The unofficial P2 documentation project - Page 9 — Parallax Forums
179111213
  • jmgjmg Posts: 15,194
    edited 2013-02-08 13:11
    .. any updates on the P2 Counters operations and details yet ?
    edited 2013-02-15 03:48
    I got a little ways into the counter documentation and realized that the DACs and video circuits needed explaining, too, because there is a lot of overlap among them.
    So, here is some new documentation:
    Prop2_Docs.txt
    The counter section is not done, but the DACs and video sections are, though the video section will get more example code to round it out. All the critical stuff is in there, anyway.
    Here is a picture of the sample program at the end of the doc file making some luma-graduated color bars on 1280x1024 VGA. The program that does this is very short:
    ''*  VGA 1280x1024  *
    ' P0 = HSYNC
    ' P1 = BLUE
    ' P2 = GREEN
    ' P3 = RED
    ' P4 = VSYNC
    CON
      _clkmode = xinput
      _xinfreq = 60_000_000
    DAT             org
                    reps    #64,#2                  'start 8-bit incrementing sequence at $BB
                    setspa  #$BB
                    pusha   luma
                    add     luma,lumad
                    setctra #%00111                 'set ctra for PLL*8
                    setfrqa frqa_                   'set frqa
                    setvid  #%0100                  'set vid for vga output
                    setvidy vidy_                   'set yiq coefficients
                    setvidi vidi_
                    setvidq vidq_
                    cfgdacs #%11_11_11_11           'set dacs to video mode
                    cfgpins pinmask,pindacs         'set pins for dac outputs
    ' Field loop
    field           mov     x,#38                   'top blanks
                    call    #blank
                    mov     y,lines_vis             'set visible lines
    line            call    #sync                   'do horizontal sync
                    waitvid mode,#0                 '1280 clocks per waitvid
                    djnz    y,#line                 'another line?
                    mov     x,#1                    'bottom blanks
                    call    #blank
                    setp    #4                      'do vertical sync
                    mov     x,#3
                    call    #blank
                    clrp    #4
                    jmp     #field                  'field loop
    blank           call    #sync                   'blank lines
                    waitvid v1280,sync_color0
                    djnz    x,#blank
    blank_ret       ret
    sync                                            'horizontal sync
    sync_ret        retd
                    waitvid v48,sync_color0
                    waitvid v112,sync_color1
                    waitvid v248,sync_color0
    ' Initialized data
    luma            long    $03020100
    lumad           long    $04040404
    frqa_           long    $3800_0000
    vidy_           long    $00_2C_00_00            'red gain
    vidi_           long    $00_00_2C_00            'green gain
    vidq_           long    $00_00_00_2C            'blue gain
    pinmask         long    %1111                   'pin mask for P0..P3
    pindacs         long    %1111_101100000         'pin configuration for video DAC
                    '       color base      mode            clocks/pixel    clocks/waitvid
    mode            long    $BB << 24 +     $A << 20 +      5 << 13 +       1280
    lines_vis       long    1024
    sync_color0     long    $0_000000
    sync_color1     long    $1_000000
    v48             long    48
    v112            long    112
    v248            long    248
    v1280           long    1280
    x               long    0
    y               long    0
    640 x 360 - 61K
  • TubularTubular Posts: 4,766
    edited 2013-02-15 07:36
    Thanks, Chip. Wow, that's a mighty impressive update. There goes my weekend!...
    edited 2013-02-15 07:46
    Do we have an estimate on when the DAC adapter boards will be available?
    edited 2013-02-15 08:17
    Thanks Chip - GREAT update, now I have a lot to chew on...
  • SeairthSeairth Posts: 2,474
    edited 2013-02-15 08:56
    I think I understand all of this code except:
    Based on the intervals, this is running the screen refresh rate at 60Hz. But between the _xinfreq and the CTRA output, I can't seem to get numbers (e.g pixel frequency of 108MHz) that match what I'm expecting for 1280x1024@60Hz. Can someone spell it out for me?
    Can you clarify the clocks/pixel field in the mode value? I thought the dot clock was the same as the pixel clock, so this is confusing me. Something to do with the DAC, maybe?
    edited 2013-02-15 09:20
    Seairth wrote: »
    Oh, wait. I think I just figured this out. The stack contains only 256 pixel values (64 registers * 4 8-bit pixel values), but outputting 1280 pixels. So the clocks/pixel means "repeat each pixel for X clocks".
    edited 2013-02-15 10:52
    Seairth wrote: »
    That's right. Each pixel is repeated for 5 clocks, making 256 pixels over 1280 clocks.
    About FRQA being $3800_0000... At 60MHz, $8000_0000 would result in a 30MHz PHSA rollover. So, $3800_0000/$8000_0000 would result in 13.125MHz rollover. With the PLL multiplying it 8 times, you'd get 105MHz for the VID dot clock. It's not 108MHz, but close enough. $3800_0000 is a good value, since there are only three contiguous set bits, which the PLL can digest pretty well without noticeable "birdies" appearing in the output, causing pixel positions to shift slightly to and fro on the monitor.
    edited 2013-02-15 11:56
    potatohead wrote: »
    I just got the latest rev's yesterday. The DE0-Nano board was used in the video example above. I need to do some quick checks and give the go-ahead to build both boards up so we can send them out to you guys.
    edited 2013-02-15 12:14
    Looking forward to it.
    edited 2013-02-15 13:54
    I just finished testing both of the latest DE0-Nano and DE2-115 add-on boards and they look perfect now, so we will build them and send them out next week.
    edited 2013-02-15 14:06
    That's great! I know everyone else wants to do video but I'm looking forward to being able to boot from SPI flash and start work on XMM mode.
    edited 2013-02-15 15:08
    Excellent news!
    edited 2013-02-15 16:26
    (edited)
    XMM mode is a big deal David! That's not an area where I think my skills match up well, but I'm pretty excited about the prospect of running large programs faster on P2.
  • Ym2413aYm2413a Posts: 630
    edited 2013-02-16 13:42
    I love the new method of handling video on this chip. : ]
    I scanned over the document twice to make sure I wrapped my brain around it.
    I'm excited for the 8-bit mode with the 2+8+8+8 CLUT.
  • roglohrogloh Posts: 6,194
    edited 2013-02-16 18:10
    Totally agree with that Ym2413a. The video methods look fantastic, and the new streaming model will certainly allow a major performance boost for higher resolutions and free more COGs. Great design work!
    One related question I have for Chip is whether we really have a RGBI nibble format or IRGB in STR4_RGBI4? From the latest documentation:
    %1000 = STR4_RGBI4    - 4-bit pixels are streamed from stack RAM starting at %AAAAAAAA
                                plus S[7:0], with S[31..29] selecting the starting nibble. The
                                pixels are colored as:
                                %0000 = black
                                %0001 = dark grey
                                %0010 = dark blue
                                %0011 = bright blue
                                %0100 = dark green
                                %0101 = bright green
                                %0110 = dark cyan
                                %0111 = bright cyan
                                %1000 = dark red
                                %1001 = bright red
                                %1010 = dark magenta
                                %1011 = bright magenta
                                %1100 = olive
                                %1101 = yellow
                                %1110 = light grey
                                %1111 = white
    This documentation shows the RGBI nibble format, but I was wondering why it was encoded like this if standards such as CGA used the latter. Was the difference arbitrary/intentional? Was only wondering if this will mean some extra translation may be required for 16 color bitmaps exported from the PC etc...? I suspect it just doesn't matter much in the end as CGA is so ancient these days and we have bit shift instructions if we need them and 16 bit color will probably be more useful for text modes than bitmaps. It just stood out when I looked a the order of the colors in this list and saw them in this particular sequence which is different to how I remembered the PC's colors back in the day which had the msb of the nibble as the intensity bit IIRC.
    Cheers,
    Roger.
    edited 2013-02-16 21:14
    rogloh wrote: »
                                %0000 = black
                                %0001 = dark grey
                                %0010 = dark blue
                                %0011 = bright blue
                                %0100 = dark green
                                %0110 = dark cyan
                                %0111 = bright cyan
                                %1000 = dark red
                                %1001 = bright red
                                %1100 = olive
                                %1101 = yellow
                                %1110 = light grey
                                %1111 = white
    Cheers,
    Roger.
    My mistake, sort of. I meant to replicate the old VGA color palette, but I put the intensity bit in the LSB, not the MSB. I think I might have done that because in other similar modes on the Prop2, the intensity bits were always in the LSB's, so that they could be masked in more simply in software. Oh, well...
    edited 2013-02-16 21:35
    Thanks for the explanation Chip. Don't think it is going to be too much of a dealbreaker. :smile: Can't wait for the final device to come out to try out with some higher resolutions/color depths and external SRAM.
    edited 2013-02-16 23:08
    Yeah no deal breaker at all. : ]
    I prefer the consistency between all modes.
  • BEEPBEEP Posts: 58
    edited 2013-02-17 05:30
    Prop2_Docs.txt to Prop2_Docs.pdf
    (deleted)
    edited 2013-02-17 11:38
    Thanks for that.
    edited 2013-02-17 19:48
    Thanks BEEP. : ]
    Looks good and is a lot easier to read.
    edited 2013-02-18 04:50
    Some minor fixes
    Edit: File deleted.
    edited 2013-03-28 16:39
    --- file deleted ---
    edited 2013-04-12 10:28
    Has anyone else had performance issues with Google Docs? It had become very slow for me and is nearly impossible to open the files on anything other than a desktop/laptop. I would still like to work on a centralized reference, but not in GDocs. Thoughts?
    edited 2013-04-12 14:58
    I can promote you to wiki organizer. That system is simple. Just a thought.
    Propeller.wiki spaces.com
    edited 2013-04-12 15:35
    potatohead wrote: »
    We'd lose the simultaneous edit ability, but gain more flexible organization. I'm fine with that. Is Chip/Parallax ok with us using the wiki?
  • pedwardpedward Posts: 1,642
    edited 2013-04-12 15:53
    The Google docs are getting hard to use, I'm constantly bouncing around between new instructions and wanting for the layout of the propeller book.
    edited 2013-04-12 16:13
    I have real trouble with the G-docs too.
  • CircuitsoftCircuitsoft Posts: 1,166
    edited 2013-04-15 18:27
    A while ago, I downloaded the current state of the doc, and began converting it to LyX. Once I finish, I intend to update the original to the latest again, apply the changes, then post it here. So far, the output is pretty nice.
