How to Start hardware of 2Quick start board ...??
RITESH KAKKAR
Hello,
I have got Quick start micro controller board, but i have no idea how to use it as i think it require a software for using........!!
Please help..........
Thanks.
Thanks.
Start here. This webpage has basic "How do I start?" information and links to the resources you'll need. There are several tabs on the webpage. Explore them all.
I have readied that link and downloaded Setup-Propeller-Tool-v1.2.7-(R2) but how to use it?? it is asking for Com1 and 2, I have connected the board with USB to PC the light are glowing
I also wrote this:
@Mike, Can/will you move this thread to the Propeller forum or should Ritesh start a new thread there himself?
Duane
If this doesn't work for you, you will have to carefully list the steps you've gone through including what messages you got from Windows (exactly as shown) and what (if any) responses you made. Most people seem to be able to get this all working without problems, so it's very important for you to provide enough information so we can try to figure out what's different about your case.
No way...........!!
Hello sir,
I have windows XP 32 bit, what the need of this??
Is this s/w Virtual com port driver will convert COM to USB ??
The eight blue LEDs can be controlled by the program you load on the QS board. Don't worry about them.
There's a green power LED. There are also red and blue LEDs next to the USB connector. These two will flash when the board communicates with the PC.
Since you are using Windows XP you should be able to download the driver here.
http://www.parallax.com/usbdrivers
Or use the link Mike provided. I suggest to always listen to Mike. He knows a lot more than I do about the Propeller.
@Mike, Thanks for moving the thread.
Duane
I have downloaded that and installed............but seem to it is not working there is no set up of it in program window and desktop
The link was to just the driver. It doesn't add a program.
You will need to reinstall The Propeller Tool (unplug QuickStart first) after the driver has been installed (which I think you just did).
You ought to download version 1.3 of The Propeller Tool. It works a little better than 1.2.7.
The blue LED is working fine sensitive to touch, but there is problem in software i think it is not detecting the usb of QS, i have intel 64 bit I3 PC, but i have installed 32 bit XP.........
Got two very simple things to try before we go deeper...
1) Replace your USB cord to the quickstart board with another. (I've had issues with various cheap cables)
2) Plug the USB line into an alternate USB port
Let's start with this simple stuff, and then go from there..
OBC
Third link in post #4.
I think you should uninstall 1.2.7 first.
Then try installing driver again.
Then install 1.3.
I think I had to install the FTDI driver more than once on one of my computers.
Edit: Try what Jeff and Leon suggest first.
http://forums.parallax.com/showthread.php?132795-DEMO-QuickStart-Push-ON-Push-OFF
Download it from the Obex link supplied.
CON _CLKMODE = XTAL1 + PLL16X _CLKFREQ = 80_000_000 VAR long delay PUB Main | localIndex, direction delay := _CLKFREQ / 4 localIndex := 15 direction := 1 dira[23..16]~~ ' Set the LEDs as outputs repeat localIndex += direction if localIndex =< 15 or localIndex => 24 direction *= -1 localIndex += direction outa[localIndex] := 1 waitcnt(delay + cnt) outa[localIndex] := 0It will turn the LEDs on one at a time.
I've also attached a file that has the same code in it.
Now the fun starts!
Duane
parallax, should upload some more tutorial video of this........!!
PUB Toggle dira[16]~~ repeat !outa[16] waitcnt(3_000_000 + cnt)It'll flash the extreme right LED on P16. You'll find lots more programs you can try in the tutorial.
sure, i will write program but i don't understand it staring programing totally different and today i was reading it data sheet acc. to it the QS has 8 // process of 32 bits called cog, is this true so many processor??
Great. I'm very glad the board is working.
I gave you a lot of links in post #4 that provides information about the Propeller.
Also look under "Help" in The Propeller Tool. There is an ebook "Propeller Education Kit" with a lot of information. You'll need to adapt the exercises to use the the QuickStart board.
I'd recommend you use the label I included with the QS. It will make it easier to tell which pin is where on the 40 position header. I think there is a link to a picture of the label in post #4 of this thread.
And keep asking detailed questions here.
Duane
Yes, this is what makes the Propeller so cool!
You don't need to program all 8 cogs. You can write programs for just one cog. You'll be glad to have extra cogs later. It is a great microcontroller to use with robots because you can have each cog monitoring a different part of the robot.
There are a lot of projects on the forum that use multiple cogs. You can learn a lot from what others have done plus you can learn a lot from all the ebooks and articles Parallax provides.
Plus we are here to help.
Fun, fun, fun!
Duane
we just burn the micro controller from the kit and just take the working from it, is there any chance in this QS just burn IC and use it any where, without the need of board??
