MS			1001111 10 I CCCC DDDDDDDDD SSSSSSSSS		SETD	D,S
    --MS			1001111 11 I CCCC DDDDDDDDD SSSSSSSSS		SETI	D,S
    --MS			101000n n0 I CCCC DDDDDDDDD SSSSSSSSS		GETBYTE	D,S,#n
    --MS			101000n n1 I CCCC DDDDDDDDD SSSSSSSSS		SETBYTE	D,S,#n
    -CMS			1010010 0C I CCCC DDDDDDDDD SSSSSSSSS		COGNEW	D,S			(waits for hub)
    -CMS			1010010 1C I CCCC DDDDDDDDD SSSSSSSSS		WAITCNT	D,S			(waits for cnt)
    --MS			1010011 00 I CCCC DDDDDDDDD SSSSSSSSS		MIXPIX	D,S			(waits two clocks)
    --MS			1010011 01 I CCCC DDDDDDDDD SSSSSSSSS		MULPIX	D,S			(waits two clocks)
    --MS			1010011 10 I CCCC DDDDDDDDD SSSSSSSSS		MULPIX2	D,S			(waits two clocks)
    --MS			1010011 11 I CCCC DDDDDDDDD SSSSSSSSS		ADDPIX	D,S
    ZCWS			1010100 ZC I CCCC DDDDDDDDD SSSSSSSSS		JMPRET	D,S			(set D to INA for JMP/RET)
    ZCWS			1010101 ZC I CCCC DDDDDDDDD SSSSSSSSS		JMPRETD	D,S 			(set D to INA for JMP/RET)
    --MS			1010110 00 I CCCC DDDDDDDDD SSSSSSSSS		IJZ	D,S
    --MS			1010110 01 I CCCC DDDDDDDDD SSSSSSSSS		IJZD	D,S
    --MS			1010110 10 I CCCC DDDDDDDDD SSSSSSSSS		IJNZ	D,S
    --MS			1010110 11 I CCCC DDDDDDDDD SSSSSSSSS		IJNZD	D,S
    --MS			1010111 00 I CCCC DDDDDDDDD SSSSSSSSS		DJZ	D,S
    --MS			1010111 01 I CCCC DDDDDDDDD SSSSSSSSS		DJZD	D,S
    --MS			1010111 10 I CCCC DDDDDDDDD SSSSSSSSS		DJNZ	D,S
    --MS			1010111 11 I CCCC DDDDDDDDD SSSSSSSSS		DJNZD	D,S
    ZCRS			1011000 ZC I CCCC DDDDDDDDD SSSSSSSSS		TESTB	D,S
    ZCRS			1011001 ZC I CCCC DDDDDDDDD SSSSSSSSS		TESTN	D,S
    ZCRS			1011010 ZC I CCCC DDDDDDDDD SSSSSSSSS		TEST	D,S
    ZCRS			1011011 ZC I CCCC DDDDDDDDD SSSSSSSSS		CMP	D,S
    ZCRS			1011100 ZC I CCCC DDDDDDDDD SSSSSSSSS		CMPX	D,S
    ZCRS			1011101 ZC I CCCC DDDDDDDDD SSSSSSSSS		CMPS	D,S
    ZCRS			1011110 ZC I CCCC DDDDDDDDD SSSSSSSSS		CMPSX	D,S
    ZCRS			1011111 ZC I CCCC DDDDDDDDD SSSSSSSSS		CMPR	D,S
    --RS			11000nn n0 I CCCC DDDDDDDDD SSSSSSSSS		COGINIT	D,S,#0..7		(waits for hub) (SETNIB :coginit,cog,#6)
    ---S			11000nn n1 I CCCC nnnnnnnnn SSSSSSSSS		WAITVID	#n,S			(waits for vid if single-task, loops if multi-task)
    --RS			1100011 11 I CCCC DDDDDDDDD SSSSSSSSS		WAITVID	D,S				(waits for vid if single-task, loops if multi-task)
    -CRS			110010n nC I CCCC DDDDDDDDD SSSSSSSSS		WAITPEQ	D,S,#port		(waits for pins, +cnt32 if wc) (4)
    -CRS			110011n nC I CCCC DDDDDDDDD SSSSSSSSS		WAITPNE	D,S,#port		(waits for pins, +cnt32 if wc) (4)
    --LS			1101000 0L I CCCC DDDDDDDDD SSSSSSSSS		WRBYTE	D,S/PTR			(waits for hub)
    --LS			1101000 1L I CCCC DDDDDDDDD SSSSSSSSS		WRWORD	D,S/PTR			(waits for hub)
    --LS			1101001 0L I CCCC DDDDDDDDD SSSSSSSSS		WRLONG	D,S/PTR			(waits for hub)
    --LS			1101001 1L I CCCC DDDDDDDDD SSSSSSSSS		FRAC32	D,S
    --LS			1101010 0L I CCCC DDDDDDDDD SSSSSSSSS		WRAUX	D,S/#0..FF/SPx
    --LS			1101010 1L I CCCC DDDDDDDDD SSSSSSSSS		WRAUXR	D,S/#0..FF/SPx
    --LS			1101011 0L I CCCC DDDDDDDDD SSSSSSSSS		SETACA	D,S
    --LS			1101011 1L I CCCC DDDDDDDDD SSSSSSSSS		SETACB	D,S
    --LS			1101100 0L I CCCC DDDDDDDDD SSSSSSSSS		MACA	D,S
    --LS			1101100 1L I CCCC DDDDDDDDD SSSSSSSSS		MACB	D,S
    --LS			1101101 0L I CCCC DDDDDDDDD SSSSSSSSS		DIV32	D,S
    --LS			1101101 1L I CCCC DDDDDDDDD SSSSSSSSS		DIV32U	D,S
    --LS			1101110 0L I CCCC DDDDDDDDD SSSSSSSSS		DIV64	D,S
    --LS			1101110 1L I CCCC DDDDDDDDD SSSSSSSSS		DIV64U	D,S
    --LS			1101111 0L I CCCC DDDDDDDDD SSSSSSSSS		MUL32	D,S
    --LS			1101111 1L I CCCC DDDDDDDDD SSSSSSSSS		MUL32U	D,S
    --LS			1110000 0L I CCCC DDDDDDDDD SSSSSSSSS		SQRT64	D,S
    --LS			1110000 1L I CCCC DDDDDDDDD SSSSSSSSS		QSINCOS	D,S
    --LS			1110001 0L I CCCC DDDDDDDDD SSSSSSSSS		QARCTAN	D,S
    --LS			1110001 1L I CCCC DDDDDDDDD SSSSSSSSS		QROTATE	D,S
    --LS			1110010 0L I CCCC DDDDDDDDD SSSSSSSSS		SETSERA	D,S			(config,baud)
    --LS			1110010 1L I CCCC DDDDDDDDD SSSSSSSSS		SETSERB	D,S			(config,baud)
    --LS			1110011 0L I CCCC DDDDDDDDD SSSSSSSSS		SETCTRS	D,S
    --LS			1110011 1L I CCCC DDDDDDDDD SSSSSSSSS		SETWAVS	D,S
    --LS			1110100 0L I CCCC DDDDDDDDD SSSSSSSSS		SETFRQS	D,S
    --LS			1110100 1L I CCCC DDDDDDDDD SSSSSSSSS		SETPHSS	D,S
    --LS			1110101 0L I CCCC DDDDDDDDD SSSSSSSSS		ADDPHSS	D,S
    --LS			1110101 1L I CCCC DDDDDDDDD SSSSSSSSS		SUBPHSS	D,S
    --LS			1110110 0L I CCCC DDDDDDDDD SSSSSSSSS		SETPIX0	D,S			(config,Z)
    --LS			1110110 1L I CCCC DDDDDDDDD SSSSSSSSS		SETPIX1	D,S			(U, V)
    --LS			1110111 0L I CCCC DDDDDDDDD SSSSSSSSS		SETPIX2	D,S			(A, R)
    --LS			1110111 1L I CCCC DDDDDDDDD SSSSSSSSS		SETPIX3	D,S			(G, B)
    --LS			1111000 0L I CCCC DDDDDDDDD SSSSSSSSS		CFGPINS	D,S,#0			(waits for alt)
    --LS			1111000 1L I CCCC DDDDDDDDD SSSSSSSSS		CFGPINS	D,S,#1			(waits for alt)
    --LS			1111001 0L I CCCC DDDDDDDDD SSSSSSSSS		CFGPINS	D,S,#2			(waits for alt)
    --LS			1111001 1L I CCCC DDDDDDDDD SSSSSSSSS		JMPTASK	D,S			(mask,address)
    --LS			1111010 0L I CCCC DDDDDDDDD SSSSSSSSS		JP	D,S
    --LS			1111010 1L I CCCC DDDDDDDDD SSSSSSSSS		JPD	D,S
    --LS			1111011 0L I CCCC DDDDDDDDD SSSSSSSSS		JNP	D,S
    --LS			1111011 1L I CCCC DDDDDDDDD SSSSSSSSS		JNPD	D,S
    --RS			1111100 00 I CCCC DDDDDDDDD SSSSSSSSS		TJZ	D,S
    --RS			1111100 01 I CCCC DDDDDDDDD SSSSSSSSS		TJZD	D,S
    --RS			1111100 10 I CCCC DDDDDDDDD SSSSSSSSS		TJNZ	D,S
    --RS			1111100 11 I CCCC DDDDDDDDD SSSSSSSSS		TJNZD	D,S
    			<gap>
    ZCW-			1111110 ZC x CCCC DDDDDDDDD x00000000		COGID	D			(waits for hub)
    ZCW-			1111110 ZC x CCCC DDDDDDDDD x00000001		LOCKNEW	D			(waits for hub)
    ZCW-			1111110 ZC x CCCC DDDDDDDDD x00000010		GETCNT	D
    ZCW-			1111110 ZC x CCCC DDDDDDDDD x00000011		GETCNTX	D
    ZCW-			1111110 ZC x CCCC DDDDDDDDD x00000100		GETLFSR	D
    ZCW-			1111110 ZC x CCCC DDDDDDDDD x00000101		GETTOPS	D
    ZCW-			1111110 ZC x CCCC DDDDDDDDD x00000110		GETACAL	D			(waits for mac)
    ZCW-			1111110 ZC x CCCC DDDDDDDDD x00000111		GETACAH	D			(waits for mac)
    ZCW-			1111110 ZC x CCCC DDDDDDDDD x00001000		GETACBL	D			(waits for mac)
    ZCW-			1111110 ZC x CCCC DDDDDDDDD x00001001		GETACBH	D			(waits for mac)
    ZCW-			1111110 ZC x CCCC DDDDDDDDD x00001010		GETPTRA	D
    ZCW-			1111110 ZC x CCCC DDDDDDDDD x00001011		GETPTRB	D
    ZCW-			1111110 ZC x CCCC DDDDDDDDD x00001100		GETSPA	D
    ZCW-			1111110 ZC x CCCC DDDDDDDDD x00001101		GETSPB	D
    ZCW-			1111110 ZC x CCCC DDDDDDDDD x00001110		GETMULL	D			(waits for mul if single-task, loops if multi-task)
    ZCW-			1111110 ZC x CCCC DDDDDDDDD x00001111		GETMULH	D			(waits for mul if single-task, loops if multi-task)
    ZCW-			1111110 ZC x CCCC DDDDDDDDD x00010000		GETDIVQ	D			(waits for div if single-task, loops if multi-task)
    ZCW-			1111110 ZC x CCCC DDDDDDDDD x00010001		GETDIVR	D			(waits for div if single-task, loops if multi-task)
    ZCW-			1111110 ZC x CCCC DDDDDDDDD x00010010		GETSQRT	D			(waits for sqrt if single-task, loops if multi-task)
    ZCW-			1111110 ZC x CCCC DDDDDDDDD x00010011		GETQX	D			(waits for cordic if single-task, loops if multi-task)
    ZCW-			1111110 ZC x CCCC DDDDDDDDD x00010100		GETQY	D			(waits for cordic if single-task, loops if multi-task)
    ZCW-			1111110 ZC x CCCC DDDDDDDDD x00010101		GETQZ	D			(waits for cordic if single-task, loops if multi-task)
    ZCW-			1111110 ZC x CCCC DDDDDDDDD x00010110		SERINA	D			(waits for rx if single-task, loops if multi-task, releases if wc)
    ZCW-			1111110 ZC x CCCC DDDDDDDDD x00010111		SERINB	D			(waits for rx if single-task, loops if multi-task, releases if wc)
    ZCW-			1111110 ZC x CCCC DDDDDDDDD x00011000		GETPHSA	D
    ZCW-			1111110 ZC x CCCC DDDDDDDDD x00011001		GETPHZA	D			(clears phsa)
    ZCW-			1111110 ZC x CCCC DDDDDDDDD x00011010		GETCOSA	D
    ZCW-			1111110 ZC x CCCC DDDDDDDDD x00011011		GETSINA	D
    ZCW-			1111110 ZC x CCCC DDDDDDDDD x00011100		GETPHSB	D
    ZCW-			1111110 ZC x CCCC DDDDDDDDD x00011101		GETPHZB	D			(clears phsb)
    ZCW-			1111110 ZC x CCCC DDDDDDDDD x00011110		GETCOSB	D
    ZCW-			1111110 ZC x CCCC DDDDDDDDD x00011111		GETSINB	D
    ZCM-			1111110 ZC x CCCC DDDDDDDDD x00100000		PUSHZC	D
    ZCM-			1111110 ZC x CCCC DDDDDDDDD x00100001		POPZC	D
    ZCM-			1111110 ZC x CCCC DDDDDDDDD x00100010		SUBCNT	D			(subtracts D from cnt[31:0], then cntl if same thread)
    ZCM-			1111110 ZC x CCCC DDDDDDDDD x00100011		GETPIX	D			(waits two clocks)
    --M-			1111110 xx x CCCC DDDDDDDDD x00100100		INCD	D			(add $200 to D)
    --M-			1111110 xx x CCCC DDDDDDDDD x00100101		DECD	D			(subtract $200 from D)
    --M-			1111110 xx x CCCC DDDDDDDDD x00100110		INCDS	D			(add $201 to D)
    --M-			1111110 xx x CCCC DDDDDDDDD x00100111		DECDS	D			(subtract $201 from D)
    --L-			1111110 xx L CCCC DDDDDDDDD x00101000		CLKSET	D			(waits for hub)
    -CL-			1111110 xC L CCCC DDDDDDDDD x00101001		COGIDX	D			(waits for hub)
    --L-			1111110 xx L CCCC DDDDDDDDD x00101010		COGSTOP	D			(waits for hub)
    --L-			1111110 xx L CCCC DDDDDDDDD x00101011		LOCKRET	D			(waits for hub)
    -CL-			1111110 xC L CCCC DDDDDDDDD x00101100		LOCKSET	D			(waits for hub)
    -CL-			1111110 xC L CCCC DDDDDDDDD x00101101		LOCKCLR	D			(waits for hub)
    --L-			1111110 xx L CCCC DDDDDDDDD x00101110		WRQUAD	D/PTR			(waits for hub)
    --L-			1111110 x0 L CCCC DDDDDDDDD x00101111		RDQUAD	D/PTR			(waits for hub)
    --L-			1111110 x1 L CCCC DDDDDDDDD x00101111		RDQUADC	D/PTR			(waits for hub if cache miss)
    ZCL-			1111110 ZC L CCCC DDDDDDDDD x00110000		GETP	D			(pin into !z/c via wz/wc)
    ZCL-			1111110 ZC L CCCC DDDDDDDDD x00110001		GETNP	D			(pin into z/!c via wz/wc)
    -CL-			1111110 xC L CCCC DDDDDDDDD x00110010		SEROUTA	D			(waits for tx if single-task, loops if multi-task, releases if wc)
    -CL-			1111110 xC L CCCC DDDDDDDDD x00110011		SEROUTB	D			(waits for tx if single-task, loops if multi-task, releases if wc)
    -CL-			1111110 xC L CCCC DDDDDDDDD x00110100		CMPCNT	D			(subtracts S from cnt[31:0], then cntl if same thread)
    -CL-			1111110 xC L CCCC DDDDDDDDD x00110101		WAITCHG	D			(waits for edge)
    -CL-			1111110 xC L CCCC DDDDDDDDD x00110110		WAITPOS	D			(waits for edge)
    -CL-			1111110 xC L CCCC DDDDDDDDD x00110111		WAITNEG	D			(waits for edge)
    ZCL-			1111110 ZC L CCCC DDDDDDDDD x00111000		SETZC	D			(D[1:0] into z/c via wz/wc)
    --L-			1111110 xx L CCCC DDDDDDDDD x00111001		SETTASK	D
    --L-			1111110 xx L CCCC DDDDDDDDD x00111010		SETMAP	D
    --L-			1111110 xx L CCCC DDDDDDDDD x00111011		SETXCH	D
    --L-			1111110 xx L CCCC DDDDDDDDD x00111100		SETXFR	D
    --L-			1111110 xx L CCCC DDDDDDDDD x00111101		SARACA	D			(waits for mac)
    --L-			1111110 xx L CCCC DDDDDDDDD x00111110		SARACB	D			(waits for mac)
    --L-			1111110 xx L CCCC DDDDDDDDD x00111111		SARACS	D			(waits for mac)
    --L-			1111110 xx L CCCC DDDDDDDDD x01iiiiii		REPD	D,#i			(REPD $1FF,#i = infinite repeat)
    --L-			1111110 xx L CCCC DDDDDDDDD x10000000		SETSPA	D
    --L-			1111110 xx L CCCC DDDDDDDDD x10000001		SETSPB	D
    --L-			1111110 xx L CCCC DDDDDDDDD x10000010		ADDSPA	D
    --L-			1111110 xx L CCCC DDDDDDDDD x10000011		ADDSPB	D
    --L-			1111110 xx L CCCC DDDDDDDDD x10000100		SUBSPA	D
    --L-			1111110 xx L CCCC DDDDDDDDD x10000101		SUBSPB	D
    --L-			1111110 xx L CCCC DDDDDDDDD x10000110		SETQUAD	D
    --L-			1111110 xx L CCCC DDDDDDDDD x10000111		SETQUAZ	D
    --L-			1111110 xx L CCCC DDDDDDDDD x10001000		SETPTRA	D
    --L-			1111110 xx L CCCC DDDDDDDDD x10001001		SETPTRB	D
    --L-			1111110 xx L CCCC DDDDDDDDD x10001010		ADDPTRA	D
    --L-			1111110 xx L CCCC DDDDDDDDD x10001011		ADDPTRB	D
    --L-			1111110 xx L CCCC DDDDDDDDD x10001100		SUBPTRA	D
    --L-			1111110 xx L CCCC DDDDDDDDD x10001101		SUBPTRB	D
    --L-			1111110 xx L CCCC DDDDDDDDD x10001110		PASSCNT	D			(loops if (cnt[31:0] - D) msb set)
    --L-			1111110 xx L CCCC DDDDDDDDD x10001111		NOPX	D			(waits)
    --L-			1111110 xx L CCCC DDDDDDDDD x10010000		CALLA	D
    --L-			1111110 xx L CCCC DDDDDDDDD x10010001		CALLB	D
    --L-			1111110 xx L CCCC DDDDDDDDD x10010010		CALLAD	D
    --L-			1111110 xx L CCCC DDDDDDDDD x10010011		CALLBD	D
    --L-			1111110 xx L CCCC DDDDDDDDD x10010100		CALLAR	D
    --L-			1111110 xx L CCCC DDDDDDDDD x10010101		CALLBR	D
    --L-			1111110 xx L CCCC DDDDDDDDD x10010110		CALLARD	D
    --L-			1111110 xx L CCCC DDDDDDDDD x10010111		CALLBRD	D
    --L-			1111110 xx L CCCC DDDDDDDDD x10011000		OFFP	D
    --L-			1111110 xx L CCCC DDDDDDDDD x10011001		NOTP	D
    --L-			1111110 xx L CCCC DDDDDDDDD x10011010		CLRP	D
    --L-			1111110 xx L CCCC DDDDDDDDD x10011011		SETP	D
    --L-			1111110 xx L CCCC DDDDDDDDD x10011100		SETPC	D
    --L-			1111110 xx L CCCC DDDDDDDDD x10011101		SETPNC	D
    --L-			1111110 xx L CCCC DDDDDDDDD x10011110		SETPZ	D
    --L-			1111110 xx L CCCC DDDDDDDDD x10011111		SETPNZ	D
    --L-			1111110 xx L CCCC DDDDDDDDD x10100000		DIV64D	D
    --L-			1111110 xx L CCCC DDDDDDDDD x10100001		SQRT32	D
    --L-			1111110 xx L CCCC DDDDDDDDD x10100010		QLOG	D
    --L-			1111110 xx L CCCC DDDDDDDDD x10100011		QEXP	D
    --L-			1111110 xx L CCCC DDDDDDDDD x10100100		SETQI	D
    --L-			1111110 xx L CCCC DDDDDDDDD x10100101		SETQZ	D
    --L-			1111110 xx L CCCC DDDDDDDDD x10100110		CFGDACS	D
    --L-			1111110 xx L CCCC DDDDDDDDD x10100111		SETDACS	D
    --L-			1111110 xx L CCCC DDDDDDDDD x10101000		CFGDAC0	D
    --L-			1111110 xx L CCCC DDDDDDDDD x10101001		CFGDAC1	D
    --L-			1111110 xx L CCCC DDDDDDDDD x10101010		CFGDAC2	D
    --L-			1111110 xx L CCCC DDDDDDDDD x10101011		CFGDAC3	D
    --L-			1111110 xx L CCCC DDDDDDDDD x10101100		SETDAC0	D
    --L-			1111110 xx L CCCC DDDDDDDDD x10101101		SETDAC1	D
    --L-			1111110 xx L CCCC DDDDDDDDD x10101110		SETDAC2	D
    --L-			1111110 xx L CCCC DDDDDDDDD x10101111		SETDAC3	D
    --L-			1111110 xx L CCCC DDDDDDDDD x10110000		SETCTRA	D
    --L-			1111110 xx L CCCC DDDDDDDDD x10110001		SETWAVA	D
    --L-			1111110 xx L CCCC DDDDDDDDD x10110010		SETFRQA	D
    --L-			1111110 xx L CCCC DDDDDDDDD x10110011		SETPHSA	D
    --L-			1111110 xx L CCCC DDDDDDDDD x10110100		ADDPHSA	D
    --L-			1111110 xx L CCCC DDDDDDDDD x10110101		SUBPHSA	D
    --L-			1111110 xx L CCCC DDDDDDDDD x10110110		SETVID	D
    --L-			1111110 xx L CCCC DDDDDDDDD x10110111		SETVIDY	D
    --L-			1111110 xx L CCCC DDDDDDDDD x10111000		SETCTRB	D
    --L-			1111110 xx L CCCC DDDDDDDDD x10111001		SETWAVB	D
    --L-			1111110 xx L CCCC DDDDDDDDD x10111010		SETFRQB	D
    --L-			1111110 xx L CCCC DDDDDDDDD x10111011		SETPHSB	D
    --L-			1111110 xx L CCCC DDDDDDDDD x10111100		ADDPHSB	D
    --L-			1111110 xx L CCCC DDDDDDDDD x10111101		SUBPHSB	D
    --L-			1111110 xx L CCCC DDDDDDDDD x10111110		SETVIDI	D
    --L-			1111110 xx L CCCC DDDDDDDDD x10111111		SETVIDQ	D
    --L-			1111110 xx L CCCC DDDDDDDDD x11000000		SETPORA	D
    --L-			1111110 xx L CCCC DDDDDDDDD x11000001		SETPORB	D
    --L-			1111110 xx L CCCC DDDDDDDDD x11000010		SETPORC	D
    --L-			1111110 xx L CCCC DDDDDDDDD x11000011		SETPORD	D
    			<gap>
    ZC--			1111110 ZC x CCCC xxxxxxxxx x11100000		RETA
    ZC--			1111110 ZC x CCCC xxxxxxxxx x11100001		RETB
    ZC--			1111110 ZC x CCCC xxxxxxxxx x11100010		RETAD
    ZC--			1111110 ZC x CCCC xxxxxxxxx x11100011		RETBD
    ZC--			1111110 ZC x CCCC xxxxxxxxx x11100100		RETAR
    ZC--			1111110 ZC x CCCC xxxxxxxxx x11100101		RETBR
    ZC--			1111110 ZC x CCCC xxxxxxxxx x11100110		RETARD
    ZC--			1111110 ZC x CCCC xxxxxxxxx x11100111		RETBRD
    ZC--			1111110 ZC x CCCC xxxxxxxxx x11101000		TESTSPA
    ZC--			1111110 ZC x CCCC xxxxxxxxx x11101001		TESTSPB
    ZC--			1111110 ZC x CCCC xxxxxxxxx x11101010		POLCTRA				(CTRA rollover into !Z/C)
    ZC--			1111110 ZC x CCCC xxxxxxxxx x11101011		POLCTRB				(CTRB rollover into !Z/C)
    ZC--			1111110 ZC x CCCC xxxxxxxxx x11101100		POLVID				(VID ready into !Z/C)
    ----			1111110 xx x CCCC xxxxxxxxx x11101101		CAPCTRA
    ----			1111110 xx x CCCC xxxxxxxxx x11101110		CAPCTRB
    ----			1111110 xx x CCCC xxxxxxxxx x11101111		CAPCTRS
    ----			1111110 xx L CCCC xxxxxxxxx x11110000		CACHEX
    ----			1111110 xx L CCCC xxxxxxxxx x11110001		CLRACA
    ----			1111110 xx L CCCC xxxxxxxxx x11110010		CLRACB
    ----			1111110 xx L CCCC xxxxxxxxx x11110011		CLRACS
    ----			1111110 xx x CCCC xxxxxxxxx x11110100		SYNCTRA				(waits for ctra if single-task, loops if multi-task))
    ----			1111110 xx x CCCC xxxxxxxxx x11110101		SYNCTRB				(waits for ctrb if single-task, loops if multi-task))
    			<gap>
    ----			1111111 0n n nnnn nnnnnnnnn nnniiiiii		REPS	#n,#i
    ----			1111111 10 x BBAA DDDDDDDDD SSSSSSSSS		SETINDx	#D,#S			(SETINDA S   / SETINDB D   / SETINDS D,S)
    ----			1111111 11 x 0B0A DDDDDDDDD SSSSSSSSS		FIXINDx	#D,#S			(FIXINDA D,S / FIXINDB D,S / FIXINDS D,S)
    x = don't care, use 0
    Now I've got to change the Verilog and the assembler in PNUT to reflect this new map. This will take several days.
  • SapiehaSapieha Posts: 2,964
    edited 2013-10-16 02:42
    Hi Chip.
    Can't You attach that list as HELP in PNut?.
    I've been busy for the last few days reorganizing the op-code mapping and I think I've got it about done:
    --MS            1001110 11 I CCCC DDDDDDDDD SSSSSSSSS        SWBYTES    D,S            (switch/copy bytes in D, S = _10_01_00 = D same)
                <gap>
                <gap>
                <gap>
    Now I've got to change the Verilog to reflect this new map. This will take several days.
    edited 2013-10-16 02:59
    Sapieha wrote: »
    Hi Chip.
    That's a good idea. If I forget to do that when the next PNUT comes out, please remind me.
    edited 2013-10-16 03:03
    Hi Chip.
    Thanks.
  • SeairthSeairth Posts: 2,474
    edited 2013-10-16 04:08
    Nice reorganization! Out of curiosity, why did you leave those last few instructions at %1111111 instead of placing the extended instruction set (currently at %1111110) at the end? I'm not asking for it to switched, just curious if there's a technical reason for it.
    Edit: And for all our sake, get some sleep!
    edited 2013-10-16 04:15
    Seairth wrote: »
    I needed more bits than were available in the %1111110 set. Do you see a better way? I may not be thinking straight.
    Those last 3 instructions were real odd-balls, so I put them at the end. Everything before those three is pretty regular. Weirdos to the back of the bus!
    edited 2013-10-16 05:28
    Looks nice Chip! MIXPIX could be BLNDPIX maybe? or just have both with one being an alias.
    Couldn't ESWAP8 also be done with SWBYTES? Would free an instruction there. Could have an alias for ESWAP8 to the appropriate SWBYTES maybe?
    edited 2013-10-16 06:07
    Hi Roy.
    Stands not E in ESWAP8 for --- Edian?
    Roy Eltham wrote: »
    edited 2013-10-16 06:11
    Roy Eltham wrote: »
    Looking at Chip's notes it appears your right Roy. ESWAP8 is now obsolete!
    edited 2013-10-16 06:38
    Chip, you certainly have been busy. As others said, go get some sleep while we digest these.
    edited 2013-10-16 06:47
    May I make a suggestion Chip for a replacement for the now obsolete ESWAP8 instruction.
    In many PCB I/O layouts it quite common for pins to connected to dual row headers (0.1 inch for example).
    Most PCB layouts tend to fan-out the pins so that one side of the connector is odd numbered I/o and the other even.
    The F{GA boards are an example of this. P0,P2,P4 on one side and P1,P3,P5 the other.
    In a lot of cases it would be nice to use a group of pins on one side of the connector.
    My idea is a SPREAD instruction that does the following.
    SPREAD D,S
    where s = %11001 for example
    D would = %0101000001 after
    A simple shift could align to odd/even bits or maybe WC could be used to shift left 1 bit optionally.
    Basically the 9 bits of an immediate or the lower 16 bits of S are spread over 32 bits
    A reverse instruction SQUISH could do the opposite. Every 2nd bit is aligned to create a 16 bit result. WC could be used to grab odd/even bits.
    This would simplify/reduce code required to mask/modify IO pins.
    I figure it's just a basic MUX function?
    edited 2013-10-16 08:36
    Looks very good!
    Initial observations:
    - I am curious about what the 'R' stands for in {RD|WR}AUXR
    - I really like the niblle/byte/word moves and endian reversal
    			<gap>
    			<gap>
    			<gap>
    edited 2013-10-16 09:35
    ozpropdev wrote: »
    I second this suggestion, just so I can use "SQUISH" in my code!
    Actually, couldn't you do that with MERGEW and SPLITW?
    edited 2013-10-16 09:55
    There's also a CALLAR, CALLBR, CALLARD, and CALLBRD. Since STACK is now AUX, I think the "R" refers to "reverse" (like the old PUSHA[R] and POPA[R]). For the RDAUX/WRAUX operations, I'm guessing that the "R" is only differentiated from the non-"R" version when using SPA/SPB. Going out on a limb, I'm guessing SPA/SPB is used when the MSB of S-field is set (otherwise, it's an absolute offset between 0 and 255). However, why have the separate "R" version in that case? Couldn't the increment/decrement of SPA/SPB be encoded in the lower eight bits (similar to the INDA/INDB encoding)?
    Ok. Maybe I should wait until Chip clarifies. :)
    edited 2013-10-16 11:59
    Roy Eltham wrote: »
    ESWAP8 moves the value from S to D, whereas SWBYTES works on D using S. I'll leave them for now. There are plenty of opportunities for new instruction slots, if we need them.
