Cool $20 Gift for the Guy who has Everything
Sorry, not Parallax, not even electronics. But if you need a last minute gift, here's a $20 Sterling Cycle engine that runs off your mug of hot coffee. Seller is in Kentucky (most at this price are shipped from China) so there's a chance it will arrive before Christmas. I just ordered two, one for my brother and one to hoard.
ANYBODY WITH A COOL NEW COFFEE MUG needs one of these! :)
Maybe someone smart will add a magnet & coil and blink an LED... or power a Prop...!
https://www.ebay.com/itm/223215448837
Forum issue: recently when I "insert picture" I get 4-8 duplicates and must delete. Anyone else?
"When you make a thing, a thing that is new, it is so complicated making it that it is bound to be ugly. But those that make it after you, they don’t have to worry about making it. And they can make it pretty, and so everybody can like it when others make it after you."
- Pablo Picasso
  • erco wrote: »
    ...here's a $20 Sterling Cycle engine that runs off your mug of hot coffee.
    How does that thing work? I don't see any connecting rod joining the flywheel to the displacer. It looks like the axle if fixed in the acrylic tower and the flywheel spins on a bearing but the only connection from the flywheel is to the power piston.
  • I think the crank/connecting rod that you can see IS the displacer drive. The "power piston" is probably a rubber diaphragm inside or at the top of the pedestal containing the main bearing - the "connecting rod" for the power diaphragm is probably always under (varying) tension - so it only needs to be a length of thread.
    These cheap Stirling engines often only use a diaphragm for the power piston - gets around the cost of making a low friction, well sealed, piston and cylinder. You can make one yourself from a couple of old cans, a CD for the flywheel, a few bits of thin wire and balloon from which to cut the diaphragm. You can find lots of plans on the internet and in YouTube videos on how to do it.
  • W9GFOW9GFO Posts: 3,925
    edited 2018-12-14 - 16:49:18
    ceptimus wrote: »
    In the first image you can clearly see the connecting rod (wire) attached a piston - unless it passes through the piston, if so what drives the flywheel?
    There needs to be something driving the flywheel, and something 90 degrees out of phase driving the displacer. The axle going through the pedestal containing the main bearing is fixed, and is straight - I don't see how there could be any form of reciprocating motion driving it.
    ceptimus wrote: »
    The ones I have found use a crankshaft with two throws, one for the displacer and one for the power (diaphragm). Can you link to one that uses a single connection to the flywheel?
  • Stirling engines are great.
    The Swedes use them in the latest generation of the submarines - the engines are very, very quiet.
  • ceptimusceptimus Posts: 108
    edited 2018-12-15 - 13:50:37
    I was thinking that the second 'crank' on the crankshaft would be inside the (hollow) acrylic tower, and attached to the "power piston" (membrane) by a thread inside that hollow tower.
    But I must admit that I'm not sure how the manufacturer would be able to assemble something like that ( the tower would have to be in two pieces to allow the crank to be inserted, or the crankshaft would have to be built-up of several pieces? ) so I could be completely wrong. If the 'crank' for the power piston is just a gentle crescent-shaped curve, I suppose it could be slid in from one end.
    I have seen YouTube videos of Stirling Engines that don't have any direct connection to the displacer - but they are usually in the form of a see-saw tube so that gravity can do the job of moving it as the tube tilts - and the one pictured in this thread can't work that way.
  • There's a listing of the same item with a hopefully real 5 star review saying it works. I'd love to see a video of it in action.
  • ceptimus wrote: »
    You can see that the flywheel is on a bearing - that means the shaft is stationary; so even if there were a crank inside the tower, it would not turn with the flywheel.
    edited 2018-12-15 - 18:24:58
    I suppose there could be a magnet in the rim of the flywheel, and a magnet in the displacer to lift it up as the magnet in the flywheel passes? I don't think that would work very well, and if you were trying to build a mechanism like that, you'd put the flywheel over the centreline of the displacer and arrange for the rim of the flywheel to be very close to the displacer case.
    So I'm stumped. Maybe the whole thing is a scam and it doesn't actually work.
    Edit: another idea. You could use the angle of the connecting rod (the angle from the vertical as it rocks side to side) to operate a sort of rocking lever mechanism inside the power piston - which would then cause the power piston to operate out of phase with the displacer. Seems a complicated and expensive way to do it though, and a two-throw-crank would likely be simpler, cheaper, and operate with less friction.
  • I am confused at the confusion. The black piston in the small tube will rise to vent steam and then fall. The connecting rod on top of that piston is attached the flywheel by an offset hub. As the flywheel rotates, the connected rod must rise and fall as the offset hub rotates.... Which is what steam would make it do. So, it should work like any other Sterling engine. Probably not too well though.
  • There's no steam in a standard Stirling motor - and no venting either. They use a so-called 'working fluid': often it's just air but sometimes it's compressed air or helium on some high performance models. Whatever the working fluid, it remains inside the motor and is alternately heated and cooled by moving it from the 'hot end' to the 'cold end'. This causes the working fluid to expand and contract, and this change in volume drives the power piston back and forth.
    I have a low-temperature model Stirling engine that has roughly the same layout as the one shown in this thread, but it does have a two-throw crank and is much better engineered with ball races on all the rotating joints. It only needs a temperature difference of four degrees or so between the hot and cold ends to run, so it will run by just standing it on your hand, using body heat, or by placing it on a running computer or television or similar, or even just from sunlight shining on it.
    I also built a small cheap engine from bits and pieces that ran - but it needed a much greater temperature difference. I used to stand it on top of a cup of boiling water which would just about make it run, or I could put it over a small flame or on a stove hot plate.
  • ercoerco Posts: 19,585
    Agreed, hard to discern the exact function from the photo. Of course, I have seen photos of broken/bent/misassembled parts and kits on Ebay, so it's possible that something is hinky with the item shown. Will advise upon receipt.
    Different model, but here's a video of one working atop a coffee cup.
    - Pablo Picasso
  • ceptimus wrote: »
    Right, in fact having the working fluid being in a closed system is essential. A tiny leak will render a Stirling cycle engine useless.
    The large displacer piston alternates moving the working fluid (air in all the hobby level engines) from the cold side to the hot side and back with every revolution of the flywheel. The working fluid either expands or contracts depending upon which side it is on. This expansion or contraction of the working fluid either pushes or pulls the power piston, driving the flywheel. The displacer piston must also be connected to the flywheel* in order for the timing of the movement of the working fluid from one side to the other.
    *There are a couple types of Stirling engine where the displacer piston is completely free, it either relies on resonance or pressure to move correctly. Neither seem to apply in this case.
    I do suspect that the image does not show the actual engine, but I kind of hope that it is real...
    edited 2018-12-16 - 16:33:53
    Here is a video (stolen) of my Stirling cycle engine that I built/machined about 10 years ago.
  • Could the clear plastic tower be hollow, and there is a rotary valve on the shaft?
    If noone else ordered one, I will post my result here when mine comes
    I am the Master, and technology my slave.
    edited 2018-12-16 - 19:06:40
    The_Master wrote: »
    The shaft does not rotate, you can see a bearing on the shaft upon which the flywheel spins.
    Even if that were not the case, how would a valve make it work?
    - Pablo Picasso
    Or if you have $60 to spend on a gift, here's a USB hub with lots of big red switches to trigger a self-destruct sequence. https://www.thinkgeek.com/product/jujk
    - Pablo Picasso
  • I think I have the answer. There is a small magnet on the bottom of the power piston that interacts with the displacer.
    edited 2018-12-17 - 18:19:23
    Clever sleuthing! Did you find one to examine? I haven't found any videos or reviews of this exact unit anywhere. It appears to be all clear plastic, where most Stirling engines have metal "cylinder heads" for improved heat transfer. It will be good to finally see one in action.
    - Pablo Picasso
  • erco wrote: »
    I found another (different brand) with a power piston right in the middle, it had pictures of the piston taken out with a magnet in the end.
    Being all plastic I doubt it will work as well as the ones with metal top and bottom plates. Plastic isn't exactly known for conducting heat well.
    Also $20/free ship from WM marketplace. Arrives after Christmas now...
    Here it is for $16.03 shipped: www.ebay.com/itm/Aibecy-Low-Temperature-Stirling-Engine
  • Don't suppose we could use an overclocked P2 as the heat source?
    Tubular wrote: »
    Makes sense to spin this motor via SPINning cogs.
    And run a more traditional engine block using BLOCKLY.
    - Pablo Picasso
  • Clock LoopClock Loop Posts: 1,604
    edited 2018-12-18 - 22:12:29
    Make mine UP built. Too bad its not 20$ (yes not the same as closed loop, but since were talking about heat transfer engines...)
    1.Silicon gel filled square. <-2.Sonics(ultra even). 3.Lazers. 4.?
    https://hackaday.io/project/162734-a-trillion-year-clock
    54 propeller chips connected, One to rule them all.
    https://forums.parallax.com/discussion/127983/55-parallax-propeller-s-parallells-processing-of-permanent-perturbations/p1
    Seriously contemplating removing ALL my content from the net completely, FREEDOM OF SPEECH IS DEAD.
  • AwesomeCronkAwesomeCronk Posts: 898
    edited 2018-12-19 - 03:43:03
    Another admirer?
    Sarcasm for English build 2019.12.30 released two days before New Year's! Ports to other languages are in progress and are expected to be finished by January 5, 2020.
  • lmclmc Posts: 3
    edited 2018-12-20 - 13:52:34
    For anyone interested in similar mechanisms, there's a website with loads of them - many of which are animated.
    http://507movements.com/about.html
    Mine arrived today and works great. Rich was right about the magnet linking the power & displacer pistons.
    - Pablo Picasso
    edited 2018-12-22 - 10:54:05
    Thanks for posting the video.
    The one I have, with a separate crank to drive the displacer, will only run in the one direction when you stand it over a cup of hot water. To get it to run the opposite way you have to make the top plate hotter than the bottom one - and one way to do that is to stand it on some ice cubes.
    I suspect your engine won't run in either direction when stood on ice - the magnet displacer coupling only works for the hot end being the bottom plate.
  • Neat!
  • So,
    It turns out this is a Stirling engine of the BETA configuration, and Wikipedia has a very nice diagram of how the various Stirling engines work.
    The clever part about the toy is that rather than use mechanically complex crankshaft arrangements, etc to provide proper piston phasing, it uses the natural hysteresis of application/deapplication of a magnet to a metal disc to achieve this mechanical effect.
    And rather than deal with the problems of a loose displacer piston in a necessarily large bore (cocking in the bore etc), it evidently is using a semi permeable foam disc which achieves the same thing.
    This is all interesting to me because up until now I never knew what a Stirling engine really was, although I knew that they are supposed to be extremely efficient
  • The_Master wrote: »
    For anyone interested in real world applications of stirling engines this video is worth watching.
    In science there is no authority. There is only experiment.
    Life is unpredictable. Eat dessert first.
