Programming woes with TAB sumobot
Hi all,
we recently received a second TAB sumobot and had great fun building it as a family. It is a great startup bot to build with 6 year olds. Though it is working fine with the supplied remote control and pre-programmed behaviors, we have had ZERO success trying to program the onboard BS2. We tried:
1. installing the supplied IDE in an old XP laptop and using the built-in serial port. We used a straight-through serial cable here.
2. using the most recent parallax IDE in a mac with a USB-to-serial adapter cable. We use this regularly to program a more advanced Sumovore with BS2 (from Solarbotics)
3. using the above USB-serial cable on a Netbook running Win7 and latest parallax IDE.
When I attempted to identify the onboard BS2, I get a YES for loopback and echo. But device type and version come out blank :-(
Any suggestions?
Thanks in advance.
Any suggestions?
Thanks in advance.
I have some of the TAB "build your own robots" where there is an empty socket for a BS2-IC. The pre-programmed behaviors are in hardware in that robot, perhaps similar to yours. That is, the remote and behaviors may work even if the BS2 doesn't.
Sorry for not clarifying. I am not able to program either of them. We have had one for about three years and I never got around to programming it (or even trying). When we got the second one few months ago, I thought it might be worth it to try to program the bots and that's when I noticed that I am not able to program them.
The cables do work on the third sumobot we have. The third one has a removable BS2 module and it is a completely different beast (Sumovore by Solarbotics). The issues I am experiencing are with the two TAB sumobots. As mentioned in another reply above, the TAB sumobots have soldered-in BS2 chips and they are not removal.
Was that the original DOS PBasic editor you tried? That's almost as old as your Sumobot, it may work...
The year was 1995. The BS2 was new. The only option was DOS, Win95 was barely in its infancy. START IT UP!
I started programming on an old monochrome Compaq LTE286 laptop. AND LIKED IT FINE!
Yeah... but it's a pain to browse the web with it! :-) (Lynx anyone?)
Bill
