About the StingRay...
I was so happy to get a StingRay with the Ping kit for X-mas. My project is to develop a remote controlled robot with X-Bee's. I have some practice with the Propeller and before with the SumoBot...
I made only one modification : I replaced the old fashioned NiMh cells with a 2s LiFe pack... no problem...
Several days later, today... I connect the StingRay to my PC to start programming... no current...
Check with the multimeter : pack at 0.7V... so low that the even my charger refuse to charge it... I had to get around with my lab power supply...
What happend ? The switch was on OFF !
Funny design... the switch DOES NOT cut power... the pack discharged on God knows what.
Fortunately, LiFe are strong enough, they will recover...
Next modifications : a MAIN switch... recommended to all users
Are you certain you didn't leave it in the middle position, which would still drain your batteries eventually? Always make sure the LEDs near the barrel jack are off.
Ken has already posted a reply to another thread with a list of known issues that are going to be addressed soon (this is one of them).
http://forums.parallax.com/showthread.php?127511-Stingray-Plans-question-for-Ken
It is worth reading!
Robert
I would add that even with the addition of a master off switch - I alway disconntect or remove the battery after use.
Loading "ping" program... no reaction...
Loading "motor test" program... no reaction...
Loading "led test" program, with those funny transistors (never used them before... translators ?)
Strictly following instructions... searching transistor connection on web... it works ;-)
At least board is not dead on arrival...
Loading "motor test" again AND moving switch a lot... now it works... bad contact ?
Testing both motors... OK
Reloading "ping" program... nothing... why ?
Now trying to understand "ping" program... very confuse...
PWMx8 ???
Will rewrite it my way...
Or drop the whole bord and use a simple USB propeller and a motor driver...
That board introduces useless complexity...
Why make it simple if we can make it complex ?
Rewrote the "mvsr" move stingray...
'My StingRay v0
CON
_clkmode = xtal1 + pll16x
_clkfreq = 80_000_000
sp = 127
OBJ
pw : "pwmx8"
VAR
PUB main | lp, rp 'left & right pulse
'initialize
pw.start(24, %00001111, 23_000) 'start pwmx8 for 24..27 @ 23kHz
'main loop
mvsr(sp, sp)
waitcnt(clkfreq + cnt) 'forward for 1 sec
mvsr(0, 0)
waitcnt(clkfreq + cnt) 'wait for 1 sec
mvsr(-sp, -sp)
waitcnt(clkfreq + cnt) 'backward for 1 sec
mvsr(0, 0)
repeat
PUB mvsr(lw, rw) 'set left & right wheel from -255 to +255, 0 = stop
lw := -255 #> lw <# 255
rw := -255 #> rw <# 255
ifnot lw & $80_00_00_00
pw.duty(24, 0)
pw.duty(25, lw & $ff) 'left forward
else
pw.duty(25, 0)
pw.duty(24, (0-lw) & $ff) 'left backward
ifnot rw & $80_00_00_00
pw.duty(27, 0)
pw.duty(26, rw & $ff) 'right forward
else
pw.duty(26, 0)
pw.duty(27, (0-rw) & $ff) 'right backward
Loading... FLOP...
Moving switch a lot... OK...
Probably bad quality switch...
Will go further with compass...
