DE0-Nano and DE2-115 add-on boards for Prop2 emulation are ready! - Page 6 — Parallax Forums
12346»
  • RaymanRayman Posts: 15,962
    edited 2013-03-15 10:49
    David, you should have today an FPM module with the SST25VF32 chip on it, the 32Mbit version of that one...
    You can use the sample code here to program them:
    http://www.rayslogic.com/Propeller/Products/FlashPoint/FlashPoint.htm
    edited 2013-03-15 11:12
    Rayman wrote: »
    You're absolutely right! It arrived just now along with the QMP board I ordered. Thanks!!
    Doesn't your RamPage2 module also use this SST chip? If so, I already have code to talk to it.
    edited 2013-03-15 11:21
    RamPage2 uses different, SQI chips (but also Microchip, I think). Those let you program 256 bytes at a time, as I recall...
    edited 2013-03-15 11:25
    Rayman wrote: »
    Okay, I have some SST SPI flash code already as well. It's ifdefed in the spi_flash_cache.spin driver that is distributed with PropGCC. I'll have to check to see if it is for the same chip or at least compatible.
  • UntelUntel Posts: 27
    edited 2013-03-27 12:04
    I have used a DE2-115 FPGA boards (and interface board) for many month now and also propeller for many years. I just wonder if the add-on board is still available so I can I can collaborate to this forum. If so : How can I get one ?.
    Regards
  • SapiehaSapieha Posts: 2,964
    edited 2013-03-27 12:11
    Hi Untel.
    You need PM to Chip and ask.
    In other thread he said he still have them
    Untel wrote: »
    Regards
    edited 2013-03-27 12:25
    Hi Sapieha
    What is PM to Chip ?
    Regards
    edited 2013-03-27 12:30
    Hi Untel.
    http://forums.parallax.com/private.php
    PM - Private Massage ---- to ---- cgracey
    Untel wrote: »
    Hi Sapieha
    Regards
