$1.78 USB Power Monitor
I might need two, since they come in clear and blue.
http://www.ebay.com/itm/USB-Charger-Doctor-Mobile-Battery-Tester-Power-Detector-Voltage-Current-Meter-G9-/161364003839
I wish I could make estimates like this at work. From the PayPal order confirmation:
http://forums.parallax.com/showthread.php/153786-Open-Propeller-Project-2-Envision-the-S3-Robot?p=1283435&viewfull=1#post1283435
OK - I ordered three. Might try to remove the USB ports to use standalone...
Of course, there are all kinds of cheap voltmeters/ammeters without USB:
http://www.ebay.com/itm/RC-Voltage-Lipo-Battery-Meter-Tester-Indicator-2-6-cells-LED-Panel-Voltmeter-S9-/310778768986?pt=LH_DefaultDomain_0&hash=item485bdbae5a
http://www.ebay.com/itm/0-30V-Red-LED-Display-Digital-Voltage-Voltmeter-Panel-Motor-Motorcycle-02-ERUS-/400705508624?pt=LH_DefaultDomain_0&hash=item5d4be8d510
http://www.ebay.com/itm/gib-New-Direct-Current-DC-0-36Inch-LED-Digital-Display-Voltmeter-Panel-/171334248571?pt=LH_DefaultDomain_0&var=&hash=item27e451287b
http://www.ebay.com/itm/1-3PCS-0-30V-Colors-Red-LED-3-Digital-Display-Voltage-Voltmeter-Panel-Motor-01-/380898759352?pt=LH_DefaultDomain_0&var=&hash=item58af55d2b8
http://www.ebay.com/itm/XD-3-New-0-36-Inch-LED-Digital-Ammeter-Amp-Current-Display-Panel-Gauge-DC0-1A-/111352636854?pt=LH_DefaultDomain_0&var=&hash=item19ed2265b6
They aren't that precise, I already own couple of them. And while their sense resistor is only 0.05 ohm, on charging actual device trough this, charge time increases 20-30%, have no idea why.
last year and made it display current for 4s, then flicker and display charge for 0.5s and flicker and
switch back to current. Monitoring charge is handy when I'm charging my phone
What is the difference between charge and current?
If only I got some kickbacks from Ebay, Paypal, and the "Free Shipping " Corporation.
I sure hope this stuff is better than CuriousOne reports!
http://www.ebay.com/itm/Mini-OLED-USB-Charger-Capacity-power-Current-Voltage-Detector-Tester-Meter-/281346507482
Gotta love this hoarder's review: You can never have enough Charger Doctors...
I figured it out: charge is sum(current). Presumably starting at 0 from when the monitor is plugged in.
Is that even possible?
How the heck could we have ever lived (if you can call it that) without these, blindly plugging in USB items and letting them charge willy-nilly?
Buy several extras for birthdays, bar mitzvahs, and stocking stuffers. Friends don't let friends charge blindly.
Although I did receive my fancy OLED one several days ago. So nanner nanner!
UPS has a big hub at Louisville WorldPort
'Still, still waiting...
Phil,
Where's the YouTube video of you singing that little ditty??
I received my OLED one today but it was DOA. :frown:
Darn. I also received five of these volt meters.
