XBee firmware
I had a hard time downloading the new versions with my windows 7 laptop.
found the ftp on xbee. and used the file insted of web.
http://ftp1.digi.com/support/firmware/update/xbee_zb/
The file i needed is attached.
I may be mistaken, but I think I've found that older versions of XCTU do not find the most current firmware, even when you ask them to search online for that firmware. I had some new XBees that had pre-installed firmware that I was unable to read with my roughly three year old version of XCTU. I just installed an up-to-date version, and it does find that new firmware.
In short, it's important to keep your XCTU version up to date. I agree that it's by far easiest to update firmware with XCTU (and with the Parallax USB adapter board). When I compare this with what I used to go through (wiring up a serial adapter...), it's heavenly.
