This: 0011 is not the same as this: '0011'
Here is a little code problem which could drive someone nuts...
I copied an example from a pdf file and it had this...
0011
But that did not work! Instead I needed this...
'0011'
is ASCII hex 92
' is ASCII hex 27
255 character ASCII Chart...
http://www.aboutmyip.com/AboutMyXApp/AsciiChart.jsp
0011
'0011'
is ASCII hex 92
' is ASCII hex 27
"This is a string."
I get
“This is a string.”
which can't be copied and pasted into a code editor and expected to run. It's really annoying.
Huh? Wha? A Microsoft product that causes computer glitches of one kind or another?
I'm.... I'm shocked!
