"When you make a thing, a thing that is new, it is so complicated making it that it is bound to be ugly. But those that make it after you, they don’t have to worry about making it. And they can make it pretty, and so everybody can like it when others make it after you."
- Pablo Picasso
I wish I could make estimates like this at work. From the PayPal order confirmation:
- Pablo Picasso
RoboPi: The most advanced Robot controller for the Raspberry Pi (Propeller based)
Index of my projects and interesting forum posts
http://forums.parallax.com/showthread.php/153786-Open-Propeller-Project-2-Envision-the-S3-Robot?p=1283435&viewfull=1#post1283435
- Pablo Picasso
OK - I ordered three. Might try to remove the USB ports to use standalone...
youtube.com/user/MicroZapMan
Of course, there are all kinds of cheap voltmeters/ammeters without USB:
http://www.ebay.com/itm/RC-Voltage-Lipo-Battery-Meter-Tester-Indicator-2-6-cells-LED-Panel-Voltmeter-S9-/310778768986?pt=LH_DefaultDomain_0&hash=item485bdbae5a
http://www.ebay.com/itm/0-30V-Red-LED-Display-Digital-Voltage-Voltmeter-Panel-Motor-Motorcycle-02-ERUS-/400705508624?pt=LH_DefaultDomain_0&hash=item5d4be8d510
http://www.ebay.com/itm/gib-New-Direct-Current-DC-0-36Inch-LED-Digital-Display-Voltmeter-Panel-/171334248571?pt=LH_DefaultDomain_0&var=&hash=item27e451287b
http://www.ebay.com/itm/1-3PCS-0-30V-Colors-Red-LED-3-Digital-Display-Voltage-Voltmeter-Panel-Motor-01-/380898759352?pt=LH_DefaultDomain_0&var=&hash=item58af55d2b8
http://www.ebay.com/itm/XD-3-New-0-36-Inch-LED-Digital-Ammeter-Amp-Current-Display-Panel-Gauge-DC0-1A-/111352636854?pt=LH_DefaultDomain_0&var=&hash=item19ed2265b6
- Pablo Picasso
They aren't that precise, I already own couple of them. And while their sense resistor is only 0.05 ohm, on charging actual device trough this, charge time increases 20-30%, have no idea why.
- Pablo Picasso
P1 Prop OS (also see Sphinx, PropDos, PropCmd, Spinix)
Website: www.clusos.com
P1: Tools (Index) , Emulators (Index) , ZiCog (Z80)
P2: Tools & Code , Tricks & Traps
last year and made it display current for 4s, then flicker and display charge for 0.5s and flicker and
switch back to current. Monitoring charge is handy when I'm charging my phone
What is the difference between charge and current?
If only I got some kickbacks from Ebay, Paypal, and the "Free Shipping " Corporation.
I sure hope this stuff is better than CuriousOne reports!
- Pablo Picasso
- Pablo Picasso
http://www.ebay.com/itm/Mini-OLED-USB-Charger-Capacity-power-Current-Voltage-Detector-Tester-Meter-/281346507482
Gotta love this hoarder's review: You can never have enough Charger Doctors...
- Pablo Picasso
I figured it out: charge is sum(current). Presumably starting at 0 from when the monitor is plugged in.
Is that even possible?
How the heck could we have ever lived (if you can call it that) without these, blindly plugging in USB items and letting them charge willy-nilly?
Buy several extras for birthdays, bar mitzvahs, and stocking stuffers. Friends don't let friends charge blindly.
- Pablo Picasso
Although I did receive my fancy OLED one several days ago. So nanner nanner!
- Pablo Picasso
UPS has a big hub at Louisville WorldPort
'Still, still waiting...
Phil,
Where's the YouTube video of you singing that little ditty??
- Pablo Picasso
I received my OLED one today but it was DOA. :frown:
Darn. I also received five of these volt meters.
