Most efficient way to sum the 1's in a byte — Parallax Forums
LuckyLucky Posts: 98
edited 2010-04-03 22:07 in Propeller 1
I am trying to find the number of ones in a byte so that I can determine the parity bit. I have some code, but I am unsatisfied with it because I know there is a better way. Right now I'm having·a brain fart, and can't come up with anything. This is what I have:
·· index := %0000_0001
·· repeat rep from 0 to 7
····· if(KeySig &·index == 1)
········ ++parity
····· index <<= 1
·· if(parity // 2 == 1)······· 'odd parity
····· parity := 0
·· else
····· parity := 1
Is there a better way?
"You do not really understand something unless you can explain it to your grandmother."
-Lucky[size=-1][/size]
Post Edited (Lucky) : 4/3/2010 12:57:58 AM GMT
    edited 2010-04-03 01:16
    I don't know about most efficient (it's too early here) but try this:
    CON
      pattern = %0110_1001_1001_0110
    PRI parity(b)
      return (pattern >> (b & $F) ^ pattern >> (b >> 4)) & 1 ^ 1
    Edit: minor improvement
    PRI parity(b)
      return !(pattern >> (b & $F) ^ pattern >> (b >> 4)) & 1
    Edit: and one more
    CON
      pattern08 = %1001_0110
      pattern32 = %1001_0110_0110_1001_0110_1001_1001_0110
    PRI parity(b)
      return !(pattern32 >> b ^ pattern08 >> (b >> 5)) & 1
    Post Edited (kuroneko) : 4/3/2010 4:35:39 AM GMT
  • LuckyLucky Posts: 98
    edited 2010-04-03 01:23
    Wow, can you explain what is going on because I have no clue what you just did
    edited 2010-04-03 01:25
    I know you can use the carry in PASM to test for parity but that Spin method is a very cute method indeed, it encapsulates what is essentially a twin table lookup in a one line'r of 22 byte tokens.
    *Peter*
    edited 2010-04-03 01:32
    First I split the byte into two nibbles (which can have values from 0..15). That value is used as a bit index on a 16bit constant (pattern). Said constant has a 1 in places where the bit count of the index is odd, e.g. %0111 (7) is odd meaning bit 7 in pattern is set. That bit is also shifted into position 0 (>>). This is done for both nibbles. Now we combine them (e?e=e, e?o=o, o?e=o, o?o=e) which is done by xor'ing them. What remains to be done is extract the bit 0 of the result (& 1) and change parity to even (^ 1).
    Does that make sense?
  • pjvpjv Posts: 1,903
    edited 2010-04-03 01:38
    Hello Lucky;
    In assembler the carry holds the parity value when ANDing the long with $FFFF_FFFF. That of course is the same as the slightly more convenient form of ANDN Long, #0 ..... so a single instruction.
    But that's assembly..... unfortunately I don't (yet) know or understand SPIN, and can't help you there.
    Cheers,
    Peter (pjv)
  • JonnyMacJonnyMac Posts: 9,846
    edited 2010-04-03 01:40
    I don't know if this is the *most* efficient, but it's simple:
    pub ones(value)
      result~
      repeat 8
        result += value & 1
        value >> 1
    Jon McPhalen
    Hollywood, CA
    edited 2010-04-03 02:24
    @kuroneko: yes that makes much more sense, thank you
    @pjv: how do you know assy but not spin, I thought every program on the prop needed some spin
  • James NewmanJames Newman Posts: 133
    edited 2010-04-03 03:36
    Well, it only takes a bit of spin to start the asm code for the prop. I too started with quite a few (some quite large and intricate) pasm programs before I had a project that was easier to do some stuff in spin. That was mainly interface using vga_text, floating math, keyboard, etc...
    edited 2010-04-03 07:02
    Lucky,
    I ran some benchmark speed test on the suggested methods...
    Your original code came in at...  268.4us
    kuroneko code version 1           43.4us       'return (pattern >> (b & $F) ^ pattern >> (b >> 4)) & 1 ^ 1'
    kuroneko code version 2           41.4us       'return !(pattern >> (b & $F) ^ pattern >> (b >> 4)) & 1'
    kuroneko code version 3           36.4us       'return !(pattern32 >> b ^ pattern08 >> (b >> 5)) & 1'
    JonnyMac's code                   200.4us
    Beau Schwabe
    IC Layout Engineer
    edited 2010-04-03 08:18
    It's surprising what a walk outside can do for you [noparse]:)[/noparse] One last improvement for today ...
    CON
    PRI parity(b)
      return !(pattern32 >> (b ^ (b >> 5))) & 1
  • Andrey DemenevAndrey Demenev Posts: 426
    edited 2010-04-03 08:24
    And moving the negation to constant saves another instruction
    CON
     {pattern32 = %1001_0110_0110_1001_0110_1001_1001_0110}
      pattern32 = %0110_1001_1001_0110_1001_0110_0110_1001
    PRI parity(b)
      return (pattern32 >> (b ^ (b >> 5))) & 1
    edited 2010-04-03 08:32
    Nice one!
  • wjsteelewjsteele Posts: 697
    edited 2010-04-03 10:42
    Bill
    edited 2010-04-03 13:16
    Actually it seems to generate the complement of the parity.· The ! operator shouldn't be used with the original pattern32.
    edited 2010-04-03 13:19
    Dave Hein said...
    As per OP, even parity is reported as 1 (not judging whether that was intended).
    edited 2010-04-03 14:46
    wjsteele,
    For speed testing, just set up the routine to be timed in a repeat loop that toggles a pin !outa[noparse][[/noparse]0]
    Use this routine as a baseline time, use a scope to measure the width of the pulse.
    dira[noparse][[/noparse]0]~~
    repeat
      !outa[noparse][[/noparse]0]     'toggle pin 0
    Now, do the same thing by adding the code you want to time and use a scope to measure the width of that pulse.
    repeat
      {place the code you want to time here}
    To isolate just how long the timed routine requires, subtract the baseline amount of time from the time with the added code.
    Beau Schwabe
    IC Layout Engineer
  • Roger LeeRoger Lee Posts: 339
    edited 2010-04-03 18:23
    Beau,
    I like the way you think. Teach a man to fish...
    Roger
    edited 2010-04-03 20:33
    If you don't have a scope, but do have an LED and a resistor you can measure the time by looping the test code many times as follows:
    repeat
        repeat 10000
    Use a convenient loop count that you can easily measure with a watch.
    edited 2010-04-03 21:34
    The following uses the Spin decode/encode operators to knock down one bit at a time, so it is fastest when 1's are sparse, and easily extends to longs.
    PRI ones(tbd)
      repeat until tbd==0
        tbd := tbd - |< ( >| y - 1 )     ' knock down set bits, msb first
        result++
    Hacker's Delight devotes 25 pages to functions based on counting 1s.
    Tracy Allen
    www.emesystems.com
  • MagIO2MagIO2 Posts: 2,243
    Why would you use a scope or an LED to measure the time???? Everybody has a serial interface and every propeller has the CNT. Isn't it precise enough for you?? ;o)
