Name It Win It Contest Closed - MicroPropPC - Page 2 — Parallax Forums
2
    edited 2011-01-10 23:50
    The Jazzy Computer
  • BaggersBaggers Posts: 3,019
    edited 2011-01-11 02:00
    How about
    SDRAMBox2
    as in
    SD RAMBO x2
  • MagIO2MagIO2 Posts: 2,243
    edited 2011-01-11 02:01
    I'd add 64MB of RAM and call it the P64² (it has 64 bit [2 propellers 32 bit each ;o] and 64MB then)
    inconvenient name: PC( $50726F70 )
    tinyPC where PC = Propeller Compunter
  • solarprismsolarprism Posts: 23
    edited 2011-01-11 03:39
    Propeller Super Power = PSP
    :D
  • BTXBTX Posts: 674
    edited 2011-01-11 03:50
    Nice board !! :)
    PROPERTON !!
  • blittledblittled Posts: 681
    edited 2011-01-11 04:03
    Nice work!
    Prop Squared
    Prop Hotrod
    BiProp
    SuperProp
  • jeff-ojeff-o Posts: 181
    edited 2011-01-11 04:50
    Easy:
    Turbine
    Though come to think of it, that would be a great name for the next-gen Propeller chip as well...
  • TrickTrick Posts: 8
    edited 2011-01-11 05:13
    Kitty Hawk - History first twin prop to fly.
    Lightning - P38 twin engine WWII fighter
    438 x 131 - 8K
  • ColeyColey Posts: 1,129
    edited 2011-01-11 06:04
    @Jazzed looks a great board well done!
    In fact you could say it was a bit of a beast so with that in mind I would call it Typhon.
    (The most deadly of all the beast from Greek mythology)
    I'm sure you'd have it running TyphOS in no time :lol:
    Coley
  • bsnutbsnut Posts: 521
    edited 2011-01-11 06:37
    Here is my names
    Propeller Jazz! (Technical Development Workstation)
    SpinPC
    PropPC
    edited 2011-01-11 07:33
    Propple //e
    edited 2011-01-11 07:42
    jazzed wrote: »
    Lots of interesting suggestions so far. Keep 'em coming. Thanks!
    Some Q&A's:
    @RobotWorkshop, I'll see if I have room for a small reset header; there is no more room on the front. I was thinking that since the reset button is through hole, it would be pretty easy to replace it with a cable if necessary. Is that solution a suitable substitute for a separate header?
    If there isn't room for a separate 2-pin header and you could just place those alon with the pads for the reset switch that would be fine. That way someone could install a 2-pin header instead.
    Most people tend to leave that out on boards but mount an acutal switch on the board instead. My preference is the two pin header with an option for an onboard switch. I've got a bunch of cables with 2-pin connectors and it makes it so easy to mount a remote reset switch if you add the pads. Alternately you can just solder it tothe board but I like having a plug.
    Lately I've been using more than one board in my robot projects and I've had to add headers like this to the boards so I can more easily make a master reset for everything at once. I keep poking at Parallax to consider doing the same to all their development boards too....
    Robert
  • jazzedjazzed Posts: 11,803
    edited 2011-01-11 10:03
    Great suggestions everyone! There are a few names very high on my list.
    I will choose the name before 4PM PST today.
    The prototype PCB fabrication must start today to meet my schedule.
    Someone mentioned it would be hard to choose. It is, but it's a good problem to have.
    The product will be available by the following SKUs (Stock Keeping Unit):
    <name>-nMBbRc - where:
    n = 8,16,32,64,or 128 MB SDRAM
    b = C for CoinCell or X for external RTC battery.
    c = front/back-panel color option if available.
    @RobotWorkShop, I've found room for a 2 pin header nestled between the mounting pins of the right-angle reset push-button.
    @william chan, I really would like to put the power complex on the back and the USB connectors on the front, but that is a significant challenge at this point. I'll see what I can do.
    Thanks for all the suggestions.
    edited 2011-01-11 11:31
    Sonic PPC
    PDS PPDS personal propeller dev station
    RPDC rapid propeller dev computer
    Zen! RPDC. RPDS
    PPC Jazz! (Could be extended to different products such as Zen Tiger Model 1 2, etc)
    Xtreme PPC. Xtreme RPDC
    Xtreme PPC DUO
    RTDE Jazz! ; jazz RDC.
  • base2designbase2design Posts: 78
    edited 2011-01-11 12:09
    I'd call it "Miles" or "Davis", because it's real cool and a little dangerous.
    -j
  • TubularTubular Posts: 4,740
    edited 2011-01-11 12:46
    P8x32x2x134217728A
    2 props, 134217728 bytes = 128MB :)
  • ajwardajward Posts: 1,130
    edited 2011-01-11 12:59
    The Wowcard!
    edited 2011-01-11 14:42
    I have a list of finalists, but only a few of them make sense with a logo.
    Maybe there are some easily "pictured" suggestions out there?
    I have another idea but no one would get credit for it as of now.
    edited 2011-01-11 15:42
    How about Propeller Typhoon you could do a nice logo with that too.....
    Something like this.
    600 x 400 - 32K
    edited 2011-01-11 16:14
    Well, I have to extend the contest to tomorrow since there are so many options.
    Here's the short-list:
    Propulsion - ambroxio
    PropDuo - Rsadeika
    PropellerT16 - Roy Eltham
    ProperTon - BTX
    JazzPC - Brian Riley
    JazzedUP - Duane Degn
    TheJazz - Heater
    Turbinator - Baggers
    Propinator - Shawn Lowe
    Turbine - jeff-o
    Typhoon - Coley
    SpinPC - bsnut
    MicroProp - potatohead
    PocketPropPC - idbruce
    ZZProp - ravenkallen
    Other names with more visual opportunities will be considered. More pictures please :)
    Some things I've definitely ruled out:
    PropBox & PSP - used by Rayman
    TurboProp - reserved as Parallax Propeller2
    ScrewPC - name of a propeller on a ship
    AnyThingBlade - Cluso99's "line"
    Something I've seriously considered with attached etch-able logo is "Propagator"
    240 x 120 - 11K
  • BTXBTX Posts: 674
    edited 2011-01-11 17:20
    Sorry, not enough time to play with, this week for me, but this is one, catch the idea.
    400 x 360 - 7K
    edited 2011-01-11 19:14
    Steve, I like the propagator, but you will require 2 gators in the pic indicating 2 props :)
    However, if you expect a line of prop pcbs then you need to think this through too.
    edited 2011-01-11 19:44
    Well, here's my picture....
    I've got this drawn in vectors, so fonts, scaling, etc... all can change. Let me know.
    1024 x 333 - 27K
  • ambroxioambroxio Posts: 17
    edited 2011-01-11 20:11
    Biplane (except biplane refers to 2 wings and not 2 propellers )
    Propcopter ( helicopters have 2 propellers )
    Dioscuros ( Castor and P
  • zoopydogsitzoopydogsit Posts: 174
    edited 2011-01-11 21:49
    Going with the Jazz theme, and two musicians is a Duo then;
    JazzDuo
    Jazz-Duo
    http://en.wikipedia.org/wiki/Musical_ensemble
    edited 2011-01-12 01:48
    Thinking along the propcopter line, like ambroxio, what about
    The Chinook
  • BTXBTX Posts: 674
    edited 2011-01-12 04:09
    Here's another one.
    152 x 48 - 6K
  • RS_JimRS_Jim Posts: 1,773
    edited 2011-01-12 05:54
    Hi Jazzed,
    How about SirPropalot, Picture Mounted Lancelot figure with a twin Prop Beenie!
    RS_Jim
    edited 2011-01-12 07:42
    @Bruce, surely there should be a beanie on each cheek! :lol:
  • AntoineDoinelAntoineDoinel Posts: 312
    edited 2011-01-12 08:04
    Hi Jazzed
    don't know if I'm late to the party, anyway here's my suggestion: SupraDynaProp (pun intended ;-))
    I also have a question (didn't have the time to accurately read the whole thread, sorry if you already answered this): I can see two SDRAMs on the component drawing, but I can't see any specific mention in the description. Is that a second one accessable from the other prop (i.e. for graphics)?
    Regards
    Alessandro
