Nikos' Fibonacci Spiral Challenge
14567810»
  • ercoerco Posts: 19,441
    I am the walrus, I am the erco, koo koo kachoo!
    Nice try but no.
    "When you make a thing, a thing that is new, it is so complicated making it that it is bound to be ugly. But those that make it after you, they don’t have to worry about making it. And they can make it pretty, and so everybody can like it when others make it after you."
    - Pablo Picasso
  • Was just joking. :)
    Infernal Machine
  • Oh erco, just brilliant!
    smiling again, thanks
    edited 2018-05-19 - 17:12:33
    Is there no one who can code their robot to drive along these clearly intersecting spiral paths?
    857 x 960 - 87K
    - Pablo Picasso
  • Make one black square white, (double white squares). Move Bot with QTI sensors CW until it hits double white; turn slightly to the right to pick up the next sequence. Repeat until center.
    Infernal Machine
  • That completely made me cross eyed!!
    Amazing the way the brain works
    The thumbnail underneath not a problem..
    why?
    Dave
  • erco,
    That is wicked. You just crashed my brain.
  • Bot can probably be made to move to the next nearest square easily enough.
    Bot has a compass and/or giro such that it knows it's heading when started.
    Bot follows the circle it's on, next nearest square by next nearest square, until it's heading is the same as when it started. One revolution is then complete.
    Then bot veres off to left or right, depending which way we are circling, until it find the next inner circle.
    Repeat.
    edited 2018-05-21 - 01:09:30
    - Pablo Picasso
  • Actually, thinking about it, it's no more weird than all those spirals we see in the seeds of a Sunflower.
    You see, in reality there are no circles in that picture. Or spirals. They are just constructs of our minds. Why do we expect to see either?
  • WhitWhit Posts: 4,057
    edited 2018-08-30 - 03:51:40
    Whit+
  • Maybe Erco could modify his flame thrower to spray chalk instead!
  • NikosGNikosG Posts: 657
    edited 2018-09-06 - 07:18:32
    RS_Jim wrote: »
    I think that Erco must see that: https://sprayprinter.com/order/
    I think that the only have to do is to add a ColorPAL sensor on his flame thrower and will have a Spray printer!!!!
    The main idea behind this, is that when the color sensor detects a color in the walls surface (projected from an LCD projector) the valve push the spray to release the paint ...
    1280 x 1697 - 397K
  • Wow!
    Whit+
    Pretty sweet!
    - Pablo Picasso
