[resolved][puzzle] substitute — Parallax Forums
kuronekokuroneko Posts: 3,623
edited 2010-12-27 05:39 in Propeller 1
Not much of a challenge I admit. But it's SPIN-only so maybe not too scary. Anyway, longfill is on holiday and longmove has to fill in. What would a replacement function look like? Just complete the template function and if it's not too much trouble attach it as SPIN source rather than a [noparse]
[/noparse] block.
PRI longfill_using_longmove(StartAddress, Value, Count)
  if Count
    ' longfill replacement code
See postings #14 and #15 for possible solutions (which I had in in mind that is).
    edited 2010-12-27 00:39
    kuroneko,
    I believe that Spin is smarter than that. IIRC, it always selects a move order to avoid stepping on its own toes -- assuming that's what you had in mind.
    edited 2010-12-27 00:44
    When did impossible ever stop us? There is a solution (or I wouldn't have posted the challenge).
    edited 2010-12-27 00:55
    Who said impossible? It's just that the obvious solution can't be the right one. And since you're the one posing it, I assume it has something to do with a quirk in the byte code interpreter -- perhaps doing the "wrong" thing with negative addresses or positive addresses beyond $ffff. :)
    edited 2010-12-27 01:05
    kuroneko,
    Having been playing with Fast Fourier Transform recently the answer is obvious, divide and conquer and do it recursively. Full solution in a test harness attached.
        if Count
            'longfill replacement code
            longmove(StartAddress, @Value,   1)                       'Fill in the first element
            longfill_using_longmove (StartAddress + 4, Value, Count - 1)  'Then fill in the rest
    Edit: Oops...Had a bug in my first line,
    edited 2010-12-27 01:10
    @Heater: I sure hope you mean longmove(StartAddress, @Value, 1)! While it doesn't do any harm it's obviously wasted time ;)
    OK, just checked your code and there it reads "1".
    edited 2010-12-27 01:12
    Yep, fixed as you post.
    "Wasted time" Who said anything about efficiency?
    edited 2010-12-27 01:40
    Heater. wrote: »
    Fair enough, given that this is only a theoretical exercise ;)
    FWIW, trigger for this challenge was a (now void) requirement to copy a block of memory from DAT to VAR without having overlap protection kick in (i.e. I wanted the first long transferred first).
    edited 2010-12-27 02:19
    In the interests of algorithmic symmetry, obfuscation and inefficiency and end of year fun I prefer a solution with more elegance like this:)
        if Count == 1
            longmove(StartAddress, @Value, 1)                                           'Fill in the only element
        elseif Count > 1
            longfill_using_longmove(StartAddress, Value, ((Count+1) / 2))                    'Fill in the first half
            longfill_using_longmove(StartAddress + (Count / 2) * 4, Value, ((Count+1) / 2))  'Fill in the second half
    Edit: Fixed Baggers zero length Bug.
  • BaggersBaggers Posts: 3,019
    edited 2010-12-27 02:57
    Heater, you forgot it Count==0 ?
  • AribaAriba Posts: 2,695
    edited 2010-12-27 03:14
    OK here is my solution
    Not more serious than heaters code, but much more efficient...
    and with testcode that shows that it works!
    _clkmode = xtal1 + pll16x
      _xinfreq = 5_000_000
    OBJ  term: "Parallax Serial Terminal"
      if Count
    PUB testcode | p
      'start terminal and wait 5 seconds
      term.start(115200)
      waitcnt(clkfreq*5-(byte[$69]-=4) + cnt)
      'use the new methode
      longfill_using_longmove($7000, $11223344, 16)
      'show written memory on terminal
      repeat p from $7000 to $703F step 4
        term.hex(long[p], 8)
        term.char(13)
    Andy
    edited 2010-12-27 03:28
    @Andy: Byte code patching doesn't count, sorry! ;) But 10 points for hiding it cleverly.
    edited 2010-12-27 03:36
    Baggers, OK fixed that.
    Honestly, who would be so daft as to want to fill a zero length buffer....
    edited 2010-12-27 04:49
    Attached is my serious solution. Hope I get another 10 points...
    Andy
    Ariba wrote: »
    +10 (that's similar to what I used)
      if Count
        long[StartAddress] := Value
        longmove(StartAddress + 4, [COLOR="red"]NEGX|[/COLOR]StartAddress, Count - 1)
