How do I convert this truth table into a Prop-compatible chip or logic circuit? — Parallax Forums
ElectricAyeElectricAye Posts: 4,561
edited 2010-06-22 23:24 in Propeller 1
Good morning,
I would like to independently control 4 LEDS but I can budget only 2 Prop pins to do so. I've been trying to reinvent the wheel on this with NAND gates and XOR's etc, but I just can't figure it out and I'm sure there's some kind of simple Prop-compatible (counting?) chip that can easily do this. But what da heck is it?
Suggestions will be greatly appreciated.
    edited 2010-06-18 14:23
    A 74HC138 can do that with one chip, but the outputs will be active low. Or half a HC139.
    Is the challenge to do this with one chip?
    If you really want active high outputs, I think a 74HC4051 can do it with one chip. (or 4051). Feed in a high and it passes it through to one of the outputs. Though 'low' would be tristate. Won't matter if driving leds.
    Active low driving leds won't matter either - the aim is just to get the led to light up.
    138 or 139 if you have them in the parts drawer.
    Post Edited (Dr_Acula) : 6/18/2010 2:35:30 PM GMT
    edited 2010-06-18 14:28
    Dr_Acula said...
    Doing this with one chip would be nice but I'd settle for almost any combo of gates right now. I'll have a look at your above suggestions.
    edited 2010-06-18 14:31
    See addits above re 4051
    If two chips, you can do pretty much any logic with, say, an AND gate and hex inverters eg 74HC08 and 74HC04. Use the 4 AND gates and invert one or both of the inputs for each output state.
  • RaymanRayman Posts: 16,455
    edited 2010-06-18 14:37
    Check out this datasheet:
    http://focus.ti.com/lit/ds/symlink/cd74act139.pdf
    YOu could use this chip, or copy the logic diagram...
    My Prop Apps:· http://www.rayslogic.com/propeller/Programming/Programming.htm
    My Prop Info: ·http://www.rayslogic.com/propeller/propeller.htm
    My Prop Products:· http://www.rayslogic.com/Propeller/Products/Products.htm
  • bill190bill190 Posts: 769
    edited 2010-06-18 14:58
    Just say it like it is...
    NOT a AND NOT b· -> IR 1
    a AND NOT b -> R 1
    NOT a AND b -> G 1
    a AND b· -> B 1
    edited 2010-06-18 15:10
    Doc, Rayman, bill,
    this is excellent. It seems like somebody told me years ago: you can design any logic circuit with enough NAND gates. As a point of pride, I took it upon myself to design this from scratch... but simply choked on it. blush.gif
  • jazzedjazzed Posts: 11,803
    edited 2010-06-18 15:26
    @ElectricAye, I want to add a little extra foundation to the topic.
    Look at this image and think about how many states are represented.
    It is a little more complicated than the 2 variable diagram.
    Just count the number of color spaces. Don't forget the area where there is no color.
    Use English to describe the conditions for each color "space". Don't use set theory, just logic.
    Once you have a list of statements, translate them to equations.
    That's just one way to design a 1 of 8 decoder from scratch with confidence.
    Cheers,
    --Steve
    Propeller Pages: Propeller JVM
    Post Edited (jazzed) : 6/18/2010 4:45:43 PM GMT
    edited 2010-06-18 16:21
    I'll post a circuit later, but I was able to get this functionality with 4 transistors, 2 diodes, and 5 resistors.
    Beau Schwabe
    IC Layout Engineer
    Post Edited (Beau Schwabe (Parallax)) : 6/18/2010 7:00:53 PM GMT
  • ErNaErNa Posts: 1,861
    edited 2010-06-18 19:49
    There is a way to control two leds with one pin. That makes it easy to drive one of for leds by 2 inputs. Don't remember the threat, was about 4 weeks ago
    cmapspublic3.ihmc.us:80/servlet/SBReadResourceServlet?rid=1181572927203_421963583_5511&partName=htmltext
    Hello Rest Of The World
    Hello Debris
  • heichheich Posts: 26
    edited 2010-06-18 20:04
    This is rare
    I was sure i posted an answer here. But i don't see it.
    Hope this one works.
    ww1.microchip.com/downloads/en/appnotes/00234a.pdf
    Page 2. Fig 4
    Good look
    Regards
    Are you looking for a professional PCB/Schematichs software?
    Kicad: GPL. You can do Schematics, PCBS, Gerber interfaces, 3d-views and more
    www.lis.inpg.fr/realise_au_lis/kicad/
    Search in Parallax Forums Using Google
    www.google.com/advanced_search?q=+site:forums.parallax.com&num=20&hl=en&lr=
    edited 2010-06-18 20:14
    Beau Schwabe
    IC Layout Engineer
    917 x 761 - 173K
    GC.JPG 172.5K
    edited 2010-06-18 21:01
    ErNa said...
    Yes, it was this:
    http://forums.parallax.com/showthread.php?p=910828
    But then somebody mentioned that perhaps some little bit of current might flow through both LEDs??? and that might emit a little bit of light from the undesired LED???? See...
    Peter Jakacki said...
    .... I used a red and a green in series and at 3.3V there was only a bit of leakage current flowing which means that the leds just glow slightly.....
    I'm not sure if that's true for what I wanted to do and, if so, whether or not it would mess up my measurements, so I decided to be chicken and use 2 pins to drive 4 LEDs using pure Spock logic.
    EDIT: added Peter's quote.
    Post Edited (ElectricAye) : 6/18/2010 9:07:13 PM GMT
    edited 2010-06-18 21:02
    Beau Schwabe (Parallax) said...
  • Bobb FwedBobb Fwed Posts: 1,119
    edited 2010-06-18 21:12
    ElectricAye said...
    Doc, Rayman, bill,
    I believe both NAND and NOR logic share the title of being "functionally complete". I too have tried to build even mildy complex logic with just NOR's or NAND's and gave up after short order. Using all of the available standard logic is just too easy.
    @Beau
    I always love the discrete logic solutions. I am trying to get more proficient with such things. But alas, I find my endeavors are in vain. When I am laying out my PCBs I find the parts for discrete logic circuits are almost never as small as some IC I can find on the market that also can do the same thing at higher frequencies , use less power while doing it, and ultimately are cheaper (after the cost of PCB sqaurefootage and more assembly costs). I will not be downtroddened; exercising your brain in new and exciting ways will keep you forever young.
    April, 2008: when I discovered the answers to all my micro-computational-botherations!
    Some of my objects:
    MCP3X0X ADC Driver - Programmable Schmitt inputs, frequency reading, and more!
    Simple Propeller-based Database - Making life easier and more readable for all your EEPROM storage needs.
    String Manipulation Library - Don't allow strings to be the bane of the Propeller, bend them to your will!
    Fast Inter-Propeller Comm - Fast communication between two propellers (1.37MB/s @100MHz)!
    edited 2010-06-18 21:18
    There will be no current, if another si-diode is connected in serial. But, instead of logic, another propeller may do the job wink.gif
    Hello Debris
    edited 2010-06-19 05:29
    I guess just for the intellectual challenge, see below for a solution using just NAND.
    This would be 3 chips to replicate your logic. But if you want to light up a led, use active low and that saves the 4 output inverters, and so now it would only be two chips.
    I do like Beau's transistor solution.
    608 x 502 - 34K
  • zoopydogsitzoopydogsit Posts: 174
    edited 2010-06-19 12:02
    I recall years ago using Karnaugh maps when designing stuff in nand gates. A quick google search found the following. Enjoy :-)
    http://www.allaboutcircuits.com/vol_4/chpt_8/6.html
    http://en.wikipedia.org/wiki/Karnaugh_maps
    It's all a function of time.
    edited 2010-06-19 13:13
    Dr_Acula said...
    I guess just for the intellectual challenge, see below for a solution using just NAND.....
    That's very impressive. No wonder I couldn't figure it out by myself. That fries my brain, too. lol.gif I'm sure glad you guys helped me out with a chip that does the job! smile.gif
    edited 2010-06-19 15:06
    FYI - For those learning about logic gates, in the above NAND only example, and the bottom two NAND gates shown...
    The right NAND gate has both inputs tied together.·This makes it a NOT gate...
    That along with the NAND gate to its left makes the combined two NAND gates function as an AND gate (clever use of the NAND gates).
  • ericballericball Posts: 774
    edited 2010-06-22 20:15
    ElectricAye said...
    That's a basic 2 in 4 out binary decoder/demultiplexer with active high outputs.
    Composite NTSC sprite driver: Forum
    NTSC & PAL driver templates: ObEx Forum
    OnePinTVText driver: ObEx Forum
    Here is a cool link to interactivly build and play with logic gates...
    joshblog.net/projects/logic-gate-simulator/Logicly.html
    ... you can knock two of the NAND gates off of Dr_Acula schematic by combining the inverter function of two of the input NANDs.
    Beau Schwabe
    IC Layout Engineer
