Let's back up and try again
Phil Pilgrim (PhiPi)
Based on what I've seen so far, I would not say the forum migration has been successful. I will say that the new search function seems to work very well. But so much valuable content (images, inline formatting, etc.) has been broken in the transfer that I would rather see a return to the old forum than what we have now. Frankly, I would be happy simply to lose today's posts on the new forum and return to the old one until these migration issues can be straightened out.
The issues can be corrected. I don't know that backing up and trying again latter is going to help these issues any. Having done similar types of conversion/migration of different types of systems in past and current lives, it may be just as easy to "fix" things in the current dataset as try and create a new one. Very often, when you "fix" one set of problems, you create another.
It may be easier to just do a number of "if the post has xxx, then do yyy" then do the whole thing over.
Let's give Jim a chance to look things over.
Images corrupted may be a size issue. There loss is also a big loss. The images in a post are key to the post and I have wondered about size and storage space for them. Even as jpg images they can get large. What if any is the image size limit of the new forum?
Without the lost information the new forumn is like starting over and throwing away the old one.
Tom
I certainly don't mean to impugn Jim's efforts here. I know it's a Herculean task. But I'm not sure enough of the "xxx" remains in the transferred posts to "do yyy". And the old posts are simply too valuable to take that chance. We can still go back today. Tomorrow it could be too late.
Again, pure speculation on my part.
Obviously I do not know what is possible to correct. I have done conversions of databases in the past and it really depends on the issues and tools available and only Jim can decide if it can be rectified later, or a reversion to the old forums are required. I know it's a huge task.
I am presuming we will be able to get to our old PMs (mailbox) later as stated elsewhere. I have also noticed the signature is significantly smaller - mine gives a lot of links in the signature to old threads.
But complete and correct transfer of past posts is a b.f.d. (to quote our Vice President) and has to be done right. Without that, the forum suffers a tremendous loss in value, both to us forumistas and to Parallax. If that can't be corrected after the fact, we need to back up and start over.
Second, the "default" date cutoff for showing threads in a given category needs to be changed. It took me quite a bit to figure out why I could only see 14 completed pages (rather than many, many pages of completed projects).
I had to change the settings in my profile to show all threads from the "beginning" rather than the forum default, which seems to be 30 days?
Last but not least, pictures seem to be enabled for a user's profile page but avatars on posts seem NOT to be enabled, as there is no way to upload or link to an avatar graphic.
Seconded. I don't mind missing PMs or subscriptions (still annoying though) but that the conversion removed all whitespace (per line) from within code tags is not acceptable.
FWIW, I reported this issue back in February (2/21) when migration started.
Even worse, all my saved PM's are gone.
http://forums.parallaxinc.com/forums/default.aspx?f=25&m=307271
to
http://forums.parallax.com/showthread.php?t=108002&highlight=direct+flag+manipulation
This is not even remotely acceptable! I put a lot of effort into my forum contributions. To see them butchered in this fashion really roasts my @$$!
Could we maybe be a little patient?
Could we maybe all take some time and read some of the posts and replies in this section (I seem to recall about at least a half dozen people panicking about losing PMs - they are safe and sound over at http://forums.parallaxinc.com/forums)?
This wasn't "popped on us" without warning. This isn't the end of the world. It is not obviously not "right", but it's also obviously not "done" either.
Let's all chill a little, and work through the issues.
John R., Beaver Dam, Wisconsin
I appreciate your call to temperance; and I would agree if I believed the clobbered posts could (and would) be fixed post-migration. But I'm not convinced of that. And given the rapidly accumulating collection of new posts, I feel that it's prudent to raise an alarm now, in no uncertain terms, and reverse this situation before we reach a point of no return. (We're not there yet, but time is running out.)
If I'm wrong about the immediacy and gravity of these issues, I shall be happy to eat my words when they're resolved. But, for now, there's no time to waste in going back if there's any chance that they cannot, after all, be put right.
This forum is your bread and butter, AFAICT.
Can't we try them in parallel and just switch when the new one is cleaned up and working? I for one didn't get any notice. I just tried to get in and got a 404 error.
Search capability will be a big bonus, however. To me, that should be an incremental addon, not a total rewrite of the forum. Maybe I'll come back in a week or so. Please tell me sooner if you decide to abort and take a less painful approach.
Doug
Now, I'll mirror your post, and if this is not the case, I'll eat my words, and be right there with you asking for the roll back...
I'll still go back to the thought "do you really think Parallax would allow this" and have to believe that even if they don't yet know "exactly how", the at least know in concept that they have a way to get this fixed.
Make no mistake, the problems are serious, and need to be addressed, in some way shape or form. I'm not saying "roll with it", I'm saying "these guys will get it fixed".
Hey, I'm just a hobbyist. Some (many) of you guys have your livelihoods based on this stuff, and rely on these forums for your daily bread. Parallax sees us all as "partners", and I don't believe they will leave us in the lurch.
John R.
Beaver Dam, WI
It had to be retired. I too have seen the death of some well thought out link posts, like that of the Hydra sticky thread that I took over when Paul left. For that matter I have an entire website of links which are now worthless. I'm already planning to rebuild those indexes as soon as time permits.
Change is ALWAYS uncomfortable. In the case of the forum software is was necessary.
I'm sure that we will see hundreds of adjustments, improvements, and fixes as we move forward. Let's give Parallax (ie: Jim) a chance to address these issues before everyone looses their minds.
I've already started playing with the new search abilities of this forum and LOVE IT! I was able to find CassLan's original PrEditor post within a couple pages. I would have NEVER found it in the old forum software without a link.
Come on guys.. If nothing else, drop off for the weekend and go DO SOMETHING on the prop.
OBC
Believe me, I like the new vBulletin forum software, too, and would not ever advocate returning to the old stuff permanently. But I think the migration was done far too prematurely, leaving issues that should have been worked out ahead of time. My fear is that by not taking a step back now, until these things can be taken care of, some of them can't be fixed. Yet further, assuming the old posts can be repaired after the fact, performing those repairs will be at least as big a job as doing another complete migration. As such, it would be easy for the prospect of such an ordeal to cause interminable delays in execution. That's just human nature. But with a complete roll-back, the incentive to get it right will be as strong as ever.
I certainly do not intend to demean Parallax's -- nor especially Jim's -- intentions and efforts. We're really lucky to have such supportive and responsive friends in the business. But when things go bad, as they have today, sometimes a do-over is the best recourse. Life does not present many opportunities for do-overs; but, fortunately, this could be one of them! Yet it's an opportunity that may soon disappear under the weight of too many new posts.
At the very least, perhaps both forums could be locked over the weekend until a deliberately thought-out decision can be made as to what to do next.
Then came the reality, PhiPi before/after disaster
Before - clear and readable
After - totally unreadable
Thumbs up to the search feature, been using it today, that's what I've been needing. " max7219 " keyword - limited to prop forum returned great hits.
to keep it simple, migration looks like a lot of work, keep at it please.
Roger
I'm with Phil on this one. Who had the brilliant idea to throw away so much information?
1) The code displays are unreadable now.
2) My bookmarks are all broken.
3) Worse - All links from the rest of the internet into the forum are broken. Say from Google or Hackaday or blogs or project pages here and there.
4) Avatars have gone.
5) Personal messages have gone.
6) Attachments seem to be borked.
7) Search still does not work. Try finding "Zog".
8) Passwords were gone.
I could not log in as "heater", not without changing the password, but then the old account has an old unused email address in it. My fault perhaps but a little warning would have helped.
Now I have to somehow fish out all my old PMs to see what needs saving, ahrrr!
Oh and did I mention this new forum is butt ugly...
I hope someone contacts me soon to get my old "heater" name working again.
I guess this will all get resolved some how but just now Heater is a bit Incandescent.
Try searching for *zog*
I'm not saying you should have to add the wild cards, but I think it gets what you were expecting.
Could some one get rid of that "Junior Member" thing. I'm by no means "junior". It's insulting. Of course if it's changed to "Senior Member" I'm going to like it even less.
Initiate, Novice, Acolyte, Sexton, Beadle, Scribe, Monk, Pilgrim, Friar,
Hermit, Chaplain, Deacon, Curate, Priest, Vicar, Parson, Prior, Monsignor,
Abbot, Canon, Chancellor, Bishop, Archbishop, Cardinal, Sage, Saint, Apostle, Pope
I don't think we need to go there! :-)
I do want the formatting fixed, and ALL of the posts back and links fixed.
I still want a DVDROM release of the old forum also, but as of now, I am for keeping the new forum, the new font and fix the stuff that needs to be fixed.
Thanks for your work
Doug
PS, there needs to be a cancel button on edit, post reply, and advanced edit.
