[resolved][puzzle] substitute
Not much of a challenge I admit. But it's SPIN-only so maybe not too scary. Anyway, longfill is on holiday and longmove has to fill in. What would a replacement function look like? Just complete the template function and if it's not too much trouble attach it as SPIN source rather than a [noparse]
[/noparse] block.
See postings #14 and #15 for possible solutions (which I had in in mind that is).
PRI longfill_using_longmove(StartAddress, Value, Count)
if Count
' longfill replacement code
I believe that Spin is smarter than that. IIRC, it always selects a move order to avoid stepping on its own toes -- assuming that's what you had in mind.
Having been playing with Fast Fourier Transform recently the answer is obvious, divide and conquer and do it recursively. Full solution in a test harness attached.
PRI longfill_using_longmove(StartAddress, Value, Count) if Count 'longfill replacement code longmove(StartAddress, @Value, 1) 'Fill in the first element longfill_using_longmove (StartAddress + 4, Value, Count - 1) 'Then fill in the rest
Edit: Oops...Had a bug in my first line,OK, just checked your code and there it reads "1".
"Wasted time" Who said anything about efficiency?
Fair enough, given that this is only a theoretical exercise
FWIW, trigger for this challenge was a (now void) requirement to copy a block of memory from DAT to VAR without having overlap protection kick in (i.e. I wanted the first long transferred first).
PRI longfill_using_longmove(StartAddress, Value, Count) 'longfill replacement code if Count == 1 longmove(StartAddress, @Value, 1) 'Fill in the only element elseif Count > 1 longfill_using_longmove(StartAddress, Value, ((Count+1) / 2)) 'Fill in the first half longfill_using_longmove(StartAddress + (Count / 2) * 4, Value, ((Count+1) / 2)) 'Fill in the second half
Edit: Fixed Baggers zero length Bug.Not more serious than heaters code, but much more efficient...
and with testcode that shows that it works!
_clkmode = xtal1 + pll16x _xinfreq = 5_000_000 OBJ term: "Parallax Serial Terminal" PRI longfill_using_longmove(StartAddress, Value, Count) if Count longmove(StartAddress, Value, Count) PUB testcode | p 'start terminal and wait 5 seconds term.start(115200) waitcnt(clkfreq*5-(byte[$69]-=4) + cnt) 'use the new methode longfill_using_longmove($7000, $11223344, 16) 'show written memory on terminal repeat p from $7000 to $703F step 4 term.hex(long[p], 8) term.char(13)
Andy
Honestly, who would be so daft as to want to fill a zero length buffer....
Andy
+10 (that's similar to what I used)
PRI longfill_using_longmove(StartAddress, Value, Count) if Count long[StartAddress] := Value longmove(StartAddress + 4, [COLOR="red"]NEGX|[/COLOR]StartAddress, Count - 1)
