Ron: I will post the RamBlade pinouts for RossH to see what is required. It should not be a major deal, but Catalina will NOT run without changes to the pinouts and Ram drivers. Note the I/O for the RamBlade is P23/22 NOT P31/30. You can use a propplug upside down on the bottom 4 pins.
▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔ Links to other interesting threads:
1. What do I do with the zipped files (from my website www.cluso.bluemagic.biz )?· Unzip them to a folder on the pc. Format the microSD card with FAT16 and 32KB clusters (IIRC this is the default for 1GB & 2 GB cards). 1GB & 2GB cards are probably the best. I use SanDisk. Then just copy the files to the microSD.
2. How do I connect to the DemoBoard ?· At the beginning of this thread is a pinout for the various connections. Provided you have nothing in the prototype area, using the outer row of 12 pins on the RamBlade,·I suggest you solder the first 4 pins and the·last 2 pins with the pins facing down (i.e. solder the pins on the reverse side to nomal). This means you will have (from the top) 3, nc, O, I, and skip 6 pins (can be added later) and solder the last two as nc, G. You also need to solder a wire link joining the upper 2 pins of VR1 (see photo on page 1 of this thread). Now you can plug the RamBlade into the Deom Board. P0 will be the SO (serial out P22) on the RamBlade and an input on the Demo Board. P1 will be the SI (serial in P23) on the RamBlade and an output on the Demo Board. Later you may wish to also connect R, pI, pO for resetting and·programming the RamBlade but this should not be necessary.
If you do not understand my instructions, please ask.
Is this assuming any particular software is loaded on the Demo Board? Is the intent to use the USB connection to the Demo Board as the terminal interface?
You can use the Demo Board as a Terminal - will require terminal software either on OBEX or roll your own. Alternately you can use the USB and a PC. Soon you will also be able to use the 1-pin TV (works) and 1-pin PS2 keyboard as well.
The RamBlade software on uSD expects a terminal on P23/P22 at 115,200 baud. The eeprom software just boots from uSD, so this does not need to be changed (hopefully ever) - if it does, remember you must short the link labelled WE to enable writing to the eeprom.
Here is how you connect the RamBlade to an external 3V3 regulated power supply.
Also shown is how to connect to a PropPlug and pc using a terminal program. Note that you cannot reset the RamBlade or download code this way as the serial pins are not those used for downloading !!! NOTE: The PropTool will not find the RamBlade. ·
Just a note regarding the files and programs on the SD card...
The test program will not find some files as these were deleted after I wrote the test program. However, if it reports files not found it is correctly accessing the SD card.
You will need to <esc> from the loop into PropCMD where you can do a DIR. To run ZiCog type "SPIN ZICOG150". You can automatically enter ZiCog by either
* rename ZICOG150.BIN to ZICOG.BIN
* edit AUTOEXEC.BAT and change "ZICOG·· .BIN" to ZICOG150.BIN"
Just a quick note to those who have paid orders...
I·now have a panel of 10 assembled and 2 panels partly assembled (with the finer parts so I can finish them myself). Hopefully I will have time to test/pack/ship them tomorrow. These will ship with both 6.5MHz (104MHz)·and 13.5MHz (108MHz)·xtals although 13.5MHz has not been thoroughly tested yet. My apologies for the delay.
On another note, in case you have missed it, I now have the 1-pin keyboard working using the normal resistors (no rc network required). The only issue is that you must hit the <space> key for the prop code to calculate the keyboard speed. Of course, it cannot reset the keyboard or set the leds.
Last thing to do is modify the 1-pin TV driver to work with SphinxOS and we will have a simple OS for the RamBlade and other boards.
I want to re-order a new, completely assembled Ramblade. This order is to completely replace all others. I do not know why I not received an order in over a month and a half period.
JMH: I am sorry but when you asked on 11th Jan I said I would not have parts for a couple of weeks. I do not ask for payment until the boards are almost ready. However, others have paid and I ship in order of payment. I expect to have some unsold ones available possibly at the end of the week.
I am reliant on my son soldering up the finer parts. I had hoped he would solder all parts. Unfortunately for me, he has been extremely busy at work so he only did the finer parts. I have to do the other easier parts.
Now I have images of the sweatshop down in the depths of the bilges.
Open the hatch, lob down a bag of bits and then slam the lid down yelling unveiled threats about not getting his tea if the boards aren't finished soon.
Style and grace : Nil point
Here are photos of making the 1-pin TV (video) cable and the 1-pin PS2 Keyboard cable. The circuit and connections are described 2 posts above.
I have used old computer cables except for the RCA plug and the PS2 Keyboard (6pin) socket. Note if you have a USB keyboard that supports PS2 mode you can use a USB socket instead of the PS2 socket, although not all USB keyboards can do PS2 (they autodetect).
TV (composite video cable)
Original cable was a speaker cable. Also shown is the purchased RCA plug.
Solder a 100R onto the yellow wire. Also shown is yellow heatshrink.
Heatshrink fitted over the resistor and wire joint.
Resistor soldered to centre pin and black wire to outer pin if RCA plug.
Finished cable.
Keyboard cable (PS2 1-pin version)
I used an old computer CD cable. I cut the extra mounting clips off the 4-pin plug. My 4-pin plug had another set of finer cables connected to another smaller plug. I carefully cut those wires off.
A: The white wire has 100R soldered with yellow heatshrink covering the joint. The other end of the 100R is soldered to a 10K. A 10K is also soldered to the PS2 socket (clock pin) and then covered with heatshrink.
B: A larger piece of red heatshrink is ready to be placed over the 2 resistors.
C: Red heatshrink is fitted over the 100R & 10K resistors but not shrunk yet.
The resistors are then soldered to the PS2 socket (data pin) and the red heatshrink is slid over the joint and shrunk.
E: Next the black (GND) and red (+5V) wires are soldered to the PS2 socket.
F: The exposed leads from both the 10K resistors are then bent back ready to be soldered to the red wire/PS2 socket.
G: The 10K resistors are soldered to the red wire at the PS2 socket (+5V).
H: Completed cable.
Power cable (+5V regulated power pack)
The cable was made from an old power switch. The 5V supply is from an old camera charger (neither shown).
CPM in a matchbox·· Here is a photo of the RamBlade (SBC mode) in a matchbox. Propeller & 512KB SRAM on the pcb underside.
While I was out buying the connectors today, I saw a rollup keyboard. The keys were backit. It·was·USB & PS2 compatible with·a USB plug and came with a USB to PS2 adapter too.·Cost in the shop A$50 (about US$45). (Jaycar for the Aussies).
I have just noticed that some of the orders sent 3 Feb have the invoices incorrectly stating the TriBlade instead of the RamBlade. My wife did the invoices for me and apparently I told her the wrong part. If you require an updated invoice, please email me.
Are any of you RamBladers out there (or anyone else) interested in a small pcb to plug into the RamBlade (etc) ?
4-pin interface
power out (3V3 and GND)
2-pin I/O interface
circuit for 1-pin keyboard (resistors) & PS2 connector
a USB connector can be soldered instead of the PS2 for USB keyboards in PS2 mode (saves an adapter)
circuit for 1-pin TV (resistor) & RCA connector (B&W only)
DC input connector (for power pack 6V-9V DC or 5V regulated)
5V regulator & capacitors (not required for 5V regulated supply)
3V3 regulator & capacitors
Optional additional interface & circuitry for
full 2 pin PS2 keyboard
additional·3 resistors for full 4-pin TV (color)
If so, PCB only, or kit of parts?
Sorry, I've been busy on other things recently, and I haven't yet had a chance to do Catalina drivers for the RamBlade. I can guarantee that Catalina WILL run on it - maybe as soon as next week - but I am hesitant to promise anything more specific in the absence of actual hardware to test with. I recently tried adding support for Dr_Acula's RamBlade without hardware, and ended up tripping myself up on something really stupid which wasted days. Once the actual board arrived it was only a matter of hours to get it sorted.
Ross.
Ross: We have all been busy with other things. As I said on the phone, I have been too busy to even try Catalina on the TriBlade. Maybe we can discuss at our Sydney Propfest on Friday evening
I warn you, Friday night is cocktail night at our place - and I make a pretty mean dry martini! - a couple of those and your head will be spinning so fast that you won't be able to tell the difference between Catalina running on a tri-blade prop and a tri-blade prop running on a Catalina.
Ross.
Now all we have to do is go to a sunning lab to get charged up LOL
BTW I could easily halve the size of the RamBlade using the smaller ram and prop packages with the uSD over the top. My point was to make a pcb to plug into other pcbs including the Prop Proto Board. But of course it can run standalone with the modified keyboard and video cables.
Got my Ramblades the other day... Now, I'm going to put one on my PSB accessory board and see what possibilities that opens up...
My first thought is to see if Beau's high speed serial link will allow me to us the Ramblade as a frame buffer, so as to do a better job showing a full-screen 6-bit image.
Right now, I can use an SD card as a frame buffer, but I have to drop the refresh rate down to 11 Hz, which causes noticeable flicker...
Second thought is to use the PSB as a terminal for the CP/M system they have going...
Yes, the terminal idea would be the first step and that is fairly simple.
For the framebuffer idea, yes Beau's code would be the best approach. I am presuming that it is sequential reads of the SD file, so the RamBlade could forward buffer 512KB into sram.
'RamBlade & TriBlade(#2) Hardware Definitions ' RR20100119 (c)2010 "Cluso99" 'RamBlade _clkmode = xtal1 + pll16x _xinfreq = 6_500_000 'SDcard spiDO = 24 'SD pins spiClk = 26 spiDI = 25 spiCS = 19 'Serial rxPin = 23 'serial pins, baud txPin = 22 baud = 115200 'SRAM ' A0-18 = P0-18 'address ' D0-7 = P24-31 'data ' -CE = P20 ' -WE = P21 'TriBlade (Blade #2) _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 'SDcard spiDO = 9 'SD pins spiClk = 28 spiDI = 8 spiCS = 14 'Serial rxPin = 31 'serial pins, baud txPin = 30 baud = 115200 'SRAM ' A0-18 = P8-26 'address ' D0-7 = P0-7 'data ' -OE = P28 (SCL) '-OE (U24+U24 SRAM) ' -WE = P29 '-WE (U23+U24 SRAM) ' LE = P27 (SDA) 'LE (U25 Latch on low): -CE1(U23 lo) = P10; -CE2(U24 hi) = P11
Thanks for the info.
Some questions asked...
--jc
Post Edited (Cluso99) : 1/20/2010 3:09:46 PM GMT
Post Edited (Cluso99) : 1/25/2010 2:21:39 AM GMT
Post Edited (Cluso99) : 2/1/2010 1:32:30 PM GMT
JMH
www.mikronauts.com E-mail: mikronauts _at_ gmail _dot_ com 5.0" VGA LCD in stock!
Morpheus dual Prop SBC w/ 512KB kit $119.95, Mem+2MB memory/IO kit $89.95, both kits $189.95 SerPlug $9.95
Propteus and Proteus for Propeller prototyping 6.250MHz custom Crystals run Propellers at 100MHz
Las - Large model assembler Largos - upcoming nano operating system
CPM in a matchbox
Post Edited (Cluso99) : 2/3/2010 12:56:24 PM GMT
Ross.
Ross.
Count me in for the Ramblade daughterboard: the simpler the hardware, the less potential
for smoking the parts when tired ...
T o n y
Tony: You make 2 interested so far.
The RamBlade is shipped with a 6.5MHz xtal (pluggable) to give 104MHz.
Extra items now shipped with the RamBlade...
I think somebody has taken up the challenge on small computers. It will be a right B****** to fit a 15 pin to it though.
http://www.ns.umich.edu/htdocs/releases/story.php?id=7520
With a blink-based character input and direct optic nerve output, CP/M could be run strait from the eyeball.
You would have to spend most of the day staring at the sun (not·so good, for half of the year, in your bit of the World)
My Prop Info&Apps: ·http://www.rayslogic.com/propeller/propeller.htm
My Prop Products:· http://www.rayslogic.com/Propeller/Products/Products.htm
