Need help on PWM
I have my project student to use Basic Stamp to control the speed of 4 independent motors. When she use the PWM command to control one motor, it works. However, when she uses the PWM command to control 2 motors, the motor speed reduces significantly.
When we use the oscilloscope to check the signal, we found the output to the motor has drop to zero for a period of time. She had upload the plots and we hope someone could shed some light.
Intererstingly, when she reduces the duration for the PWM command, the speed do increases. However, we thought the PWM duration is pre-determine by the RC filter. What are the effects if the duration is reduced ?
