Bresenham's line algorithm - ( Stepper motor pre-requisite )
Here is the first part of a navigation and plotting idea i have for my $20 robot series using stepper motors.
(and drive my mini etch-a-sketch board)
Goal :-
Get from x1,y1 to x2,y2 ........ a straight line ...... in an efficient way.
Solution :-
Bresenhams line algorithm
The code idea came after reading a Wiki article :- http://en.wikipedia.org/wiki/Bresenham%27s_line_algorithm
It was almost a cut and paste deal.....with tweaking to convert to Spin code.
This is a basic way to move an xy plotter - laser cutter - cnc from point to point......
The code that follows below draws a simple "dot to dot" straight line to a TV display (tnx Chip Gracey) .
I will be using this "dot to dot" approach to send steps to my stepper motors...
I hope this code helps anyone searching a start into XY plotting physical devises.
Program :-
Update 20130120 :-
Slimlined call routine.....( & removed annoying "quit" from loop command tsktsktsk)
Update 20130122 :-
From theory into practise.
Mechanics and resulting software generated lines .
(albeit plauged with backlash from cheap etchAsketch...however you can see its leaning in the right direction)
![IMG_0952[1].JPG](https://forums.parallax.com/uploads/attachments/63065/95666.jpg)
![IMG_0953[1].JPG](https://forums.parallax.com/uploads/attachments/63065/95667.jpg)
Data set for the 16 magic lines :-
Update 20130125 :-
Getting to grips with sin and cos :-
LCD screen for theory and >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>VVV for EAS reality
Spirals are taking shape.....
Astute readers will notice a CW - CCW error in my coding.
(not sure if its an error with lcd code or stepper code yet, it will "Iron out" when i start scaling the routines down )
Spiral code (first attempt) :-
Update 20130130 :-
Now plotting epicycloids :-
and Hypocycloids :-
And Etch-A-Sketch driven by the code :-
Why do i use and need drawing routines......
Well...... its not only the start and stop coordinates i am interested in....... i need to know also the "In-betweens" for stepper motor control.
also :- calculating 360 points for a circle (with sin cos ) can be very time consuming ..when you could do it instead with 36 points and just join the dot2dots.
Goal :-
Solution :-
Program :-
{{ ┌───────────────────────────────────────────┐ │ Bresenham's line algorithm │ │ Plotting a line between points │ │ ie ( x1,y1 - x2,y2 ) │ │ Demo Code : Gareth │ │ aka Youtube :- Chiprobot │ │ Graphics by Chip Gracey (Parallax) │ └───────────────────────────────────────────┘}} CON _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 _stack = ($3000 + $3000 + 100) >> 2 'accomodate display memory and stack x_tiles = 16 y_tiles = 12 paramcount = 14 bitmap_base = $2000 display_base = $5000 lines = 5 thickness = 2 mode = 1 VAR long tv_status '0/1/2 = off/visible/invisible read-only long tv_enable '0/? = off/on write-only long tv_pins '%ppmmm = pins write-only long tv_mode '%ccinp = chroma,interlace,ntsc/pal,swap write-only long tv_screen 'pointer to screen (words) write-only long tv_colors 'pointer to colors (longs) write-only long tv_hc 'horizontal cells write-only long tv_vc 'vertical cells write-only long tv_hx 'horizontal cell expansion write-only long tv_vx 'vertical cell expansion write-only long tv_ho 'horizontal offset write-only long tv_vo 'vertical offset write-only long tv_broadcast 'broadcast frequency (Hz) write-only long tv_auralcog 'aural fm cog write-only word screen[x_tiles * y_tiles] long colors[15] OBJ tv : "tv.spin" ' by Chip Gracey (Parallax) gr : "Graphics.spin" ' by Chip Gracey (Parallax) PUB start | i, j, dx, dy '*********** GRAPHICS SETUP ******************** 'start tv longmove(@tv_status, @tvparams, paramcount) tv_screen := @screen tv_colors := @colors tv.start(@tv_status) 'init colors repeat i from 0 to 15 colors[i] := $00001010 * (i+4) & $F + $2B060C02 ' 0=black ' 1=Crazy rainbow ' 2=white ' 3=blue 'init tile screen repeat dx from 0 to tv_hc - 1 repeat dy from 0 to tv_vc - 1 screen[dy * tv_hc + dx] := display_base >> 6 + dy + dx * tv_vc + ((dy & $3F) << 10) 'start and setup graphics gr.start gr.setup(16, 12, 0, 0, bitmap_base) {{ ┌───────────────────────────────────────────────────────────┐ │ Bresenham's line algorithm │ │ Transcribed from :- │ │ http://en.wikipedia.org/wiki/Bresenham%27s_line_algorithm │ └───────────────────────────────────────────────────────────┘ }} gr.colorwidth(1,1) ' crazy thin rainbow line colour drawline ( 585,493,124,158) drawline ( 124, 158,300,700) drawline ( 300,700,476,158) drawline ( 476,158,15, 493) drawline ( 15, 493,585, 493) pub drawline(x1, y1, x2, y2) | sx,sy,ddx,ddy,err,e2,colour x1:=x1/4 ' scale the coords to fit screen x2:=x2/4 y1:=y1/4 y2:=y2/4 ddx := ||(x2-x1) ' "||" = ABS(x2-x1) ie force any negative result to positive ddy := ||(y2-y1) if (x1 < x2) sx := 1 else sx := -1 if (y1 < y2) sy := 1 else sy := -1 err := ddx-ddy repeat gr.plot(x1,y1) gr.copy(display_base) if ((x1 == x2) AND ( y1 == y2)) quit e2 := 2*err if e2 > -ddy err := err - ddy x1 := x1 + sx if e2 < ddx err := err + ddx y1 := y1 + sy DAT tvparams long 0 'status long 1 'enable long %001_0101 'pins caution>>> set up to your graphic pin outputs long %0000 'mode long 0 'screen long 0 'colors long x_tiles 'hc long y_tiles 'vc long 10 'hx long 1 'vx long 0 'ho long 0 'vo long 0 'broadcast long 0 'auralcog {{ ┌──────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────┐ │ TERMS OF USE: MIT License │ ├──────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────┤ │Permission is hereby granted, free of charge, to any person obtaining a copy of this software and associated documentation │ │files (the "Software"), to deal in the Software without restriction, including without limitation the rights to use, copy, │ │modify, merge, publish, distribute, sublicense, and/or sell copies of the Software, and to permit persons to whom the Software│ │is furnished to do so, subject to the following conditions: │ │ │ │The above copyright notice and this permission notice shall be included in all copies or substantial portions of the Software.│ │ │ │THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE │ │WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR │ │COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, │ │ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE. │ └──────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────┘ }}
Update 20130120 :-
{{ ┌───────────────────────────────────────────────────────────┐ │ Bresenham's line algorithm │ │ Transcribed from :- │ │ http://en.wikipedia.org/wiki/Bresenham%27s_line_algorithm │ └───────────────────────────────────────────────────────────┘ }} gr.colorwidth(1,1) ' crazy thin rainbow line colour drawline (112,100, 25, 50) drawline ( 25, 50, 62,125) drawline ( 62,125,100, 50) drawline (100, 50, 12,100) drawline ( 12,100,112,100) pub drawline(x1, y1, x2, y2) | sx,sy,ddx,ddy,err,e2 ddx := ||(x2-x1) ' "||" = ABS(x2-x1) ie force any negative result to positive ddy := ||(y2-y1) err := ddx-ddy sx := -1 if (x1 < x2) sx := 1 sy := -1 if (y1 < y2) sy := 1 repeat until ((x1 == x2) AND ( y1 == y2)) ' origin has wandered to its goal YAY...better stop gr.plot(x1,y1) gr.copy(display_base) e2 := 2*err if e2 > -ddy err := err - ddy x1 := x1 + sx if e2 < ddx err := err + ddx y1 := y1 + sy
Update 20130122 :-
' U=Up D=Down R=Right L=Left RL=draw line from Right to Left ' the 1,0,-1 are for my reference and i have used them to filter the steppers up down right left movements. drawline (0,0,0,250) ' -1 1 0 -1 line U drawline (0,250,0,0) ' -1 -1 0 -1 line D drawline (250,0,0,0) ' -1 -1 -1 0 line RL drawline (0,0,250,0) ' 1 -1 -1 0 line LR drawline (0,0,250,250)' 1 1 -1 -1 line UR drawline (250,250,0,0)' -1 -1 -1 -1 line DL drawline (0,250,250,0)' 1 -1 -1 -1 line DR drawline (250,0,0,250)' -1 1 -1 -1 line UL drawline (0,0,100,300)' 1 1 -1 -1 1 1 0 -1 line UR steep drawline (100,300,0,0)' -1 -1 -1 -1 -1 -1 0 -1 line DL steep drawline (0,300,100,0)' 1 -1 -1 -1 1 -1 0 -1 line DR steep drawline (100,0,0,300)' -1 1 -1 -1 -1 1 0 -1 line UL steep drawline (0,0,300,100)' 1 1 -1 0 1 1 -1 -1 line UR shallow drawline (300,100,0,0)' -1 -1 -1 -1 -1 -1 -1 0 line DL shallow drawline (300,0,0,100)' -1 1 -1 0 -1 1 -1 -1 line UL shallow drawline (0,100,300,0)' 1 -1 -1 -1 1 -1 -1 0 line DR shallow
Update 20130125 :-
circles := 10 'starting spiral size repeat Steps from -180 to 180 step 1 ' Integer PI step values ie choose 360 points xx2:= 500+f32.FTrunc(fx) ' this preserves the old X,Y end plot ... to be then used as origin of the next new line. yy2:= 400+f32.FTrunc(fy) fx := f32.FFloat( Steps ) ' convert integer Pie (numnumnum) to FloatingPoint Pie circleFloat := f32.FFloat(circles) ' convert integer circle to FloatingPoint circle fy := fx ' duplicate value for Cos bit fx := f32.FMul( fx, constant( pi / 30.0 ) ) ' Scale to actual PI values fx := f32.FMul( f32.sin( fx ), circleFloat ) ' calculate Sin(fx)* circle size fy := f32.FMul( fy, constant( pi / 30.0 ) ) ' Scale to actual PI values fy := f32.FMul( f32.cos( fy ), circleFloat ) ' calculate Cos(fy)* circle size xx1:=500+f32.FTrunc(fx) yy1:=400+f32.FTrunc(fy) drawline(xx1/5,yy1/5,xx2/5,yy2/5) circles++
Update 20130130 :-
and Hypocycloids :-
My first idea is just to send the step pulses direct from the algorithm to allow for straight line , it should work (not forgetting i have to work out the orientation of robot to get to next waypoint).... there still much "to do"
The class of algorithms like Bressenhams are know as DDA (digital differential analysers - named by analogy (!) with analog computers I believe).
The basic trick is also know as coherence - any calculation that is done repetitively using a step variable can be reduced in order. Thus in BLA
each step to the next line only involves addition/subtraction instead of multiplication or division as the naive geometric approach would use.
Similarly Bressenham's circle algorithm replaces square-root calculations with 2 addition/subtractions as you step from one point to the next.
Consider the pseudo-code You can replace this by
Another way to think of this is to express the higher order operation recursively: And as you step the variable you compute the (say) square in lock-step using the recursive relation - typically extra state has to be maintained.
What i have noticed with this methode is that no artifacts (holes in the line) appear ... its one continous flow....the next pixel is always adjacent.
.... here is just some screen test outputs which will be confirmed with and Etch-A-Sketch pad driven by stepper.
There appears to be only 14 combinations to draw a connecting dot2dot line......
Heck, everything works in a simulation! Robotics is real-world with all it's ugly little singularities, but you know that, Gareth!
Please dont ask me to explain this yet .... it took me all evening and it does give me XY forward/reverse step instructions for both steppers :-
The Magic 14 (i hope only 14) ways to draw continuous dot2dot lines.
drawline (0,0,0,50) ' -1 1 0 -1
drawline (50,0,0,0) ' -1 -1 -1 0
drawline (0,0,50,0) ' 1 -1 -1 0
drawline (0,50,0,0) ' -1 -1 0 -1
drawline (0,0,50,50) ' 1 1 -1 -1
drawline (50,50,0,0) ' -1 -1 -1 -1
drawline (0,50,50,0) ' 1 -1 -1 -1
drawline (50,0,0,50) ' -1 1 -1 -1
drawline (0,0,60,90) ' 1 1 -1 -1 & 1 1 0 -1
drawline (60,90,0,0) ' -1 -1 -1 -1 & -1 -1 0 -1
drawline (0,90,60,0) ' 1 -1 -1 -1 & 1 -1 0 -1
drawline (60,0,0,90) ' -1 1 -1 -1 & -1 1 0 -1
drawline (0,0,90,60) ' 1 1 -1 0 & 1 1 -1 -1
drawline (90,0,0,60) ' -1 1 -1 0 & -1 1 -1 -1
They are programmed in however i cant see any patterns in the data to create a simple formular from the above data.....(it is there ... i just cant see it)
The first observation is that the sign of each step can be factored out at the start - for a given straight line segment
the sign of the steps in x and y can be recorded at the start, and the x and y deltas made all positive.
Then during the loop you progress the major axis every time and the minor axis whenever the test succeeds, so
the cases are
step major only
step major and minor together.
So 2 cases
It needs a wrapper for the other 7 octants. I didn't try to work that out, but it would be similar to the Bresenham wrapper.
The wrapper is implemented now in lineAlgorithm3.spin
This is a very-much stripped-down version, but it gives the flavor of the dynamics involved. The variable veloc can be varied during the course of the movement to accommodate ramping. It should always be less than or equal to MAX_VELOCITY.
A sign method is pretty simple to write:
This works because conditionals, when true, return -1.
Here are the nuts and bolts of the first stage........
The magic 16 lines ........ however there is some backlash on my "etch a sketch" ....(i have a way to eliminate it though ..stay tuned)
17 boxes drawn in a loop.
There is some rounding of the corners.......i have to tweak the software deadband control.
Bottom left is the origin ..... you can see an issue with the aluminium powder clogging up.
So if you take the axel direction that is the longest and make that speed: 1.0 (max stepper speed)
And the shorter get it's value to be calculated to be 0.246 etc, that you use for it's accumulator.
If you keep adding to the counters, both will move close to a analog fashion and they should end up at the end position at the same time.
Im a missing something?
Well if you ignore friction, non-uniform machining of motor pole step-grooves, eccentric alignment of axle, electrical
phase difference between A and B not being exactly 90 electrical degrees, non-perfect matching of drive currents in the
two windings, then yes, unlimited precision
http://hektor.ch/Videos/
Heres my first attempt at Circles......
Now with Formula driven code...
fx := f32.FMul( fx, constant( pi / 180.0 ) )
fy := f32.FMul( fy, constant( pi / 180.0 ) )
Would it qualify for entry into your "Oval" challenge if i squash them a tad .
You know tonyp12, what you are describing is also lingering in my cortex and somehow, some way, this is what i sincerely hope will happen. (just as soon as I transfer the coding to a propeller stepper enabled robi)
Plan B is to devise (a dead reckoning compass) deal (its another long shot)..
Throw a sun dial on that EAS and put it in a museum!
fx := f32.FMul( fx, constant( pi / 45.0 ) ) ' Scale to actual PI values
fy := f32.FMul( fy, constant( pi / 180.0 ) ) ' Scale to actual PI values
