Catalyst 1.1 - a Catalina O/S for the TriBladeProp, Morpheus, DracBlade. Hybrid and RamBlade
RossH
@All,
Attached to this post are set of binary releases of Catalyst for various platforms. The source has also been released as part of Catalina 2.5, and is available in the Catalina thread (here).
I have included only platforms with XMM RAM (even though Catalyst itself does not require XMM RAM) because all the really-cool Catalyst programs do!
Here is a brief description of Catalyst:
Catalyst v1.1
Catalyst is an enhanced SD-card based program loader. It is mainly intended to enhance the capabilities of programs created with the Catalina C compiler, but it can also be used for loading and executing ordinary SPIN/PASM binaries.
Strictly speaking, Catalyst is JUST a program loader - it is not really an operating system because it does no resource management - however, it can be used to load programs that perform various resource management tasks - it even comes with a few - e.g. various utilities for doing SD card management.
However, when Catalyst is programmed into EEPROM, and when each loaded program resets the Propeller on termination (as Catalina programs now do), it can provide quite an effective single-user environment for self-hosted program development on the Propeller. Currently supported are BASIC, Pascal and Lua (and of course PASM/SPIN, using Sphinx). Self-hosted C development is NOT supported yet - but Catalyst is another step along the way!
Catalyst can be used on single-CPU systems (e.g. the Hydra, Hybrid, RamBlade, DracBlade, or Parallax Demo system) or on multi-CPU systems (e.g. Morpheus or the TriBladeProp). All it really requires is an SD card. It can be used with a local keyboard and TV or Video display, or by using a VT100 compatible PC terminal emulator (I recommend using 'putty').
Catalyst can be used to load normal SPIN/PASM as well as Catalina C programs. It can be used on any Propeller to load programs into Hub RAM, and (on platforms with XMM memory) to load Catalina programs up to 16Mb into XMM RAM.
Any command line parameters entered in Catalyst are automatically passed to the loaded program - i.e. the command line will appear in the C program's main function as argc and argv parameters. If the same program is loaded by another means (e.g. using Parallax Propellent or Catalina Payload) then they will execute normally, but the argv and argc parameters will be zero and a NULL string (respectively). Support for passing arguments when using Catalina Payload may be added in a future release of Payload.
A SPIN object that allows interpreting the Catalyst command line from within the loaded SPIN program is also provided.
Once a program is loaded and executed, Catalyst does not occupy any system resources - i.e. the loaded program has all Propeller resources available to it.
Catalyst provides the following built-in commands:
Post Edited (RossH) : 6/7/2010 10:08:18 AM GMT
Catalyst v1.1
DIR - simple display of the files in the SD card root directory (only files in the root directory can be loaded - but see the MKDIR and MV external commands) CAT - simple display of a text file CLS - clear the screen HELP - display some helpAs well as built-in commands, Catalyst can execute external commands. When a command (such as 'mv') is entered that does not match an internal command, Catalyst will look for the file MV.BIN in the root directory of the SD Card, and execute it if found. Catalyst provides the following external commands. These commands do not require any XMM RAM, and will execute on any Propeller platform:
MKDIR - make a directory RMDIR - remove a directory MV - move or rename a file RM - delete a file CP - copy a file LS - more sophisticated directory display than DIRThe following demo programs demonstrate the possibilities for self-hosted development on the Propeller. Note that they are large programs and require a Propeller platform with at least 512Kb of XMM RAM:
VI - the VI text editor DBASIC - the Dumbo Basic interpreter JZIP - an Infocom game interpreter PCOM/PINT - Pascal P5 compiler/interpreter SST - a version of Super Star Trek LUA - an advanced scripting language.For example, to create, compile and edit a pascal program, you might enter the following commands in Catalyst:
vi sample.pas <- start vi, creating the file sample.pas pcom sample.pas sample.p5 <- compile sample.pas using the Pascal P5 compiler pint sample.p5 <- execute the compiled program using the Pascal P5 interpreterOr to create and execute a basic program, , enter the following commands in Catalyst:
vi sample.bas <- start vi, creating the file sample.bas dbasic sample.bas <- start Dumbo Basic, executing sample.basOr to just have a little fun, , enter the following command in Catalyst:
jzip-l30 -c40 zork3.dat <- start the JZIP Infocom game interpreter using a screen of 30 lines and 40 columns, and play ZorkIIIRoss.
I see COPY as a command. What does that copy to and from - eeprom to sd card or sd card to PC or something else?
At the moment a session developing a catalina program involves writing it on the PC and downloading it - to eeprom or ram? Say I download a program and it works really well - can I then 'save' it to the sd card instead?
And how do you store settings - eg whether you are using vga or TV? Is this done by rebuilding and downloading catalyst?
www.smarthome.viviti.com/propeller
First, a quick request before release. Can you use a seperate extension for catalyst binaries other than ".BIN"? In Sphinx there is already a problem between programs that are Sphinx-aware (i.e. Sphinx commands like DIR, DEL, etc which are actually seperate small binaries) and programs that are true Propeller Binaries (non-OS aware). This will only make matters worse.
Propeller binaries (taking full control of the prop) should remain ".BIN". There have been a few suggestions for the Sphinx programs. I had thought of ".CMD" and ".EXE" but these would conflict with CPM if we ever mix them, so it·would be better to use something like ".BIX" for Binary Sphinx. Mike Green suggested ".SBN" although if we are going to get a number of different binaries the ".BI*" may be the best way to go.
So maybe you could use something like ".BIC" ???
Is there any way this can be combined with the SphinxOS effort?
I have done a few drivers that work via just one long at the top of hub. I am trying to shift all longs used in the OS down by 1 long so the top long can be used for the "lowest used hub address" for the rendezvous longs and any space required. e.g. rendezvous locations, SD buffer, screen buffer, etc. Any OS aware program should then support this limit when it loads an OS program.
Now a question..
You mention Pascal and Basic. Are these Catalina style compilers???
· Emulators: CPUs Z80 etc; Micros Altair etc;· Terminals·VT100 etc; (Index) ZiCog (Z80) , MoCog (6809)·
· Prop OS: SphinxOS·, PropDos , PropCmd··· Search the Propeller forums·(uses advanced Google search)
My cruising website is: ·www.bluemagic.biz·· MultiBlade Props: www.cluso.bluemagic.biz
The COPY command is just a file system copy - i.e. it copies from one file on the SD Card to another file on the SD Card.
I initially included an XFER command to do a simple serial transfer between a PC and the SD card - but I took it out because I really can't see the need when you can just take out the SD Card and insert it into the PC. I may resurrect it if there is sufficient demand.
I have no plans to make it possible to 'save' a program from Prop memory to SD Card. Actually, in general it is impossible to do so - Catalina programs on disk do not look like Catalina programs in RAM - e.g. XMM programs include an XMM loader that is discarded once the program is loaded.
Ross.
Catalina - a FREE C compiler for the Propeller - see Catalina
So, what I want to do is compile my C version of the ZPU interpreter with Catalina and run it on a TriBlade where it can then execute ZPU binaries..very slowly[noparse]:)[/noparse]
I used the '.BIN' extension precisely because all Catalyst programs DO take full control of the Prop. They need have no Catalyst-specific code in them at all. At most, they may include a module to interrogate the command line - but they don't even need to do that. However, the extension means very little to me. I can change it at any time.
Catalina/Catalyst make slightly more complex use of upper RAM than SphinxOS. I'll look into converging the two when I get some time.
As to Basic and Pascal - no, they are not Catalina-style compilers - they are just slightly enhanced versions of the Dumbo Basic interpreter and P4 pascal compiler I have already released (as 'Catalina Curiosities').
Ross.
Still a way to go for self-hosted C development. I think I will eventually have to write my own PASM assembler to do that. Sphinx is not really up to the job of compiling a 100,000 line source file to produce a 500Kb PASM program just yet.
I hate to think how long a compile like that would take on a Prop I with an SD-card based file system - probably weeks!
Ross.
I've not implemented anything - I was just going to do an X/Y/ZMODEM type serial transfer.
Ross.
OK, then mparks FTF code is extremely simple and he has a PC C version that only does the transfer. Since we are using a local PC connection I think this is fine.
Now I understand that they (COPY, DIR, etc) are just straight binaries, that is fine. With Sphinx Michael has these programs returning to SPhinx without rebooting the prop which is a great advantage. So I guess Catalyst could then run under SphinxOS without any problems. This way we can use all the programs written for Sphinx such as DIR, LS, etc. Also GET & PUT (file transfer) under Sphinx. Likewise Xmodem can be done also.
BTW: There is a problem with just rebooting the prop and TriBlade/RamBlade and fsrw in that DO is not necessarily forced back to tristate. It was actually a more curious problem where while the RamBlade was booting from eeprom a reset/download sequence was started from the PC. Just thought I would mention it in case you found a problem. Not that this should cause a problem if the SD is accessed again.
I should have asked... What fsrw are you using?
My loaders use an old version of fsrw - a modified version of 1.6.
I never bothered to upgrade, since Catalina does not actually use fsrw - Catalina has its own C-based version of DOSFS (a FAT12/FAT16/FAT32 file system designed specifically for embedded systems) built-in.
However, Catalyst uses fsrw to load binaries. When I get time, I'll upgrade to the current fsrw (it's on my increasingly long list of things to do!).
Ross.
Now this will be a lot of fun to play with.
First suggestion:
How about a "BIN" directory for the commands like MKDIR etc?
www.mikronauts.com E-mail: mikronauts _at_ gmail _dot_ com
My products: Morpheus / Mem+ / PropCade / FlexMem / VMCOG / Propteus / Proteus / SerPlug
and 6.250MHz Crystals to run Propellers at 100MHz & 5.0" OEM TFT VGA LCD modules
Las - Large model assembler Largos - upcoming nano operating system
By the way Catalyst is a big Cisco product. The original CatOS is still in use although it has been hidden over time in new products. I'm not suggesting changing the name, it's just an FYI.
May the road rise to meet you; may the sun shine on your back.
May you create something useful, even if it's just a hack.
my actual project uses Sphinx. This is because later the system will be in another room, not beneath my PC.
During programming/development of the project I found, that selfhosting is not that interesting at this moment. I have a big monitor screen at my PC and I use BST which gives very nice overview...
(I do not see the sense of a PC as terminal....)
* The download/upload feature (put/get) without starting a different application has proven to be very essential!!
* Very good: That you can restart the operating system directly from SD-card by the programm. This is faster than rebooting.
* A stronger editor would be good.
My personal opinion is, that it is very attractive to use the propeller with only little added hardware, if you want to use it as a microCONTROLLER. Therefore I think it is a very good idea, that your system does not need external memory. An optional (only optional!) real time clock would be good sometimes for time stamps of files.
Good luck,
Christof
@jazzed: The advantage of leaving the O/S stay resident (actually it is only in the cogs plus the rendezvous longs and any buffers) but not any other hub code is that you can change your hardware I/O on the fly. This means you can replace the serial with a keyboard and TV or VGA using either the same pins or different pins. The new binaries no longer need to be compiled for the specific hardware.
This also means I can take my SD card from one system to another and boot via the eeprom. The program in my eeprom only knows what pins the SD card is on. There is a little more to determining the hardware by the OS but I am sure you get the idea.
Provided you enter a date/time when the OS loads (and provided it is allowed to keep the cog(s) running, the date/time can be done in one of the existing cogs. It looks as though the later fsrw has this inbuilt.
Post Edited (Cluso99) : 4/19/2010 7:59:03 PM GMT
@RossH, do you have a loader strategy for putting drivers in COGs for user applications? You do something like that with EMM right?
Thanks for the "heads up" about Cisco Catalyst. Somehow I don't think they'll sue - Catalyst is actually quite a common name - because it's so cool!
@christoff,
Yes, I'm not all that convinced that self-hosting is all that useful. I just think it's fun - when I get Cluso's RamBlade up and running I will eventually have a completely self-contained ANSI C development environment in a matchbox.
@jazzed,
All Catalina drivers and other plugins get loaded into cogs. For LMM programs any Hub RAM they occupied is then returned to the user application as additional heap or stack space before the main functions starts up. EMM is slightly different - after loading the plugins, the EMM loader then allows the whole of Hub RAM to be overlaid with new code, allowing programs to use the full 32k of Hub RAM as code space if they want to. Most people don't seem to realze that this makes it possible to run much larger C programs without resorting to XMM (XMM is different again, with all Hub RAM being reallocated as data space).
Considering how little Hub RAM the Prop has, it is surprising that SPIN is so wasteful in its memory management. To me, this indicates that despite all the complaints, very few people are actually memory limited on the Propeller. Which is why I mostly ignore those who complain about the posible size of C programs. If they bothered to learn a bit about it, they will find (as I do) that there are ways and means to accomplish just about anything you want to do.
As to the O/S "reserving" capacity for it's own use - resources on the Prop are scarce enough without dedicating cogs or Hub RAM to the O/S - in some cases this would cripple the usabillity of the Propeller. I'm constantly fighing to find enough cogs and hub RAM to do what I want, and I would be very annoyed if I discovered it was the operating system itself (which is supposed to be there to help me!) that was the cause. Other people have other opinions, and for their purposes they are probably correct. But my choice for Catalyst is that it should use no cogs, and only use Hub RAM that is already unavailable to Catalina programs (essentially, about 100 longs of upper Hub RAM which is used by the kernel, the debugger and the various plugins).
Cluso's point about the O/S managing hardware resources for you is perfectly valid - if you are using SPIN, which requires you to modify source whenever your hardware changes. but Catalina already implements a Hardware Abstraction Layer that allows for most hardware changes to be accomodated without requiring source code modifications - it doesn't need the O/S to implement another. For my purposes, I treat the Prop is a dedicated microcontroller, and I am quite happy to recompile programs if the hardware changes.
Ross.
You know how BSD and Linux work of course and it's a fair system without too much overhead. In Linux for example, you can "insmod" a driver from·the filesystem·after startup and use ioctl, open, close, read, and write to access the driver. This driver can be loaded into a reusable HUB buffer and be started with COGNEW and buffers do not need to have some predefined variable space. This is slightly different from EMM in that the new drivers do not have to be a part of the boot image, but the result is the same: more memory available for user application programs.
Of course you can build the greatest theme park in the world and still fail to attract customers. Most educated CS people understand POSIX and may use it to their benefit if given the chance; everyone else may just say "that's nice" [noparse]:)[/noparse]
Exactly. This not a case of "if you build it, they will come" - it's more a case of "if you spend years building it, some forum members may poke at it from a distance with a stick"
Ross.
other than that, fantastic work.
I've been so busy with legal stuff at work I'm missing sooooooo many advancements on the prop.
I can't wait to get free from it all and start playing prop again very soon!
Baggers.
http://www.propgfx.co.uk/forum/·home of the PropGFX Lite
No, there is no CD - but that's not a mistake. There is no concept of a "current directory". The version of fsrw I use can only load from the root directory. Other directories can be created, but only for organizational purposes - there seems no point in being able to "CD" to them. There is no way to either pass this context to a program, or even "remember" it between instances of Catalyst. Maybe I coulde write it to the SD itself.
Ross.
Here is an alpha release of Catalyst. The enclosed file contains a full set of Catalyst binaries for the TriBladeProp (blade #2).
More platforms will be forthcoming shortly. Building and testing each one takes me some time.
Note that this is a binary only release. Releasing the source of Catalyst at this point would not do anyone any good because it requires a new (and as yet unreleased) version of Catalina.
The enclosed zip file contains a binary called 'catalyst.bin' that should be programmed into the EEPROM of the TriBladeProp CPU #2 (you may need to rename it to 'catalyst.binary' to do this). The other contents of the zip file should be put on a Micro SD Card formatted as FAT16. Then reboot the Prop and enjoy Catalyst!
Note that Catalyst itself, the built-in commands (dir, cls, cat etc) and the external commands (rm, cp, mkdir, rmdir, ls, mv etc) do NOT require any XMM RAM to run. But most of the demo programs (vi, pcom, pint, dbasic, jzip etc) require 512Mb of external XMM RAM.
All the binaries in this release (as well as Catalyst itself) are built to use a VT100 compatible PC terminal emulator. I recommend 'putty' (which is free). The vi editor now works using the PC HMI option, although editing files this way is quite slow. In fact, everything is quite slow at this point - but quite functional.
See the enclosed CATALYST.TXT document for more details on each command (there are some minor updates to the original blurb at the top of this thread).
Here are some example commands you could try:
Have fun!
Ross.
EDIT: Attachment removed. All the alpha release binaries are now attached to the first post in this thread.
Post Edited (RossH) : 4/28/2010 1:22:07 PM GMT
Pullmoll's Propeller Projects
This set of binaries will only work on the TriBladeProp. I'll issue some binaries tonight for a few more platforms, including the DracBlade (I just ran out of time last night).
The sources will be released along with the next release of Catalina. Catalyst is a combination of SPIN and C - but even the SPIN components depend on some of the Catalina modules to work correctly.
Ross.
I have attached alpha binary releases of Catalyst for the TriBladeProp, Morpheus, DracBlade and Hybrid to the top of this thread.
All the normal Catalina HMI options are avalable to Catalyst programs, whether they are implemented in SPIN or C.
For example:
- The TriBladeProp and Morpheus versions expect to be used via a VT100 compatible PC terminal emulator.
- The Morpheus version uses a proxy HMI because the SD Card is connected to a different CPU to the XMM RAM.
- The DracBlade version uses a local HiRes VGA display and keyboard.
- The Hybrid version uses a local HiRes TV display and keyboard.
Source code will be forthcoming with the next Catalina release.Ross.
P.S. I should point out that Catalyst currently uses both fsrw Kye's FATEngine. I am currently thinking I will transition Catalina away from fsrw, which means that the final version of Catalyst will be able to have the equivalent of a PATH, and execute programs from arbitrary subdirectories.
Nice job and well done!
Juergen
Somehow when I posted the alpha release binaries I seem to have lost the original SPIN demo program I posted - I have re-attached it (as spin_demo.zip) to the first post in this thread.
This means you don't have to wait for the next release Catalina to write programs for Catalyst - you can write them in SPIN, and load and run them using the alpha release of Catalyst. See the demo program for more details.
@pullmoll,
Thanks. Yes, vi is very slow - especially on the DracBlade. Performance improvements to the whole of Catalina/Catalyst are on my list of things to do.
I only use VT100 emulation when the PC HMI option is used (e.g. on the Morpheus or TriBlade), and it is very trivial - it only uses about 5 VT100 functions. On the DracBlade I write to the screen directly. But I just did a "quick and dirty" port of xvi, and didn't implement the scrolling functions at all - which makes it much slower than it needs to be to redraw the screen. Yrt another thing to add to my "to do" list!
The Catalyst loader can load normal programs (i.e. SPIN/PASM or LMM C) up to 31kb in size, or XMM C programs up to 2Mb. I may need to increase the latter limit at some point, but I can't see anyonw reaching that limit for a while!
I just noticed there were two 'vi' binaries in the Catalyst_DracBlade.zip alpha release - 'vi.bin' and 'xvi.bin'.
The correct one is actually 'xvi.bin'. I have fixed the zip file, but you don't need to download it again - just delete 'vi.bin' and rename 'xvi.bin' to 'vi.bin'.
Ross.
Geez, too bad: it doesn't work. I'm not over 31kb it seems... 31468 bytes. Perhaps something else is going wrong? The attached cpm.bin starts up and also initializes the VGA, but it does not clear the frame buffer, which can only happen when it dies somewhere before initializing a cog with the code to handle i/o on behalf of the Z80. So it starts up half way through and then dies.
What would happen if a program is larger than 31kb? Would you cut off the remaining 1kb? And is 31kb the exact limit, i.e. 31*1024?
The code needs all cogs and in the last step grabs cog #0 with a coginit(0, ...) - could this be a problem source?
PS: to run this bin there must be some files on the SD card on the DracBlade: BOOT.DSK, A.DSK, B.DSK and C.DSK. You can use any files for this, as it hangs before running relevant code that would make use of the contents of the files.
Post Edited (pullmoll) : 4/29/2010 3:06:49 PM GMT
