interfacing prop to RC receiver
Any tips on interfacing to a Radio Control receiver, like say for example this one:
http://www.towerhobbies.com/products/towj0224_n.html
My guess would be that it can be interfaced similarly to the GWS PG-03 Gyro in the Propeller Official Guide book, but I figured it's worth a double-check to see if there are any existing applications or objects. I'm assuming these RC receivers all run off 5V, not I'm not quite sure how we're able to get away without a level shifter between the prop and the 5V device (I haven't done any mixing of 3.3V and 5V devices until now, so I don't know the rules).
Scott
Scott
The details of how you do the software depends on the specifics of the R/C receiver. Typically you'd get 5V/0V pulses with the pulse width ranging from 1ms to 2ms or maybe as much as 0.5ms to 2.5ms. This object may help you: obex.parallax.com/objects/522/.
http://servomagazine.com/index.php/magazine/article/trade_two_pwm_channels_for_a_whole_bunch_of_switches
Signature space for rent!
Send $1 to CannibalRobotics.com.
Post Edited (CannibalRobotics) : 5/2/2010 1:17:36 PM GMT
Nice article - BUT.
For many of us unusable SCH files as them can only be read by them that have same Software You support.
For ones that me that use different PCB software More usable are PDF type SCH files.
Regards
Nothing is impossible, there are only different degrees of difficulty.
For every stupid question there is at least one intelligent answer.
Don't guess - ask instead.
If you don't ask you won't know.
If your gonna construct something, make it·as simple as·possible yet as versatile as posible.
Sapieha
Jim
There are several objects in the Obex for reading RC signals. One of them is mine.
All you need to do is put a 1K or 4K7 ohm resistor (I use a 1K) in series with the signal line.
Rich H
The Simple Servo Tester, a kit from Gadget Gangster.
@Sapieha, the applications to read those files, should you choose to do so, is available for free download at the ExpressPCB website: http://expresspcb.com/·It's a decent program, easy to use·and there are allot of forum members that use it.
Glad·my article project is·getting used - let me know how it goes!
Jim-
I have already to much Programs installed.
If I not like one - I un-install it - And that Program are EXPRESPCB
Regards
Sapieha
