About the StingRay... — Parallax Forums
RambomanRamboman Posts: 101
edited 2011-01-12 02:00 in Robotics
I was so happy to get a StingRay with the Ping kit for X-mas. My project is to develop a remote controlled robot with X-Bee's. I have some practice with the Propeller and before with the SumoBot...
I made only one modification : I replaced the old fashioned NiMh cells with a 2s LiFe pack... no problem...
Several days later, today... I connect the StingRay to my PC to start programming... no current...
Check with the multimeter : pack at 0.7V... so low that the even my charger refuse to charge it... I had to get around with my lab power supply...
What happend ? The switch was on OFF !
Funny design... the switch DOES NOT cut power... the pack discharged on God knows what.
Fortunately, LiFe are strong enough, they will recover...
Next modifications : a MAIN switch... recommended to all users
    edited 2011-01-10 08:27
    Nice to hear you like your Stingray! The main board uses a 3-position switch. There is an all-off position at one end, which completely disconnects the battery. The center position is "electronics on, motor off" (useful for bench testing) and the other end is "electronics and motor on".
    Are you certain you didn't leave it in the middle position, which would still drain your batteries eventually? Always make sure the LEDs near the barrel jack are off.
    edited 2011-01-10 08:30
    This is a known issue. Even in the "all off position" the WIN still goes to the H-Bridge and the VIN connections on the board. You have to disconnect the battery completely to keep it from being slowly drained.
    Ken has already posted a reply to another thread with a list of known issues that are going to be addressed soon (this is one of them).
    edited 2011-01-10 08:35
    The thread that Roy mentions is located here:
    http://forums.parallax.com/showthread.php?127511-Stingray-Plans-question-for-Ken
    It is worth reading!
    Robert
  • WhitWhit Posts: 4,194
    edited 2011-01-10 08:59
    I second reading Ken's update on the Stingray thread. erco is right (and you were too) - the general assumption is that off is off. Though not in this case!
    I would add that even with the addition of a master off switch - I alway disconntect or remove the battery after use.
    edited 2011-01-10 09:03
    I DID assume! And you know what that leads to...
  • RambomanRamboman Posts: 101
    edited 2011-01-11 00:31
    Going (slowly) further...
    Loading "ping" program... no reaction...
    Loading "motor test" program... no reaction...
    Loading "led test" program, with those funny transistors (never used them before... translators ?)
    Strictly following instructions... searching transistor connection on web... it works ;-)
    At least board is not dead on arrival...
    Loading "motor test" again AND moving switch a lot... now it works... bad contact ?
    Testing both motors... OK
    Reloading "ping" program... nothing... why ?
    Now trying to understand "ping" program... very confuse...
    PWMx8 ???
    Will rewrite it my way...
    Or drop the whole bord and use a simple USB propeller and a motor driver...
    That board introduces useless complexity...
    Why make it simple if we can make it complex ?
    Going further...
    Rewrote the "mvsr" move stingray...
    'My StingRay v0
    CON
    _clkmode = xtal1 + pll16x
    _clkfreq = 80_000_000
    sp = 127
    OBJ
    pw : "pwmx8"
    VAR
    PUB main | lp, rp 'left & right pulse
    'initialize
    pw.start(24, %00001111, 23_000) 'start pwmx8 for 24..27 @ 23kHz
    'main loop
    mvsr(sp, sp)
    waitcnt(clkfreq + cnt) 'forward for 1 sec
    mvsr(0, 0)
    waitcnt(clkfreq + cnt) 'wait for 1 sec
    mvsr(-sp, -sp)
    waitcnt(clkfreq + cnt) 'backward for 1 sec
    mvsr(0, 0)
    repeat
    PUB mvsr(lw, rw) 'set left & right wheel from -255 to +255, 0 = stop
    lw := -255 #> lw <# 255
    rw := -255 #> rw <# 255
    ifnot lw & $80_00_00_00
    pw.duty(24, 0)
    pw.duty(25, lw & $ff) 'left forward
    else
    pw.duty(25, 0)
    pw.duty(24, (0-lw) & $ff) 'left backward
    ifnot rw & $80_00_00_00
    pw.duty(27, 0)
    pw.duty(26, rw & $ff) 'right forward
    else
    pw.duty(26, 0)
    pw.duty(27, (0-rw) & $ff) 'right backward
    Loading... FLOP...
    Moving switch a lot... OK...
    Probably bad quality switch...
    Will go further with compass...
