HMC6352 Compass Module turn into a magnometer?
Would like some help with this project,would like to turn the HMC6352 Compass Module into a magnometer, also with LED's for the + & - ,and also do actual real time Graphing.. Anybody help with this project?
http://www.tuc.nrao.edu/~demerson/cs/magnet.htm
Also, there is this example that shows how the above units might be used.
But perhaps the compass modules are just as accurate???
For that module, there are some objects on the Propeller chip OBEX. See here. I think at least one of these displays on a TV, for example.
Also, I'm not sure you saw the supporting documents on this page for the HMC635 : http://www.parallax.com/StoreSearchResults/tabid/768/txtSearch/compass/List/0/SortField/4/ProductID/596/Default.aspx
