Propeller Controller Board for Robots (officially version 1.02)
Here is a board I have created for my robots. It is intended for the Lynxmotion Quadrapod 3.
I think I read just about everything in the forums about creating a board and what parts to use. Hopefully this design will work well.
It was created with ExpressPCB. The software can be downloaded from: www.expresspcb.com
UPDATE: (6-11-06)
I completely revamped the board.
I realized that it would be better to put the main servo headers on the left side and that I have no use for the Rx, Tx, SDA, and SCL pins.
Added selectable power for the right set of pins.
Fully linked to the schematic.
UPDATE: (6-20-06)
Minor revisions to the PCB file. This is actually what I had prototyped.
I would appreciate any feedback.
(be sure to rename the sch1 file back to sch)
"It is not necessary to change. Survival is not mandatory."
- W. Edwards Deming
Post Edited (Dual Exhaust) : 7/8/2006 5:57:13 PM GMT
UPDATE: (6-11-06)
UPDATE: (6-20-06)
- W. Edwards Deming
Kerry
- W. Edwards Deming
If people like this design, maybe we could share the cost of a "Full Production Service" with solder mask and silkscreen from ExpressPCB.
Unless I hear some negative feedback or suggestions, I'm going to order the proto boards on Monday. I think I've checked and rechecked each connection 20 times.
I canceled the first order I placed (I was just a tad too quick).
- W. Edwards Deming
Post Edited (Dual Exhaust) : 6/11/2006 5:50:27 AM GMT
I've included a picture of the finished board.
- W. Edwards Deming
What'd you use for the etching? I'm having to relearn the state of the art. (It doesn't seem to be markers and acid baths anymore.)
I use PCB Express for prototyping. Feel free to use and modify the designs I've posted.
www.pcbexpress.com
P.S. You can use any of the pins for I2C.
- W. Edwards Deming
- W. Edwards Deming
Pictured here on the forum was Mark's prototype 1.00 board which worked fine right out of the envelope. After we got together, between some of my suggestiosn and mark's further investigations we had a V1.01 that never made it to copper but served instead as a focal point for a series of revisions that brought about v1.02. The PRC v1.02 board prototype is in transit from the fabricators as this is being written. We expect to have it by 7/5/2006 and have it fully checked out in a matter of a day or two.
What remains then is how many production boards to order. We are going to do this. But the one item that remains to be determined is the size of the order. The goal here is to provide 10 boards for Mark's use and 10 boards for Brian's use, and have the sale of the remaining boards cover the costs of the whole production run and the two prototyping runs if possible.
To that end we are looking at a fabrication run of 50 to 200 boards. Interestingly enough, for this board, the price drops per board, for each 100 units past 200 units are not all that significiant. If we order;
- 50 boards they can be sold for about $12 each
- 100 boards they can be sold for about $8 each
- 150 boards they can be sold for about $7 each
- 200 boards they can be sold for about $6 each
- Shipping and handling comes to about plus $2 S/H for up to 3 boards, plus $1 for each two boards beyond that
So, if you might be interested please go check out the web page I put up at
www.wulfden.org/PRC/
I have a picture of the V1.00 board, the schematic and mechanical layout of the v1.02 board (the proposed production candidate) there is a link there so that if you might be interested you can email us and let us know how many baords you might be interested in purchasing. This is non-binding. Just for guidance. We just want to know if you are interested, and how many boards you might buy at what price. We estimate that we will order by 7/12, which means we would have boards available for shipment on or before 7/28.
cheers ... brian riley, n1bq, underhill center, vermont
See the K107 Serial LCD Controller at
www.wulfden.org/k107/
Mark sent me the parts list and I looked up part numbers etc and HTMLed it. It is now posted on the PRC webpage. If there is enough interest I will kit asll the non-Parallax parts. The URL is ...
P.S. This IS GOING TO HAPPEN what only remains to be revealed is how many boards Mark and I get when its done to use for coasters and other odd uses, and of course how inexpensive we can make them for the others interested.
"All the pins (00-27) have jumpers for direct connect (wire jumper) or resistors (individual 1/4 watt or isolated resistor network dips)"
Can you explain that in more detail? I don't see where you would connect these jumpers.
I like the design, I just want to make sure that working with external 5 volt parts won't be real difficult. We can't take a direct 5 volt logic level into the Prop chip. So I'd like to use standard 3 pin connectors (GND, POS, Signal), but have an easy way to put a resistor inline to protect the Prop chip. Hope that makes sense.
Kerry
What you are asking is exactly what it does. It's more of a bridge than a jumper. It's the first two rows of sockets (width of a standard 16 pin dip) next to the Propeller. You can put a jumper wire, resistor, or an isolated resistor network dip.
Soon we will have pictures and it will all make sense.
- W. Edwards Deming
Sign me up for one then [noparse]:)[/noparse]
Kerry
I think everyone will be very happy with the design and the features.
- W. Edwards Deming
So now the question becomes ARE YOU ALL READY?
I want to thank all the persons who have emailed and expressed interest and tentative committments so far. If most of these guys had their way. I would have to have ordered the boards last week. Thanks for the support guys.
Anyway, I need to have an idea on quantity by 1300 EDT on Wednesday 12 July 2006. ExpressPCB's production queue management protocol uses 1400 EDT as a cutoff time on its day counts. This would give us a delivery date on or before 28 July 2006 and boards in the mail on or before Saturday 29 July 2006.
Pricing; It is still difficult to tell but I feel comfortable right now making these statements in terms of maximums and minimums
- Bare Boards - Paypal, Shipping, handling - $2 for up to 3 boards plus $1 per two additional boards
- Bare Boards - single board $10-14 each, two-three boards $9-13 each, four-five boards $8-12 each, six-nine boards $7-11 each, ten or more boards $6-10 each.
- Non-Parallax parts kits, each bundled with a board for 1-9 boards $20 each (plus cost of board), 10 or more $18 each(plus cost of board).
- Boards and Parts kits - Paypal, Shipping and Handling - $3 for first and $1 each additional
So that is it ... I hope you all like what we have to offer, I will do my best to keep the prices down. We have commitments now for about 38 boards. If we get committments for at least 20 more boards I can say with some assurance the price per board will be in the middle of each range quoted above. If at least half of the total boards committed go out with parts the parts price will hold. If a greater percentage orders parts as well I may be able to shave $1 to as much as $2 off of that.
cheers ... Brian and Mark
{Estimated at the high end, in USD}
1 Board + 1 Part kit + shipping & handling == $14.00 + $20.00 + $3.00 == $37.00, delivered. OK, not a bad price at all.
Please see a PM to you.
Just tossing my two bits worth into the bit bucket
KK
Be sure the check out the web site.
- W. Edwards Deming
KK
www.lynxmotion.com/Category.aspx?CategoryID=34
I have an older model, but it is basically the same.
- W. Edwards Deming
Hard numbers here, a single board and kit of parts will cost $30 plus $3 S/H = $33 total for one, but if your order four it's $112 plus $6 S/H = $118 total for four which is under $30 each. Six boards and kits comes in at $29 each. Its all there to see, check it out.
I have kept the prices down as low as I could to still cover our production, development, and overhead expenses. This is the only place it has been advertised. So its our small way of saying thanks to you guys for your support and encouragement. On 21 July, the day I plan to order the parts for the kits, the price per board and per kit of parts will rise $1 each ($2 total for a board and a kit of parts)
We still anticipate to begin shipping on 29 July 2006.
Brian
Thanks for the update. I placed my order on the site for 2 kits as previously discussed.
Paul
I also discovered an anomaly in the Mouser Search database. For some weird reason, the Microchip Serial EEPROM, Mouser Part number 579-24LC256-I/PG, will not be found on the Mouser site if you search against the whole part number, if you search against "24LC256" it will be found.
The parts list is now correct as it stands, all the parts fit in the right places etc.
Thanks to all those who supported this effort so far.
Bean.
Cheap 4-digit LED display with driver IC·www.hc4led.com
"Remember, you are unique, just like everyone else." Unknown.
Unfortunately I didn't take this into consideration until after I ordered ths first round of boards. Mark designed it for a different robt mount. However I took apart one of my BOEBOT chassis and played around a bit and one could easily drill 4 new holes without getting in the way of anything, and if you have the three slots long the front end free, one would only need to drill 2 new holes.
The only confirmation I've gotten is the PayPal receipt.
I want to make sure you aren't getting caught up in my Spam Filters.
Kenny
Kenny Gardner
GAP Development Company
http://www.gapdev.com/
As I state on all the order pages on my website, the PayPal receipt is your order confirmation. I have been doing business via PayPal for over two years now and have found it to be extraoridnarily reliable in that line. I acknowledge that some people have had some problems with Paypal, but it hasn't happened to me or my cutomers. I have handled about 11-1200 transactions inn two years.
A "Pre-Order" situation like ths is always a bit tough. I have prided myself in this little business that I get orders out the door in a single business day. The reality usually is that any order received by noon is out the door that same day, if the Post Office is open; otherwise, it goes out the next day the USPS is open. So the "Shipping Status List" link on the order pages will generally almost immediately reflect the order as soon as it comes to my attention and is packed. But, when you have a "pre-Order" awaiting delivery of PCBoards, I can understand that the lack of seeming confirmation can make one uneasy.
That said, I might have had to come back and tell you I didn't have any record of an order from "Kenny Gardner", until I went back and looked at your post again and noted the "Gap Development" tacked onto your signature. There was no name at all attached to your PayPal order to me from GapDev.
The one and only dispute I have ever had on my PayPal record went round and round for two weeks and it was not until the fifth or sixth exchange of emails that this individual got around to mentioning his PayPal email address, which was completely different from the email address with which he was addressing me while making the complaint. The matter then was resolved immediately.
Four paragraph's later ... <grin> ... YES, I have your order; thank you very much ... and ... NO, I generally do not issue order confirmations beyond the PayPal confirmation.
I don't have any problems with PayPal other than the fact that when I switched over to them from Authorize.net, I'm getting more declined Credit Cards for no reason or because the customer wrote "6th Street" instead of "Sixth Street" so the AVS fails.
Can't wait to get the boards. Thanks much,
Kenny
Kenny Gardner
