Player x ISD 1760
Friends, help me please,
I need to assemble a player, as simple as possible for an ISD1760 chip corder. The board only needs to have PLAY BOTTON, FORWARD and ERASE, a 5V regulator and nothing more. The output will go to powered speakers the my computer.
Please help me with the layout, because I have urgency to introduce this project.
Already, many thanks.
Mafoni
Mafoni
Can you post some doc's on the ISD1760 chip?
This sounds pretty simple with enough info.
There goes a friend!
I'm a little confused at what your after? Do you need help with a PCB layout?
Where does the BS2 fit-in?
I'll put an RC model boats and just need the sounds. Be triggered by radio transmitter (Tx) + bit switch with the receiver (Rx). The sounds are recorded in chipcorder through the recorder whose project was sent in the previous question.
MAFONI
