What parts do I need to this complete kit? — Parallax Forums
doggiedocdoggiedoc Posts: 2,257
edited 2011-02-18 16:09 in Propeller 1
Hi all -
I purchased 5 Schmartboard Modules from Fry's today, but unfortunately they don't come with the Prop chip and some other components.
I almost didn't buy them since I was going to have to order the parts anyway - but I wanted to support Fry's since they carry some Parallax inventory at all.
So... besides the Prop Chip and crystal, what do I need?
Any help is greatly appreciated,
Paul
  • damagedcellsdamagedcells Posts: 12
    edited 2011-02-13 18:46
    here is the pdf for the board
    http://www.parallax.com/Portals/0/Downloads/docs/prod/boards/27150-P8X32A-Q44Schmartboard-v1.2.pdf
    looks like a fair amount of the parts are missing
  • doggiedocdoggiedoc Posts: 2,257
    edited 2011-02-13 19:20
    Thanks for that link - I should make it clear that this is not the kit from Parallax directly. This is a kit that Fry's sells:
    http://www.frys.com/product/6250560?site=sr:SEARCH:MAIN_RSLT_PG
    I bought it know I needed to order parts - just thought I'd try to get it all on the same order.
  • ForrestForrest Posts: 1,341
    edited 2011-02-13 20:50
    The Parallax link above has a complete parts list on page 2
    edited 2011-02-14 02:13
    Looks like you need (part numbers in parens):
    the Prop (P8X32A-Q44)
    an eeprom (602-10001)
    the crystal (251-05000)
    2 10k resisters (150-01031)
    a 40 pin sip header that you will cut into 4 10 pin pieces (451-04001)
    a 2 pin header (451-00201)
    edited 2011-02-14 03:40
    Thanks Guys! Ya'll are the greatest!!!!
    edited 2011-02-14 04:30
    Doggiedoc, I look forward to hearing the results of your project. Sounds like you could make some really cool multi-prop stuff with 5 boards!
    edited 2011-02-14 14:55
    Still chewing on some ideas on that one Humanoido!
    Roy Eltham wrote: »
    Thanks Roy!!
    edited 2011-02-14 15:17
    Ooops. I can't find the resistors or the rubber feet on the Parallax Store - so I'm ordering 5 of the kits and can use the extras to flesh out these boards. I'll have to conjure up some rubber feet locally.
    So....... that means I'm going to have 10 little boards to play with!! (Don't tell my wife!)
    Paul
    edited 2011-02-14 16:54
    doggiedoc wrote: »
    \ I'll have to conjure up some rubber feet locally.
    Home Depot or Lowes will have rubber "cabinet door bumpers" in their hardware sections; they work the same as rubber feet.
  • jdoleckijdolecki Posts: 726
    edited 2011-02-15 04:16
    Wait till you try and solder R2 and R3
    I just finished mine
    12 dollars at frys chicago
    edited 2011-02-17 11:59
    Got the goods today!! It really came fast! I have learned that USPS gets here in about 3 business days where as UPS Ground takes 7-8. LOL
    edited 2011-02-17 13:00
    I almost always use USPS if I can - They're quick, and they're cheap. Why UPS ground is the de-facto is beyond me. You'll have to render an opinion on difficulty once you've had a chance to populate one of those boards. I'm curious as to how tricky that little eeprom is to solder.
    edited 2011-02-17 13:33
    @JasonDorie - I was just looking at that SMT eprom - it is very tiny!!
    As for the default to UPS over the faster, cheaper USPS - I suspect it's for accountability. You get insurance and tracking with UPS - good for buyer and seller.
    Paul
    edited 2011-02-18 11:07
    Just soldered on the first Prop, eprom, and crystal - but not found on in prop tool. I put sockets in for the crystal so I'm hoping that's it.
    OK, I'm a complete retard. The prop plug goes on flipped compared to the PEK. :D
