A Poll: PROP = SPIN, PASM, or C ?
Taking a little poll here·- for an application for everyone here to use. This is not·to start a·popularity or 'which is better' contest!
Take the Poll:
http://infopoll.net/live/surveys/s34168.htm
PLEASE SUBMIT ONLY ONE ENTRY
See the on-going results:
http://infopoll.com/live/surveys.dll/r?sid=34168&r=63019
(Thanks to Bob Lawrence (VE1RLL) for the above online form.)
We've had a few folks reply here before Bob set this up, so
you can also·answer here, if you'd like.
Please, just give ONE·numeric answer so this can be tabulated.
For the Propeller, which do you use (or code in) the most often?
(Don't count the library-like obex objects in PASM, e.g, video·drivers, etc.·- unless you modify them to suite your needs.)
1) SPIN
2) PASM
3) SPIN and some PASM
4) C
5) Forth
6) Other
thanks for your time.
- Howard
Post Edited (CounterRotatingProps) : 11/30/2009 8:45:59 PM GMT
Take the Poll:
1) SPIN
2) PASM
4) C
5) Forth
6) Other
- Howard
(I have changed my mind, my big coding jobs have all been pasm)
Post Edited (Graham Stabler) : 11/30/2009 1:27:25 AM GMT
Catalina - a FREE C compiler for the Propeller - see Catalina
Chat in real time with other Propellerheads on IRC #propeller @ freenode.net
Safety Tip: Life is as good as YOU think it is!
More PASM than SPIN though [noparse]:)[/noparse]
Just learning 2 now.
2
4
1
In that order
You don't need to do it again.
If you did it both ways please let us know so that it's not counted twice. I will manually remove one.
Post Edited (Bob Lawrence (VE1RLL)) : 11/30/2009 2:25:17 AM GMT
OK let's let the survey software to take it from here... again the link is:
Please keep your answers coming in!
Here is the real-time report.(I still have to add the manual responses.
Sorry for the confusion but the project was already live before I designed the automated version.
Edit: All of the manual responses have been added.
Post Edited (Bob Lawrence (VE1RLL)) : 11/30/2009 2:35:43 AM GMT
BTW, it's "forth", not "fourth".
2) PASM
4) C
5) Fourth
6) Other
Thanks! typo has been corrected in the Poll/survey form. Unfortunately the report will still show it wrong because it's generated from the database.
Post Edited (Bob Lawrence (VE1RLL)) : 11/30/2009 2:53:42 AM GMT
Jim Fouch
FOUCH SOFTWARE
jmh
My better code and preference is 2 (pasm). It is just that spin has it's place too.
· Emulators: CPUs Z80 etc; Micros Altair etc;· Terminals·VT100 etc; (Index) ZiCog (Z80) , MoCog (6809)
· Search the Propeller forums·(uses advanced Google search)
Now is 2.5 valid as it's mostly PASM with SPIN thrown in when speed isn't required as it's so nice to program in!
http://www.propgfx.co.uk/forum/·home of the PropGFX Lite
· Propeller Object Exchange (last Publications / Updates);·· Vaati's custom search
Please play nice and submit only ONE entry.
thanks
They are too shy to admit it here in the public.
No, it wasn't me!
Nick
Never use force, just go for a bigger hammer!
The DIY Digital-Readout for mills, lathes etc.:
YADRO
Visit some of my articles at Propeller Wiki:
MATH on the propeller propeller.wikispaces.com/MATH
pPropQL: propeller.wikispaces.com/pPropQL
pPropQL020: propeller.wikispaces.com/pPropQL020
OMU for the pPropQL/020 propeller.wikispaces.com/OMU
I think we can extrapolate the results - let's keep it going this way for now.
If you'd like to post your results here too, that's fine
... especially you 'shy' C types :-O
So it's C, then PASM ... long way to go ... SPIN
A poll that would have allowed some weighting would have been more usefull.
Nick
YADRO
yes - you are right of course. This was just a rough, first pass to glean a general idea.
We will drill down into it more later.
thanks (und mfG)
- H
