sock.Listen is commented in the StartListners method. No socket listener on the line.
PUBStartListners | irepeat i from0to SOCKETS-1
sock[i].Listen
That,s true . Overlooked that .
change it with yours ,But I stilll cant get the page loaded ,
I can see in wireshark that when i open the page in the brouwser, the pc and the prop talk back and forth a bit .
but the page never loads . so somthing still stops the page from getting out
UPDATE
I already found the problem , there were a few pst statements left in the parseresourse , I removed those and now it does load the page
and it works faster too mike . page load up verry fast
Ok , Thout let me post the fix for other reading this having the same problem .
i have added a hard reset just before all starts , this ensures that it always lauches right and the wiznet is not busy with something else
and with removal of all the pst statments , its all working again ,. WITHOUT( NOT CONNECTED) THE USB-PROPSTICK connected
this how it looks like for a easy copy past
A DHCP + multisocketserver running wich can be address by hostname , So no bothering with ip adress .
Many thanks to mike for his great work and support .
last ting still is get the login page running and working along with all the ajax request going on and other task the propeller is also doing ( monitoring sensor, and setpoints )
, . hopefully the last chapter
I have experienced that a demo program may have problem (ex: DHCP 'Discover Error') if the Wiz820io is not started from 'reset condition' which may be either power-on-reset, nRESET pin control and (possibly, I haven't tried it) software reset command.
I had that probleem , Mike mentiond that it is some kind of conflict Hardware or Firmware. , Not sure wich one
i bypased the hole problem by complety removing all pst statements ,
you have the pst statements in the dhcp demo ?? try removing them an see if the problem still ther
I'll incorporate your reset logic as well as build a handler to detect W5200 connections for stand alone operation.
Mike glad to hear that at least that I could contribute . sweet
im not so sure about the timming , deffinitly could do it faster, its pretty slow now
did it like that just to be sure its resetting, but the datasheet may give a better timming . only im not that good at calculating that for the prop
sure it wil be a quik awnser for the one who knows
Is the PST issue worth a own tread to get it solved mike ??
Mike how do you sugest the login page get incorporated in the multisocket , i have edditi the mulitsocket like below , and about 10 other combinations including the tokenzeheader
but this is deffinitly not working,
PUBMultiSocketServer | bytesToRead, i, page, j, x , bytesSent, ptr
bytesToRead := bytesSent := i := j := x := 0repeat
CloseWait
repeatuntil sock[i].Connected
i := ++i // SOCKETS
repeatuntil bytesToRead := sock[i].Available
if(bytesToRead < 0)
sock[i].Disconnect
sock[i].Open
sock[i].Listen
bytesToRead~
next
sock[i].Receive(@buff, bytesToRead)
{page := ParseResource(@buff)}
req.TokenizeHeader(@buff, bytesToRead)
if(req.UrlContains(string("favicon.ico")))
pst.str(string("404 Error", CR))
sock.Send(@notFound, strsize(@notFound))
sock.Disconnect
bytesToRead~
next
{{ Process the Rx data}}
'Check for Authorization headerif(IsAuthenticated)
pst.str(string("Authenticated", CR))
sock.Send(@index, strsize(@index))
else
pst.str(string("Not Authenticated", CR))
sock.Send(@auth, strsize(@auth))
{bytesSent := 0}{ptr := page}{repeat until bytesSent == strsize(page)}{bytesSent += sock[i].Send(ptr, strsize(ptr))}{ptr := page + bytesSent}if(sock[i].Disconnect)
do_nothing
else
sock[i].Open
sock[i].Listen
sock[i].SetSocketIR($FF)
i := ++i // SOCKETS
bytesToRead~
where the parsereasource returnd the page to be displayed back to the main pgram and then spit it to the buffer , the tokenheader seems to spit it out from there . confusing me even more ,.
aint got a clue , where to put the url that the prop has to listen to (POST), for it to listen to a command when a button is pushed ( e.g. led).
I committed Html5GraphBasicAuthentication.spin to the code repository. It shows how to copy and paste the basic authentication demo source to Html5Graph.
As stated in previous post, you should not mix the parsereasource from Html5Graph and tokenheader from the HttpHeader object. You're essentially tokenizing the header twice. Use the httpHeader object ONLY!
This is not a logon page! The demo uses basic authentication. A logon page would take a lot more work and require supporting objects. At this point, I only have an idea of how to accomplish the task. I do know the task would require session state and encrypted tokens as well as research and development.
He mike , Thanks for the adding , There was a pst statment left in the multisocket server , you sould remove it
. after that , it now works great. Thnaks allot
one other thing ,
I was trying again with some smartphones(blackberry & nokia n97 symbian) to get the page loaded , but the connections seems to time out ,
in allot of tries the page may partialy load up one time than alot of times not again , so I suspect its the famous timeout issue .
read a few post , but I cant seem to find the timeout statment anywhere in the html5graph files.
could you point me the ? :P thanks
Mike.
When I open the login page, and its asking me for the username and password.
If i enter it right away , thothing wrong, and the server works fine
But if i wait for let say a minute before I login with the page open for that minute.
I think the connection is getting time out orso ,and then getting stuck .the propeller nevver recovers. to ask for the password again , or serve the page
I am then unable to connect to it anymore , also not with a new brouwser window .
I left the password prompt open for 5 minutes then clicked OK. The graph page loaded as expected.
You must close then open the browser to invoke a new password prompt.
ill troubleshoot with the iphone tommorow as the person hoe had it left me, comming back tomorrow .
Thout I start to find te timeout as i knew i read about that a couple of times .
But the html5graphl page doesn,t load so ill have to do the timming troubleshoot first thing in the morging. thanks for telling me where.
around wich value would you say is a good starting value and increase decreas in steps of howmuch ..
sadly i dont have the phone now , ill try tommorrow and let you know
o bye the way..Jazzed mention he knew about the problem we are having with the pst and a solution for it , chek it out
Hey Mike - not sure you should add nRESET to your code unless there's a way to make it optional. Some apps may just use POR and/or drive nRESET from global reset signal. It's easy enough for end-user app to handle nRESET (and PWDN & nINT) if they choose to and are able/willing to devote the Prop pins.
Good point twc, I see mike already did it . nice going
Mike , about the server hanging .
I troubleshooted alot but cant find anything strange
If I load your demo code , and I added just the HTML page of my , so its some bigger . anyway
it works fine in the biginning
but if i repeatedly .
open a new browser ---- go to the login page
login ---- run page a few seconds -- do e few refresh (F5) -- close the bouwser again .
and start all over , to log in again ,.
if I keep doing this , eventualy the server hangs . not letting anything load or open anymore .
But i can ping it with the pc , but not get a page reply .
sometimes it take 5 retryies to get it to hang, the otrher time 30 times , so its a little bit random .
Sure your not having this problem mike ??
I'm not exactly sure what demo you are running but it sounds like pressing F5 or ctrl F5 several times causes unexpected results. Probably displays a message like "Unable to Connect"?
That sounds like the socket is not in the expected state. The socket could be in the CloseWait or Closing state. I slightly modified TcpSocketBasicAuthenticationServerDemo.spin and committed the changes. Load the code and see if that helps with the locks.
If the page does not display, try pressing refresh. The server should recover.
Mike it looks like its working without getting stuck .
There is a sencario.
When I run the serveer . Open the loginpage on one computer on my network , and leave the login page open not loggin in yet , and open another brouweser on another computer on my network , and try to connect with the second pc.
then again the server gets hanging ,
If you are running the demo in post 168, you only have one socket running. That means one available connection. The initial logon is holding the socket open waiting for a username and password. If you require more concurrent connections then start more sockets. You have 8 max plus you have modify the code so it cycles through the available sockets.
Edit: The browser will handle the authentication request. Several browser instances can be opened with the Authentication Request alert dialog open. Clicking OK will send a second request with the base64 encoded username and password.
If you are running the demo in post 168, you only have one socket running. That means one available connection. The initial logon is holding the socket open waiting for a username and password. If you require more concurrent connections then start more sockets. You have 8 max plus you have modify the code so it cycles through the avaialable sockets.
Im running the Html5GraphBasicAuthentication spin code, it was multisocket right ?? in the beginning it states 7 sockets,
aint that suppose to make the multiple connections possible
but running the code with 1 socket if thats the case, it sould be possible to not let the prop hang when a seccond connection is trieing to connect at the same time. just drop it orso . now it hangs
I have not written code to handle concurrent requests for the W5200. If you require concurrency, then you'll have to write the code. The Spinneret source can handle concurrency by monitoring and queuing socket status. There is also buffer considerations.
Anyway, see the Spinneret code for ideas.
Mike , I have figured out what was going on the the prop was hanging .
Fist the steps to get it hanging and not responding anymore
computer1 - I open a brouwser , open the page , login . and the page runs fine .
after this , I open a second brouwser tab within the same brouwser . and close the first one . this way I have closed the page from the prop , but the brouwser is stil kept its autorization to acces the page
on computer 2 , Or this could be another brouwser ( eg. Crome & firefox )
open brouwser and go to the page , but dont log in yet.
when the page is open and asking for the login ,. leave it
Go back to pc 1 and open the page of the prop with the brouwser that already has the autorization .
This is where the prop hangs in the connected state , never recovvering .
in the pst i see this every time it hangs .
[HTML]Send Response
Byte to send 252
Bytes Sent 252
Disconnect socket 4
Disconnected
TCP Service
Connected Socket 5[/HTML]
so there is a soccet that get conencted never timing out
Having a look at the multisocket closer .
i := ++i // SOCKETS
pst.str(string("Connected Socket "))
pst.dec(i)
pst.char(CR)
'Data in the buffer?repeatuntil NULL < bytesToRead := sock[i].Available
'Check for a timeoutif(bytesToRead < 0)
pst.str(string("Timeout",CR))
sock[i].Disconnect
sock[i].Open
sock[i].Listen
bytesToRead~
next
the if thatment for the timeout , was never part of the first reapeat untill
so I moved them 2 spaces back , so they wil be part of the repeat untill
repeat until NULL < bytesToRead := sock[i].Available
if(bytesToRead < 0)
sock[i].Disconnect
sock[i].Open
sock[i].Listen
bytesToRead~
next
And now magicly , In the same situation as before .
When it hangs . with a few refreshes and a few timouts poping up in the pst . all resumes to normal operation
[HTML]
Send Response
Byte to send 252
Bytes Sent 252
Disconnect socket 0
Disconnected
TCP Service
Connected Socket 0
Timeout
Timeout
Timeout
Timeout
Timeout
Timeout
Copy Rx Data
Not Authenticated
Send Response
Byte to send 148
Bytes Sent 148
Disconnect socket 0
Disconnected
TCP Service
Connected Socket 0
Copy Rx Data
[/HTML]
was this moved by accident ,or am I seeing it wrong . works fine now
one thing thou
when you do nothing , the timout statments , keeps repeating ,.
sould I add a force socket close. or is this gonna close the socket like its not the intention
im getting an force close statement when i try to connect with a nokia n97 symbian phone
what does this mean . ive play whti the transtimeout alot whitout resutls
[HTML]Send Response
Byte to send 8171
Bytes Sent 8171
Disconnect socket 0
Force Close
TCP Service[/HTML]
Igor, your expectations are beyond the capabilities of the current W5200 code base.
dont realy understand what you mean , Its working just like i wanted now , on the pc, no hanging , no fuss. the smartphoneś only it doens open .
do you refer to wanting it to work on all those smartphones and a normal pc is too mucha of an expectation for te wiz
In post 169 and 173 you are testing concurrency. Be advised, there is NO CODE written that handles true concurrency!
Secondly, moving the if statement inside repeat until NULL < bytesToRead := sock.Available is not a good idea. A better solution is removing the NULL conditional statement.
Html5GraphBasicAuthentication.spin is committed to the code repository with slight modifications to better deal with multiple authentication requests. However, MultiSocketServer does not handle true concurrency it just appears like it does. The Basic Authentication demo works because of the way the browser functions. The Authentication request/response is two separate requests. I just figured out that when the Authentication alert is open the original socket severed up to page is is closed. The browser is not connected to a socket as I originally thought.
now I understand the concurrency issue , but it wansnt the idear to let them work in lets say tru parallel , like the propeller cogs do .
correct me if im wrong ,
but now the server handels , the request 1 after another in a quee list fasion , but its working pretty fast ,
I think I would not need true concurrency. for this application of just mesuring a temp sensor. and serving a page and managing a small interface(LCD+LED+buttons) on the propside
about the timeout , your suggestion works fine now , I dont get the timeouts anymore to see in the pst .. nice
but where are the timeouts that I used before intended for then , are those causing the socket to close prior to me opening it on my nokia n97 smartphone
UPDATE : strangly the html5graph demo does open on the phone , but my bigger code page doesn,t are all the sylesheets enso atache to it making the socket close ?
seems like the nokia is not supporting html5 but only 4.1 . so the graph is not going to display. ill have to live with that
edit ; i just missed your postupdate .
another thing the mod did seem to solve is .
before , when the page and the pst are open , you can see allot of activity . happening at the pst side .
if you leave the brouwser tab open and just go to another tab , the speed of the activity seem to get reduced by half
but now it doesnt anymore, now its constant the hole time nice
Placing the if statement inside the repeat loop causes a bug on timeouts.
This following statement ignores timeouts.
repeatuntil NULL < bytesToRead := sock.Available
This statement passes a timeout and let's you do something about it.
repeat until bytesToRead := sock.Available
bytesToRead~
next
I thought your stylesheets were located on another computer not the W5200/Porp?
Did you have the sensiron SHT-11 temperture & humidity sensor ??
if so ,
I was having some problems with the temperture , jumping up 1 degree and going back , resulting in spikes in the html5graph that is beeing served to a webpage by the wiznet server.
the temp also jump on the lcd display controlled by the propeller .normaly it just jumps 0.1 degree orso and back
I thout that it has to be with , a cog reading the values wile another cog is writing to the same values ,
integrated some lockes to make sure they get exclusive acces to the variables.but it still getting spikes .
anybody got an idea about whats going on ?
in other words , impove the stability of the reading
You really should start a new post for this issue. Maybe in the Sensor or Propeller forum.
According to the data sheet at 22 C the SHT-11 has an accuracy of is +/-0.5 C. At ~10 C accuracy is closer to +/-1 C
Assuming the source code is bug free, consider averaging 3 samples before sending the values to the graph.
Add an array of temperature values. Fill each element in a circular fashion. When it comes time to populate the graph, send the average of the three temperatures.
When populating the array, validate the temperature value is within an acceptable deviation form the mean. If it is not acceptable do not add the temperature value.
UPDATE
PUB HardRestart_WIZ dira[nRESET_WIZ]~~ outa[nRESET_WIZ]~~ waitcnt(clkfreq/2000 +cnt) outa[nRESET_WIZ]~ waitcnt(clkfreq/2000 +cnt) outa[nRESET_WIZ]~~ return
PUB Main | i, page, dnsServer HardRestart_WIZ i := 0 setpoint := i2cObject.ReadLong(i2cSCL, EEPROMAddr, $7981) offset := i2cObject.ReadLong(i2cSCL, EEPROMAddr, $7977) cognew(Tempcontrol,@stack1) pause(500) wiz.start(6, 5, 4, 7) wiz.SetMac($00, $08, $DC, $16, $F8, $01) dhcp.Init(@buff, 7) repeat until dhcp.DoDhcp if(++i > DHCP_ATTEMPTS) quit if(dhcp.GetErrorCode > 0 OR i > DHCP_ATTEMPTS) return else PrintIp(dhcp.GetIp) dnsServer := wiz.GetDns PrintIp(wiz.GetDns) printIp(wiz.GetDhcpServerIp) printIp(wiz.GetRouter) repeat repeat i from 0 to SOCKETS-1 sock[i].Init(i, TCP, 80) OpenListeners StartListners \MultiSocketServer pause(5000) PUB OpenListeners | i repeat i from 0 to SOCKETS-1 sock[i].Open PUB StartListners | i repeat i from 0 to SOCKETS-1 sock[i].Listen PUB CloseWait | i repeat i from 0 to SOCKETS-1 if(sock[i].IsCloseWait) sock[i].Disconnect sock[i].Close if(sock[i].IsClosed) sock[i].Open sock[i].Listen PUB MultiSocketServer | bytesToRead, i, page, j, x , bytesSent, ptr bytesToRead := bytesSent := i := j := x := 0 repeat CloseWait repeat until sock[i].Connected i := ++i // SOCKETS repeat until bytesToRead := sock[i].Available if(bytesToRead < 0) sock[i].Disconnect sock[i].Open sock[i].Listen bytesToRead~ next sock[i].Receive(@buff, bytesToRead) page := ParseResource(@buff) bytesSent := 0 ptr := page repeat until bytesSent == strsize(page) bytesSent += sock[i].Send(ptr, strsize(ptr)) ptr := page + bytesSent if(sock[i].Disconnect) do_nothing else sock[i].Open sock[i].Listen sock[i].SetSocketIR($FF) i := ++i // SOCKETS bytesToRead~ PUB HardRestart_WIZ dira[nRESET_WIZ]~~ outa[nRESET_WIZ]~~ waitcnt(clkfreq/2000 +cnt) outa[nRESET_WIZ]~ waitcnt(clkfreq/2000 +cnt) outa[nRESET_WIZ]~~ return PUB do_nothing return PUB ParseResource(header) | ptr, value, i, done, j ptr := header i := 0 done := false repeat until IsEndOfLine(byte[ptr]) if(IsToken(byte[ptr])) byte[ptr] := 0 resPtr[i++] := ++ptr else ++ptr if(ptr - header > 500) return @index resPtr[0] := header repeat j from 0 to i-1 if(strcomp(resPtr[j], string("HTTP"))) return @index if(strcomp(resPtr[j], string("xmltemp"))) value := GetTemp Settemp(tempc3,@temperature) Setlv(lv3,@lvlv) Settemp(tempmax,@t_max) Settemp(tempmin,@t_min) Setlv(lvmax,@lv_max) Setlv(lvmin,@lv_min) Setlv(setpoint,@Set_p) Setlv(offset,@off_s) return @xml if(strcomp(resPtr[j], string("setpointplus"))) setpointplus return PUB setpointplus if setpoint < 99 Setpoint:= Setpoint + 1 return
Mike , got a feeling the server is working faster also , because of the pst statements beeing removed, any way of measuring that ?
PUB MultiSocketServer | bytesToRead, i, page, j, x , bytesSent, ptr bytesToRead := bytesSent := i := j := x := 0 repeat CloseWait repeat until sock[i].Connected i := ++i // SOCKETS repeat until bytesToRead := sock[i].Available if(bytesToRead < 0) sock[i].Disconnect sock[i].Open sock[i].Listen bytesToRead~ next sock[i].Receive(@buff, bytesToRead) {page := ParseResource(@buff)} req.TokenizeHeader(@buff, bytesToRead) if(req.UrlContains(string("favicon.ico"))) pst.str(string("404 Error", CR)) sock.Send(@notFound, strsize(@notFound)) sock.Disconnect bytesToRead~ next {{ Process the Rx data}} 'Check for Authorization header if(IsAuthenticated) pst.str(string("Authenticated", CR)) sock.Send(@index, strsize(@index)) else pst.str(string("Not Authenticated", CR)) sock.Send(@auth, strsize(@auth)) {bytesSent := 0} {ptr := page} {repeat until bytesSent == strsize(page)} {bytesSent += sock[i].Send(ptr, strsize(ptr))} {ptr := page + bytesSent} if(sock[i].Disconnect) do_nothing else sock[i].Open sock[i].Listen sock[i].SetSocketIR($FF) i := ++i // SOCKETS bytesToRead~
one other thing ,
Default timeout setting are in the Socket.spin object.
'Increase TRANS_TIMEOUT in increments of 100*X if you are experiencing timeouts TRANS_TIMEOUT = 1000 TIMEOUT = TRANS_TIMEOUT * 10
Html5Graph (Top level object) sets the Socket object properties using setter methods.
PUB SetTimeout(value) _timeout := value PUB SetTransactionTimeout(value) _trans_timeout := value
What troubleshooting steps have you taken?
chek it out
the initial hanging doesnt seem to happen anymore
PST
[HTML]
Request:
GET /xmltemp?ms=1351368588056 HTTP/1.1
Host: px-100:8080
User-Agent: Mozilla/5.0 (Windows NT 5.1; rv:16.0) Gecko/20100101 Firefox/16
.0
Accept: text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8
Accept-Language: nl,en-us;q=0.7,en;q=0.3
Accept-Encoding: gzip, deflate
Connection: keep-alive
Referer: http://px-100:8080/
Authorization: Basic d2ViOndlYg==
Send Response
Byte to send 252
Bytes Sent 252
Disconnect socket 0
Disconnected
TCP Service
Connected Socket 0
Copy Rx Data
Request:
GET /xmltemp?ms=1351368589057 HTTP/1.1
Host: px-100:8080
.0
Send Response
Byte to send 252
Bytes Sent 252
Disconnect socket 0
Disconnected
TCP Service
Connected Socket 0
Copy Rx Data
Request:
GET / HTTP/1.1
Host: px-100:8080
User-Agent: Mozilla/5.0 (X11; Linux i686) AppleWebKit/537.4 (KHTML, like Ge
cko) Chrome/22.0.1229.94 Safari/537.4
Accept-Encoding: gzip,deflate,sdch
Accept-Language: en-US,en;q=0.8
Accept-Charset: ISO-8859-1,utf-8;q=0.7,*;q=0.3
Not Authenticated
Send Response
Byte to send 148
Bytes Sent 148
Disconnect socket 0
Force Close
TCP Service
Connected Socket 1
Copy Rx Data
Request:
GET / HTTP/1.1
Host: px-100:8080
Send Response
Byte to send 8171
Bytes Sent 8171
Disconnect socket 1
Disconnected
TCP Service
Connected Socket 2
Copy Rx Data
Request:
GET /favicon.ico HTTP/1.1
Host: px-100:8080
Accept: */*
Send Response
Byte to send 8171
Bytes Sent 8171
Disconnect socket 2
Disconnected
TCP Service
Connected Socket 3
[/HTML]
[HTML]Send Response
Byte to send 252
Bytes Sent 252
Disconnect socket 4
Disconnected
TCP Service
repeat until sock[i].Connected i := ++i // SOCKETS pst.str(string("Connected Socket ")) pst.dec(i) pst.char(CR) 'Data in the buffer? repeat until NULL < bytesToRead := sock[i].Available 'Check for a timeout if(bytesToRead < 0) pst.str(string("Timeout",CR)) sock[i].Disconnect sock[i].Open sock[i].Listen bytesToRead~ next
'Data in the buffer? repeat until NULL < bytesToRead := sock[i].Available if(bytesToRead < 0) pst.str(string("Timeout",CR)) sock[i].Disconnect sock[i].Open sock[i].Listen bytesToRead~ next
[HTML]
Send Response
Byte to send 252
Bytes Sent 252
Disconnect socket 0
Disconnected
TCP Service
Connected Socket 0
Timeout
Timeout
Timeout
Timeout
Timeout
Timeout
Copy Rx Data
Request:
GET / HTTP/1.1
Host: px-100:8080
.0
Not Authenticated
Send Response
Byte to send 148
Bytes Sent 148
Disconnect socket 0
Disconnected
TCP Service
Connected Socket 0
Copy Rx Data
[/HTML]
one thing thou
[HTML]Send Response
Byte to send 8171
Bytes Sent 8171
Disconnect socket 0
Force Close
TCP Service[/HTML]
repeat until bytesToRead := sock.Available 'Check for a timeout if(bytesToRead < 0) bytesToRead~ pst.str(string("Timeout",CR)) next
I thought your stylesheets were located on another computer not the W5200/Porp?my page im working on has a few stylesheets and 2 javascripts. that I meant with bigger
thanks for the timeout explination
if so ,
