Please test URL for Spinneret Web Server — Parallax Forums
Mike GMike G Posts: 2,702
edited 2011-09-13 00:05 in Propeller 1
All;
Please try to hit the following URL. It's my Spinneret web server.
http://spinneret.servebeer.com:5000/index.htm
http://68.99.244.218:5000/index.htm
  • SapiehaSapieha Posts: 2,964
    edited 2010-12-23 10:46
    Hi Mike G
    FireFox not complain But them not show anything
    edited 2010-12-23 10:47
    I tried this and it bounced the first time but displayed your web page on the second try.
  • Mike GMike G Posts: 2,702
    Thanks, I'm seeing hits but the headers seem to be empty.
    edited 2010-12-23 10:48
    Can someone try the login page? Just do a post, submit.
    edited 2010-12-23 10:50
    Hi Mike G.
    I still can't see anything on this page (Blank)
    edited 2010-12-23 10:54
    Mike G wrote: »
    I tried this and got to the login form but when I submitted my filled in form I get "erver unexpectedly dropped the connection".
    edited 2010-12-23 10:57
    Wow, there was/is a lot of traffic for the Spinneret. I only have one socket wired up so I image there would be drop connections.
  • KyeKye Posts: 2,200
    edited 2010-12-23 11:00
    I got... internet explorer could not display this webpage.
    Thanks for testing. I logged as much as I could. Now back to work.
    edited 2010-12-23 11:03
    Thanks Kye, I'm using you FAT 2.0 to serve up static and dynamic pages
    edited 2010-12-23 11:43
    I made some changes. If you all do mind, please try to hit the URL again. Thanks
    edited 2010-12-23 11:48
    Ok, I had to make another change... I'm seeing requests go through now.
    edited 2010-12-23 11:49
    I'm using Safari Version 5.0.3 and it's looking good.
    edited 2010-12-23 11:52
    Hi Mike.
    Now it function for me to
  • Cole LoganCole Logan Posts: 196
    edited 2010-12-23 11:53
    Thats really cool. All seems to be working for me.
    I just got my spinneret today so hopefully I will get to play with it soon
  • hover1hover1 Posts: 1,929
    edited 2010-12-23 11:54
    Working fine with Google Chrome. Login successful.
    Jim
    Thank you so much for testing. I had to reset the server a few times. One socket is not enough but it worked better than I thought. Some folks requested the pdf. Was anyone able to download the pdf successfully?
  • RavenkallenRavenkallen Posts: 1,057
    edited 2010-12-23 12:05
    It worked for a bit than Firefox said "the connection has timed out"
    edited 2010-12-23 12:15
    I was able to get the PDF to download.
    Would it be possible for you to post the code your useing.
  • Ray0665Ray0665 Posts: 231
    edited 2010-12-23 13:02
    Tested all the links worked just fine...
    I'm using Opera V10.10 (64bit) running on Mandriva 2009 64 bit distribution
    edited 2010-12-23 15:30
    I got the "spineret is down for maintenance"
    edited 2010-12-23 17:46
    Thanks for checking, I took the spinneret offline and redirected traffic to another web server.. That way folks receive a friendly descriptive message.
    edited 2010-12-25 10:11
    Happy Holidays All;
    If you guys don't mind, please try to hit the spinneret URL - first post. I added timeout logic and encoding. Just curious if the Spinneret web server can handle the load any better.
    edited 2010-12-25 10:21
    Using Safari Version 5.0.3, things seem to look good. It took about 1.5 minutes for the pdf of the manual to show up.
    Keep up the good work!
    edited 2010-12-25 10:24
    Thanks that helped out a lot, I made an adjustment during the testing. Seems that my internet connection is a little slow today. I saw the pdf go... didn't think it took over minute though. I'm just glad it the pdf made it to its destination.
    edited 2010-12-25 10:32
    Hi Mike.
    On my end I had 15KB downstream --- NOT so bad.
    Have downloaded that PDF to
  • bsnutbsnut Posts: 521
    edited 2010-12-25 21:29
    Mike,
    I tried your link with my phone using the Dolphin HD and it states that it's unavailable. This maybe due to my phone's browser. I will try it with my laptop later today to see works. If it doesn't work, I will have to wait for you to get it back on line.
  • coffeelovecoffeelove Posts: 14
    just hit every link visible on chromium ( ubuntu 11.04 ) and only had some display issues upon first load. other than that, seems to be working like a champ. leeched you *downloads* page, and it kept up. :)
