Mystery Part — Parallax Forums
Mystery Part
ercoerco Posts: 20,263
edited 2011-10-24 13:21 in General Discussion
Whippersnappers (everyone under 20): You probably know Java, HTML, C++, and machine code. But do you know what THESE are? EVERYONE had 'em.
ATTACH=CONFIG]86219[/ATTACH]
Old guys rule and know NOT to post the answer here. It's more fun to drive the kiddies mad. Post YOUR mystery part here.
«134
    edited 2011-10-22 10:13
    I'm totally guessing here - Is this some sort of insulator put between a vacuum tube and the board it was mounted on? It looks like it's designed to fit different sizes due to the curved patterns on the outside.
    Of course, I'm probably TOTALLY wrong, in which this will seem quite funny to read my reasoning. :)
    Try again Micro...
    I'm 45 years old, so I know what they are.
    C.W.
    edited 2011-10-22 10:19
    Ok, is this even related to electronics or computers in any way? (It would be mean of erco to trick us like that!)
    Assuming it is, it looks like some sort of insulator. However, seeing as some old computers were programmed in strange ways, could this be some sort of programming key? Even if it was, I have no idea how it would work.
    Maybe it's a type of wire clip, possibly to keep the wire from getting too near a high-voltage source. I've seen something like that in a tube TV coming off of the cathode ray tube.
  • LeonLeon Posts: 7,620
    edited 2011-10-22 10:24
    I'm 69 and I haven't a clue what they are. :)
    edited 2011-10-22 10:27
    Leon wrote: »
    They must not have had anything to do with the Transputer or the "X" chip then...
    C.W.
    edited 2011-10-22 10:30
    I only had them in Black. The Red one are cool!
  • stamptrolstamptrol Posts: 1,731
    edited 2011-10-22 10:33
    Nice, Erco!
    You've got a fortune there! And the high performance red ones, too!
    The store we got the the "main component" from used to charge us 5 cents each..................when I made $1 an hour.
    Must dig into the "archives" and see if I can find a similar poser.
    Cheers,
    edited 2011-10-22 10:36
    stamptrol wrote: »
    Sort of like spark plug wires, for some reason color makes a difference...
    C.W.
  • Mike2545Mike2545 Posts: 433
    edited 2011-10-22 10:40
    Mine was solid...never had one of the new-fangled ones
  • LevLev Posts: 182
    edited 2011-10-22 10:54
    Mike2545 wrote: »
    Wow. Nostalgia trip. Haven't seen one of those since the early 19XX's (not revealing the era). Mine were all solid too, no slots.
    edited 2011-10-22 11:00
    erco you could give them a clue to think about.
    edited 2011-10-22 11:02
    Rat, I gave them one, Leon didn't, or maybe by way of comparison he did...
    C.W.
    edited 2011-10-22 11:05
    What those things did individually, my family had a mechanism for that did a bunch at once.
    edited 2011-10-22 11:08
    You could even find them in white, black, or even in cast metal. I'm sure I have a couple in my basement somewhere.
    edited 2011-10-22 11:18
    I was going to post something like that Phil but the way I worded it gave to much away so I didn't submit it.
  • SRLMSRLM Posts: 5,045
    I think they are parts to build structures with. Sort of like Legos, but with only one component. Similar sets are usually found in the gift shop of science museums.
    edited 2011-10-22 11:19
    Using more than one of those things at a time also required a "balancing arm."
    edited 2011-10-22 11:21
    Lets not go round in circles with this.
    edited 2011-10-22 11:38
    Never needed these as the function was built into the one I had. I always thought they were part of a Communist conspiracy that started in the mid 40s.
    -- Gordon
  • $WMc%$WMc% Posts: 1,884
    edited 2011-10-22 12:35
    The red ones are cool.
    The ones I used were all black.
    Due they still make these?
    edited 2011-10-22 12:38
    $WMc% wrote: »
    Not while erco has so many to put on ebay. :)
    Jim
    edited 2011-10-22 12:40
    Indeed, they do. In fact there's an entire website devoted to the things, and they come in more varieties than I knew existed.
    edited 2011-10-22 12:47
    At least tell me this: are these in any way related to electronics??
    edited 2011-10-22 13:05
    Yes. When you use them, you're also using electronics. (However, the electronics aren't strictly necessary.)
    edited 2011-10-22 13:20
    SRLM wrote: »
    I think they are parts to build structures with. Sort of like Legos, but with only one component.....
    Throw in some popsicle sticks and you were good to go.
    edited 2011-10-22 13:22
    OK, another hint please! What were these used as, e.g. Was this a toy of some sort? Was it something for your car? Did you use it around the house? etc.
    Seriously, I don't have a clue.
    You didn't need rotary encoders to count revolutions back then...
    HINT: One of these came in handy with erco's parts.
    186 x 186 - 4K
  • ajwardajward Posts: 1,130
    edited 2011-10-22 13:32
    At 63 I've used a great many of these!
    edited 2011-10-22 13:33
    The things they were used with were, like, totally groovy, man!
    edited 2011-10-22 13:35
    -- Gordon
    The red ones look like they could the logo for some political party!
