And now for a new use for a board that normally works in strange ways — Parallax Forums
Buck RogersBuck Rogers Posts: 2,216
edited 2019-09-03 21:55 in BASIC Stamp
Hello!
Take a look at this:
It is of a board normally used for that strange board originally designed to run a dialect that combines the best of Processing and the difficult to ponder parts of C Plus-Plus. Naturally I stuck a Stamp1 carrier board on it, via Scotch and my breakout board for talking to a TI programmable. I promptly spun it up as a temporary solution to making the whole idea, on a Super board.
I originally planned to use it with a regular carrier board, but couldn't get it work with the original occupant, a modified prototype board for the same family.
My only problem is that the numbers on the LCD display aren't formatted as they are on when talking to a Stamp2. The display gets covered by the numbers, instead of being left column oriented.
    edited 2019-09-03 22:09
    Buck, can you afford a better camera? :)
    Can't make out a darn thing in the picture.
  • Why?
    No it came with the phone. I was going to use my regular one, but it can only be accessed by special software that does not run on this laptop.
    Sign reads, "Mascot returns on Thursday."
  • Why?
    Your camera doesn't have a removable SD card that you can just plug into your computer and extract the images from?
  • Why?
    Hello!
    Yep. It predates memory cards by about twenty years. I do have a CF based one, but I rarely use it. Why? Did you look at the photo and have the same problem that Pub collided with? Ideally what's seen there, is a Stamp1 on its carrier board, stuck to the right of the breadboard with Scotch tape. And also held down by a 2-56 fastener which holds down the breakout board for the style of connector originally used on sound cards. I use it to connect a TI programmable in the 83 Plus series to either a Stamp1 one, (in this case) or a Stamp2 (also used but not here). The breadboard has on it connections to a LCD display which is a 27977-RT, the cable wired to it was also originally designed to connect sound cards to devices. I've used Dupont connectors on it to connect to the 27977-RT device. Power is connected to the 9V knucks on the back via a standard 9V battery inside a switched holder. I've used generic connectors to bring the holder to the carrier board, and the wiring was done up in a style that Mike Green described, which is how to wire a standard PCB attachable 9V connector to the board, (I don't remember but it is in the forum some place as applied to the HWB which at the time was unswitched.)
    Mascot supplied this before he left on vacation:Why do tribbles hiss when they are discovered by Klingons?
