Bresenham's line algorithm - ( Stepper motor pre-requisite ) — Parallax Forums
GarethGareth Posts: 278
edited 2013-03-05 01:54 in General Discussion
Here is the first part of a navigation and plotting idea i have for my $20 robot series using stepper motors.
(and drive my mini etch-a-sketch board)
Goal :-
Get from x1,y1 to x2,y2 ........ a straight line ...... in an efficient way.
Solution :-
Bresenhams line algorithm
The code idea came after reading a Wiki article :- http://en.wikipedia.org/wiki/Bresenham%27s_line_algorithm
It was almost a cut and paste deal.....with tweaking to convert to Spin code.
This is a basic way to move an xy plotter - laser cutter - cnc from point to point......
The code that follows below draws a simple "dot to dot" straight line to a TV display (tnx Chip Gracey) .
I will be using this "dot to dot" approach to send steps to my stepper motors...
I hope this code helps anyone searching a start into XY plotting physical devises.
Program :-
    │        Bresenham's line algorithm         │
    │      Plotting a line between points       │
    │           ie ( x1,y1 - x2,y2 )            │
    │ Demo Code : Gareth                        │
    │ aka Youtube :- Chiprobot                  │
    │ Graphics  by Chip Gracey (Parallax)       │
CON
  _clkmode = xtal1 + pll16x
  _xinfreq = 5_000_000
  _stack = ($3000 + $3000 + 100) >> 2   'accomodate display memory and stack
  x_tiles = 16
  y_tiles = 12
  paramcount = 14
  bitmap_base = $2000
  display_base = $5000
  lines = 5
  thickness = 2
  mode = 1
VAR
    long  tv_status     '0/1/2 = off/visible/invisible           read-only
  long  tv_enable     '0/? = off/on                            write-only
  long  tv_pins       '%ppmmm = pins                           write-only
  long  tv_mode       '%ccinp = chroma,interlace,ntsc/pal,swap write-only
  long  tv_screen     'pointer to screen (words)               write-only
  long  tv_colors     'pointer to colors (longs)               write-only
  long  tv_hc         'horizontal cells                        write-only
  long  tv_vc         'vertical cells                          write-only
  long  tv_hx         'horizontal cell expansion               write-only
  long  tv_vx         'vertical cell expansion                 write-only
  long  tv_ho         'horizontal offset                       write-only
  long  tv_vo         'vertical offset                         write-only
  long  tv_broadcast  'broadcast frequency (Hz)                write-only
  long  tv_auralcog   'aural fm cog                            write-only
  word  screen[x_tiles * y_tiles]
  long  colors[15]
OBJ
  tv    : "tv.spin"          ' by Chip Gracey (Parallax)
  gr    : "Graphics.spin"    ' by Chip Gracey (Parallax)
PUB start | i, j, dx, dy
  '*********** GRAPHICS SETUP ********************
  'start tv
  longmove(@tv_status, @tvparams, paramcount)
  tv_screen := @screen
  tv_colors := @colors
  tv.start(@tv_status)
   'init colors
  repeat i from 0 to 15
    colors[i] := $00001010 * (i+4) & $F + $2B060C02
  '   0=black   '   1=Crazy rainbow  '   2=white   '   3=blue       'init tile screen
  repeat dx from 0 to tv_hc - 1
    repeat dy from 0 to tv_vc - 1
      screen[dy * tv_hc + dx] := display_base >> 6 + dy + dx * tv_vc + ((dy & $3F) << 10)
  'start and setup graphics
  gr.start
  gr.setup(16, 12, 0, 0, bitmap_base)
{{  &#9484;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9488;
    &#9474;              Bresenham's line algorithm                   &#9474;
    &#9474;                  Transcribed from :-                      &#9474;
    &#9474; http://en.wikipedia.org/wiki/Bresenham%27s_line_algorithm &#9474;
    &#9492;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9496; }}
  gr.colorwidth(1,1)     ' crazy thin rainbow line colour
  drawline ( 585,493,124,158)
  drawline ( 124, 158,300,700)
  drawline ( 300,700,476,158)
  drawline ( 476,158,15, 493)
  drawline ( 15, 493,585, 493)
pub drawline(x1, y1, x2, y2) | sx,sy,ddx,ddy,err,e2,colour
  x1:=x1/4     ' scale the coords to fit screen
  x2:=x2/4
  y1:=y1/4
  y2:=y2/4
  ddx := ||(x2-x1)       '  "||" = ABS(x2-x1)  ie force any negative result to positive
  ddy := ||(y2-y1)
     if (x1 < x2)
       sx := 1
     else
      sx := -1
     if (y1 < y2)
       sy := 1
     else
      sy := -1
   err := ddx-ddy
   repeat
      gr.plot(x1,y1)
      gr.copy(display_base)
       if ((x1 == x2) AND ( y1 == y2))
         quit
      e2 := 2*err
       if e2 > -ddy
         err := err - ddy
         x1 := x1 + sx
       if e2 < ddx
         err := err + ddx
         y1 := y1 + sy
DAT
tvparams                long    0               'status
                        long    1               'enable
                        long    %001_0101       'pins  caution>>> set up to your graphic pin outputs
                        long    %0000           'mode
                        long    0               'screen
                        long    0               'colors
                        long    x_tiles         'hc
                        long    y_tiles         'vc
                        long    10             'hx
                        long    1               'vx
                        long    0               'ho
                        long    0               'vo
                        long    0               'broadcast
                        long    0               'auralcog
&#9484;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9488;
&#9474;                                                   TERMS OF USE: MIT License                                                  &#9474;
&#9500;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9508;
&#9474;Permission is hereby granted, free of charge, to any person obtaining a copy of this software and associated documentation    &#9474;
&#9474;files (the "Software"), to deal in the Software without restriction, including without limitation the rights to use, copy,    &#9474;
&#9474;modify, merge, publish, distribute, sublicense, and/or sell copies of the Software, and to permit persons to whom the Software&#9474;
&#9474;is furnished to do so, subject to the following conditions:        &#9474;
&#9474;        &#9474;
&#9474;The above copyright notice and this permission notice shall be included in all copies or substantial portions of the Software.&#9474;
&#9474;        &#9474;
&#9474;THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE          &#9474;
&#9474;WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR         &#9474;
&#9474;COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE,   &#9474;
&#9474;ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.                         &#9474;
&#9492;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9496;
Update 20130120 :-
Slimlined call routine.....( & removed annoying "quit" from loop command tsktsktsk)
  drawline (112,100, 25, 50)
  drawline ( 25, 50, 62,125)
  drawline ( 62,125,100, 50)
  drawline (100, 50, 12,100)
  drawline ( 12,100,112,100)
  ddy := ||(y2-y1)
  err := ddx-ddy
       sx := -1
   if (x1 < x2)
       sx := 1
       sy := -1
   if (y1 < y2)
       sy := 1
   repeat until ((x1 == x2) AND ( y1 == y2))  '  origin has wandered to its goal YAY...better stop
      gr.plot(x1,y1)
      e2 := 2*err
       if e2 > -ddy
         err := err - ddy
         x1 := x1 + sx
       if e2 < ddx
         err := err + ddx
         y1 := y1 + sy
Update 20130122 :-
From theory into practise.
Mechanics and resulting software generated lines .
(albeit plauged with backlash from cheap etchAsketch...however you can see its leaning in the right direction)
Data set for the 16 magic lines :-
'  U=Up  D=Down R=Right L=Left        RL=draw line from Right to Left
' the 1,0,-1 are for my reference and i have used them to filter the steppers up down right left movements.
drawline (0,0,0,250)  ' -1  1  0 -1                line U
drawline (0,250,0,0)  ' -1 -1  0 -1                line D
drawline (250,0,0,0)  ' -1 -1 -1  0                line RL
drawline (0,0,250,0)  '  1 -1 -1  0                line LR
drawline (0,0,250,250)'  1  1 -1 -1                line UR
drawline (250,250,0,0)' -1 -1 -1 -1                line DL
drawline (0,250,250,0)'  1 -1 -1 -1                line DR
drawline (250,0,0,250)' -1  1 -1 -1                line UL
drawline (0,0,100,300)'  1  1 -1 -1    1  1  0 -1  line UR steep
drawline (100,300,0,0)' -1 -1 -1 -1   -1 -1  0 -1  line DL steep
drawline (0,300,100,0)'  1 -1 -1 -1    1 -1  0 -1  line DR steep
drawline (100,0,0,300)' -1  1 -1 -1   -1  1  0 -1  line UL steep
drawline (0,0,300,100)'  1  1 -1  0    1  1 -1 -1  line UR shallow
drawline (300,100,0,0)' -1 -1 -1 -1   -1 -1 -1  0  line DL shallow
drawline (300,0,0,100)' -1  1 -1  0   -1  1 -1 -1  line UL shallow
drawline (0,100,300,0)'  1 -1 -1 -1    1 -1 -1  0  line DR shallow
Update 20130125 :-
Getting to grips with sin and cos :-
LCD screen for theory and >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>VVV for EAS reality
Spirals are taking shape.....
Astute readers will notice a CW - CCW error in my coding.
(not sure if its an error with lcd code or stepper code yet, it will "Iron out" when i start scaling the routines down )
Spiral code (first attempt) :-
circles := 10      'starting spiral size
 repeat Steps from -180 to 180  step 1 ' Integer PI step values ie choose 360 points
      xx2:= 500+f32.FTrunc(fx)     ' this preserves the old X,Y end plot ... to be then used as origin of the next new line.
      yy2:= 400+f32.FTrunc(fy)
      fx := f32.FFloat( Steps )        '  convert integer Pie (numnumnum) to FloatingPoint Pie
      circleFloat := f32.FFloat(circles) '  convert integer circle to FloatingPoint circle
      fy := fx                       '  duplicate value for Cos bit
      fx := f32.FMul( fx, constant( pi / 30.0 ) )     ' Scale to actual PI values
      fx := f32.FMul( f32.sin( fx ), circleFloat )     ' calculate Sin(fx)* circle size
      fy := f32.FMul( fy, constant( pi / 30.0 ) )     ' Scale to actual PI values
      fy := f32.FMul( f32.cos( fy ), circleFloat )     ' calculate Cos(fy)* circle size
         xx1:=500+f32.FTrunc(fx)
         yy1:=400+f32.FTrunc(fy)
      drawline(xx1/5,yy1/5,xx2/5,yy2/5)
    circles++
Update 20130130 :-
Now plotting epicycloids :-
and Hypocycloids :-
And Etch-A-Sketch driven by the code :-
Why do i use and need drawing routines......
Well...... its not only the start and stop coordinates i am interested in....... i need to know also the "In-betweens" for stepper motor control.
also :- calculating 360 points for a circle (with sin cos ) can be very time consuming ..when you could do it instead with 36 points and just join the dot2dots.
640 x 480 - 117K
640 x 480 - 123K
640 x 480 - 170K
640 x 480 - 143K
640 x 480 - 122K
640 x 480 - 156K
640 x 480 - 78K
640 x 480 - 137K
640 x 480 - 82K
«13
    edited 2013-01-19 10:31
    The Breshenham line algo (BLA) provides the "where" for the next movement, but not the "when." For physical motion, you want the acceleration and velocity of each stepper motor to be a smooth function of time. Otherwise, the motors will experience "cogging" and lose steps. So, in addition to the "where" provided by the BLA, you will have to come up with some way to pace the transitions in such a way that the motors run smoothly.
  • GarethGareth Posts: 278
    edited 2013-01-19 10:48
    Thanks and appreciated ..... i dont think my $3 dollar steppers could cope with your two parameters above. :-)
    My first idea is just to send the step pulses direct from the algorithm to allow for straight line , it should work (not forgetting i have to work out the orientation of robot to get to next waypoint).... there still much "to do"
  • Mark_TMark_T Posts: 1,981
    edited 2013-01-19 14:00
    If you look at the firmware for the RepRap (Mandel version) it has a DDA driving four axes and speed as a pseudo-axis (thus allowing acceleration).
    The class of algorithms like Bressenhams are know as DDA (digital differential analysers - named by analogy (!) with analog computers I believe).
    The basic trick is also know as coherence - any calculation that is done repetitively using a step variable can be reduced in order. Thus in BLA
    each step to the next line only involves addition/subtraction instead of multiplication or division as the naive geometric approach would use.
    Similarly Bressenham's circle algorithm replaces square-root calculations with 2 addition/subtractions as you step from one point to the next.
    Consider the pseudo-code
      for i = 0 to 10
        print i * 7
    You can replace this by
      product = 0
      for i = 0 to 10
        print product
        product = product+7    // an addition here maintains the product without having to multiply
    Another way to think of this is to express the higher order operation recursively:
       define mult_by_7 (i+1) = mult_by_7 (i) + 7
      define  square (i+1) = square (i) + 2i + 1
    And as you step the variable you compute the (say) square in lock-step using the recursive relation - typically extra state has to be maintained.
    edited 2013-01-19 14:49
    My kinda algorithm and thread ! I'll be digging into this stuff for several straight-line projects in progress: an indoor dead reckoning bot that keeps track of where it has been driven, then automatically returns to home position in a straight line, and an outdoor GPS RoboMagellan bot travelling between waypoints.
    edited 2013-01-20 07:43
    Mark_T wrote: »
    What i have noticed with this methode is that no artifacts (holes in the line) appear ... its one continous flow....the next pixel is always adjacent.
    edited 2013-01-20 07:47
    My kinda algorithm .
    erco .... one reason why i dived into this code was to draw spirals and ovals :innocent:, i figured having a kind of XY canvas would be first step.
    edited 2013-01-21 13:55
    My Stepper motor driver protocol appears to be of Alien origin ........
    .... here is just some screen test outputs which will be confirmed with and Etch-A-Sketch pad driven by stepper.
    There appears to be only 14 combinations to draw a connecting dot2dot line......
    640 x 480 - 115K
    edited 2013-01-21 14:25
    SCREEN TEST?
    Heck, everything works in a simulation! Robotics is real-world with all it's ugly little singularities, but you know that, Gareth!
    edited 2013-01-21 14:57
    Yes 1,0,-1 are the ugly ones ....
    Please dont ask me to explain this yet .... it took me all evening and it does give me XY forward/reverse step instructions for both steppers :-
    The Magic 14 (i hope only 14) ways to draw continuous dot2dot lines.
    drawline (0,0,0,50) ' -1 1 0 -1
    drawline (50,0,0,0) ' -1 -1 -1 0
    drawline (0,0,50,0) ' 1 -1 -1 0
    drawline (0,50,0,0) ' -1 -1 0 -1
    drawline (0,0,50,50) ' 1 1 -1 -1
    drawline (50,50,0,0) ' -1 -1 -1 -1
    drawline (0,50,50,0) ' 1 -1 -1 -1
    drawline (50,0,0,50) ' -1 1 -1 -1
    drawline (0,0,60,90) ' 1 1 -1 -1 & 1 1 0 -1
    drawline (60,90,0,0) ' -1 -1 -1 -1 & -1 -1 0 -1
    drawline (0,90,60,0) ' 1 -1 -1 -1 & 1 -1 0 -1
    drawline (60,0,0,90) ' -1 1 -1 -1 & -1 1 0 -1
    drawline (0,0,90,60) ' 1 1 -1 0 & 1 1 -1 -1
    drawline (90,0,0,60) ' -1 1 -1 0 & -1 1 -1 -1
    They are programmed in however i cant see any patterns in the data to create a simple formular from the above data.....(it is there ... i just cant see it)
    edited 2013-01-21 17:01
    Are you making things too complex for yourself perhaps?
    The first observation is that the sign of each step can be factored out at the start - for a given straight line segment
    the sign of the steps in x and y can be recorded at the start, and the x and y deltas made all positive.
    Then during the loop you progress the major axis every time and the minor axis whenever the test succeeds, so
    the cases are
    step major only
    step major and minor together.
    So 2 cases :)
    edited 2013-01-21 18:01
    For comparison, here is a slightly different algorithm, similar to Bresenham's but not quite. It builds a straight line as a modular form.
    [SIZE=1][FONT=courier new]'this if for first octant only.
    PUB MakeLineSteps(x0,y0,x1,y1) : ya | xp,yp,dx,dy
      xp := x0   ' points xp and yp will be visited
      yp := y0
      dx := x1 - x0     ' dy / dx is the slope of the line
      dy := y1 - y0
      repeat dx+1     ' number of steps is known in advance
         plot(xp,yp)   ' this not shown plots each point
         xp++                ' step right by one
         ya += dy    ' the accumulation
         if ya => dx        ' modulo dx
           ya -= dx
           yp++              ' if overflow, step up by one[/FONT][/SIZE]
    In the first octant, the slope of the line is the ratio of two positive integers dy / dx, with dx>dy. There are a total of dx steps to the right, and dy steps up. At each step to the right, the algorithm adds dy to an accumulator. If the accumulator is less than dx, then do not take a step up. If the accumulator is greater than or equal to dx, then take a step up and subtract dx from the accumulator.
    It needs a wrapper for the other 7 octants. I didn't try to work that out, but it would be similar to the Bresenham wrapper.
    The wrapper is implemented now in lineAlgorithm3.spin
    edited 2013-01-21 18:56
    For actual physical motion in a straight line, I use this algo, since the step intervals for each motor are equal:
    adx = abs(dx) * MAX_VELOCITY
    ady = abs(dy) * MAX_VELOCITY
    sdx = sign(dx)             'Sign is -1, 0 or +1.
    sdy = sign(dy)
    px = ady / 2
    py = adx / 2
    while dx or dy
      delay(dt)
      px = px + veloc
      py = py + veloc
      if (px >= ady) then
        px = px - ady
        step (x, sdx)
        dx = dx - sdx
      if (py >= adx) then
        py = py - adx
        step (y, sdy)
        dy = dy - sdy
    This is a very-much stripped-down version, but it gives the flavor of the dynamics involved. The variable veloc can be varied during the course of the movement to accommodate ramping. It should always be less than or equal to MAX_VELOCITY.
    edited 2013-01-21 19:18
    This may border on hijack or treason, but while we're talking about straight line algorithms, consider a two-link, two-pivot robot arm moving the free end in a straight line. Surely some of the IK fans here have done it already, find it "trivial" and are bored to tears with it. I'm all ears, 'cuz this is all that me and my warped perspective have tried so far: http://www.youtube.com/watch?v=uNIURBikrr8 If this thread survives a while, I just might get inspired to try drawing a few straight lines.
    edited 2013-01-22 01:20
    Thanks for this example....indeed your code works.... i will need to compare the two (mine to this) to see if i can utilise some corners....
    edited 2013-01-22 01:28
    MAX_VELOCITY.
    Tnx ..... I am beginning to see how I can implement acceleration into my software now...... (controlled by a couple of speed/acceleration "tweak" potentiometers)
    edited 2013-01-22 02:06
    Tnx for the sign trick ...... i do read the manuals (however this one slipped me by)
    edited 2013-01-22 10:01
    sign is not built-in, BTW. You have to write it. Also, my code example is not Spin, just a generic algo.
    edited 2013-01-22 13:41
    Then i did read the manual correctly......i would kill for an inbuilt SIGN( ) and an ABS( ) function though.....
    edited 2013-01-22 13:46
    Absolute value is built-in to Spin. The unary (prefix) operator is ||.
    A sign method is pretty simple to write:
    PUB sign(x)
      return (x < 0) | -(x > 0)
    This works because conditionals, when true, return -1.
    edited 2013-01-22 13:50
    SCREEN TEST?
    Here are the nuts and bolts of the first stage........
    The magic 16 lines ........ however there is some backlash on my "etch a sketch" ....(i have a way to eliminate it though ..stay tuned)
    640 x 480 - 170K
    640 x 480 - 143K
    edited 2013-01-22 15:32
    Sweet start! No encoders, right? Wonder if a full-size EAS would have less backlash.
    edited 2013-01-23 13:16
    Backlash begins to vanish ......
    17 boxes drawn in a loop.
    There is some rounding of the corners.......i have to tweak the software deadband control.
    Bottom left is the origin ..... you can see an issue with the aluminium powder clogging up.
    640 x 480 - 135K
    640 x 480 - 106K
  • tonyp12tonyp12 Posts: 1,951
    edited 2013-01-23 14:46
    Unlike pixels, steppers with the use of micro stepping is close to unlimited precision.
    So if you take the axel direction that is the longest and make that speed: 1.0 (max stepper speed)
    And the shorter get it's value to be calculated to be 0.246 etc, that you use for it's accumulator.
    If you keep adding to the counters, both will move close to a analog fashion and they should end up at the end position at the same time.
    I’m a missing something?
    edited 2013-01-23 16:56
    tonyp12 wrote: »
    Well if you ignore friction, non-uniform machining of motor pole step-grooves, eccentric alignment of axle, electrical
    phase difference between A and B not being exactly 90 electrical degrees, non-perfect matching of drive currents in the
    two windings, then yes, unlimited precision :)
    edited 2013-01-23 17:38
    Hektor's an older robot, but I still find his line drawing (and more) skills impressive. Might be new for someone here!
    http://hektor.ch/Videos/
    edited 2013-01-24 08:03
    Tnx erco.....(ahha..from the Swiss institute NY)
    Heres my first attempt at Circles......
    Now with Formula driven code...
    fx := f32.FMul( fx, constant( pi / 180.0 ) )
    fy := f32.FMul( fy, constant( pi / 180.0 ) )
    Would it qualify for entry into your "Oval" challenge if i squash them a tad .
    640 x 480 - 125K
    edited 2013-01-24 08:05
    Mark_T wrote: »
    Not forgetting the EAS tensioning spring uuuhhhgggg.
    edited 2013-01-24 08:13
    tonyp12 wrote: »
    You know tonyp12, what you are describing is also lingering in my cortex and somehow, some way, this is what i sincerely hope will happen. (just as soon as I transfer the coding to a propeller stepper enabled robi)
    Plan B is to devise (a dead reckoning compass) deal (its another long shot)..
    edited 2013-01-24 08:34
    That's almost a digital spiral, Gareth. Reminds me a bit of the thousand-year-old Sun Dagger spiral petroglyph at Chaco Canyon, http://en.wikipedia.org/wiki/Fajada_Butte
    Throw a sun dial on that EAS and put it in a museum!
    edited 2013-01-24 08:44
    Next trick ..... code is still not 95% yet .....
    fx := f32.FMul( fx, constant( pi / 45.0 ) ) ' Scale to actual PI values
    fy := f32.FMul( fy, constant( pi / 180.0 ) ) ' Scale to actual PI values
    640 x 480 - 115K
