Prop II on-chip development question - Page 4 — Parallax Forums
1246716
  • BradCBradC Posts: 2,601
    edited 2009-11-24 07:27
    Chip Gracey (Parallax) said...
    BradC, for USB, is the third pin needed to handle the initial pull-up/down on one of the two data pins? If we have pull-up/down on every pin, will it still need three pins then? I see what you are saying about the enumeration headache. The purpose of USB would be, at least, to provide a development conduit to the PC. Also, users could do other things, as well. SD card in 4 pins would be nice.
    Yeah, the third pin is for the enable resistor. The issue is it has to be quite a specific value (between about 1.2-1.5k). It also has to be at the port, whereas you need ~100 Ohm series resistors between D+/- and the port. Deviating from this can cause some pretty big headaches. Also, you can't just hardwire it as you *need* to be able to respond to an enumeration request quite quickly after the enable is pulled or the host will call the device dead and shut down the port.
    From what you've said about speed, the P-II will do full-speed USB standing on its head, and might even be able to do the MAC layer and application level in the same cog (I had to split them to be able to get responses out in time). There will be no problems at all for users to be able to do their own thing with that. As a conduit for development, just emulating a serial port would do a great job as you have no speed restrictions at all. 1MB/s is quite doable over a full-speed USB link.
    Something like this might work.
    <try all other boot methods first>
    pull enable high
    wait 1 second for enumeration (halt on fail)
    enumerate
    wait 5 seconds for further instruction (or don't timeout at all and just sit there waiting for the host software)
    go to sleep
    On the PC end you would register a notification that a new USB device had arrived. If it matched the PID/VID of the prop you have a couple of seconds to try and talk to it.
    Reset could be an issue.
    When I played with the USB bootloader, I had 2 cogs that ran full time in the background (communicated using the last 8 longs of RAM) so I could "remote reset" the chip. That way I never lost communication with the propeller. I could also stop all the application cogs, re-load ram, read/write eeprom, hard reset or warm-boot the chip (as long as the application did not change the oscillator settings!). It was a neat way to do it, but at an absolute maximum of 1000 8 bytes packets per second (reality was more like 600) it was _very_ slow to do anything.
    Plenty of time to work out the finer details anyway.
    If you always do what you always did, you always get what you always got.
    edited 2009-11-24 08:36
    BradC:
    USB: As a slave, there is only 2 pins D+ & D- plus power & gnd. I presume when we use the FTDI chip, because the USB bus is already established with the pc, the enumeration (connection) time is not an issue? So I guess, that if PropII were to use USB to download it would have to enumerate a USB connection and then wait and see if something sends a download sequence to it and this would be a long process timewise. Also, the download would have to work differently or we would be resetting the enumeration sequence (and we know windoze doesnt like that). Sounds complicated.
    Chip:
    microSD: uses 4 pins with SPI protocol. Native SD mode is licensed, so forget that. The 4 pins are -CS, SCLK, DI, DO. I am unsure if DI and DO could be joined or if there is a possibility of overlap causing contention. I do not know enough about the protocol to know if it could share a standard SPI interface. Certainly, the uSD could as long as -CS is high, and that DO (from uSD) is forced into tri-state - I do this on the TriBlade which is shares SCLK, DI & DO with the SRAM. But I am not sure if any another SPI chip on the uSD SPI bus could mis-interpret data to/from the uSD.
    Boot code: Presuming the load options are on different pins, it would be possible to launch multiple cogs and each of them concurrently try to establish communications with the various bootable devices (Hey, may as well utilise the cogs in the boot process). If the user can program a few fuse bits, the boot code could detect that to disable various boot options. Are the fuses OTP?
    edited 2009-11-24 08:40
    Cluso99, thanks to you and BradC for the USB info.
    The fuse bits are OTP. They are actually poly fuses that get blown.
    Chip Gracey
  • Mike HuseltonMike Huselton Posts: 746
    edited 2009-11-24 09:50
    Chip,
    USB3?
    JMH
  • TonyDTonyD Posts: 210
    edited 2009-11-24 10:09
    We're currently looking at making a special 12x12mm 128-pin LQFP that has a big GND plate on the bottom. This way, no pins need to be spent on GND and we can get over three 32-pin ports out.
    Single big GND plates are a pain to hand solder unless you put some pretty big vias in and solder from below or carefully use a hot air gun. Please reconsider and put GND's on pins.
    - Tony
    http://zuzebox.wordpress.com/
    edited 2009-11-24 10:27
    Cluso99 said...
    BradC:
    And you need three pins on the prop.
    edited 2009-11-24 10:38
    BradC: ??? Do you mean the extra pin for it to be a master or do you mean because of reset?
    edited 2009-11-24 10:41
    James Michael Huselton said...
    Chip,
    USB3?
    Nope.·5Gb/s is too fast. It would require much dedicated silicon to handle.
    Chip Gracey
    edited 2009-11-24 10:46
    TonyD said...
    I hear you, but that ground plate would save a GND pin for every 8 I/Os, plus 8 more for the core. This comes to about 20 pins. Those can now be I/Os, instead. Just put four .1" plated-through holes under the chip so that you could surely solder it from the backside.
    Chip Gracey
  • Graham StablerGraham Stabler Posts: 2,510
    edited 2009-11-24 10:56
    You can solder chips with a ground plate using a hotplate quite successfully even on single sided boards. The main issue seems to be maintaining alignment, a jig would make things easier. I'm really pleased to here about the possible LQFP-128 option, I was starting to imagine something I could only use with a breakout board.
    Graham
    edited 2009-11-24 11:06
    Cluso99 said...
    Neither.
    304 x 83 - 1K
    edited 2009-11-24 11:09
    BradC: Thanks, then this must be internal in the FTDI chip.
  • AribaAriba Posts: 2,697
    edited 2009-11-24 11:23
    As Brad described, the 3. Pin is needed to switch the PullUp on D- (LowSpeed) or D+ (FullSpeed) on and off. But this can also be made internal in the PropII with 2 switchable 1.5k PullUps.
    Another Problem that I see with USB Boot is the Clock frequency. I don't think the internal Oscillator is precise enough, and the Application which defines the Frequency of the connected crystal is not startet then, so the USB boot code will work only with one certain crystal frequency (?)
    Andy
    edited 2009-11-24 11:32
    Ariba said...
    Great catch Andy! I hadn't thought of that. Especially with full speed USB, the clock must be very accurate. low speed allows 1.5% deviation to cater for very cheap slaves, but full speed is _much_ tighter.
    <edit>
    Given how fast the new chip is going to be, it's entirely possible that provided a crystal oscillator is used, the code might be able to "autobaud" to adjust for any potential crystal frequency provided it's fast enough. It would be an interesting challenge.
    edited 2009-11-24 11:45
    Ariba said...
    Andy
    About these pullups: would we need 1.5k switchable to both VSS and VDD, or just one of them? I'm working on the pin circuitry, still, so I can find a way to add this.
    Because the next Prop has the ability to multiply the crystal input by 1x through 16x, I'm thinking that maybe it wouldn't be a bad thing to standardize on a 20MHz crystal. At 20MHz+, you can get minimally-sized crystals. 10Mhz crystals are still big. The oscillator circuit was designed to target 20Mhz crystals. With a known frequency base, USB timing issues go away.
    Chip Gracey
    Post Edited (Chip Gracey (Parallax)) : 11/24/2009 11:50:12 AM GMT
    edited 2009-11-24 11:59
    The pullup only needs to be switchable to VDD.
    The issue I guess is the series resistors. The USB spec is pretty tight (USB2.0 Spec - Section 7.1) on having the driver impedance limited by 45Ohm (I used 68 as it's what I had available at the time) series resistors. The signalling pull up is at the port, not at the driver, so unless you build 45 Ohm series resistors into the silicon and the 1.2K pullups (one for each pin so you could use full & low speed) then using 3 pins and 3 external resistors is certainly easier.
  • heaterheater Posts: 3,370
    edited 2009-11-24 12:04
    Are we really looking at 96 I/O pins here? Or am I just dreaming?
  • Chris_DChris_D Posts: 305
    edited 2009-11-24 12:11
    Perhaps I have missed it, but has the number of COGs been decided?
    Chris
    edited 2009-11-24 12:15
    Would 20MHz be a good starting frequency? Every time I have seen the xtals for USB, of any speed, they seem to be multiples of 6 or 12MHz.
    Style and grace : Nil point
    Chip said...
    edited 2009-11-24 12:26
    Toby Seckshund said...
    How about 20Mhz stepped up 6x to 120MHz? That would certainly jive.
    Chip Gracey
    edited 2009-11-24 12:28
    Chris_D said...
    Chris
    Eight.
    Chip Gracey
    edited 2009-11-24 12:33
    BradC said...
    We could build +/-15% tolerance resistors into the pin drivers. So, is it 1.2K or 1.5K that we'd want? And just to VDD, with VDD being 3.3v? I could easily give every pin a pull-up resistor of the nominal value needed. How fast would this pull up need to be turned on or off? I ask because it might mean toggling the pin through some modes that will take a few clocks.
    Chip Gracey
  • AleAle Posts: 2,363
    edited 2009-11-24 12:36
    Those LQFP-128 are really fine pitch :-(. I was expecting a .5mm part at the most. Well if that is the price of juicy 96 IOs then deal!
    Visit some of my articles at Propeller Wiki:
    MATH on the propeller propeller.wikispaces.com/MATH
    pPropQL: propeller.wikispaces.com/pPropQL
    pPropQL020: propeller.wikispaces.com/pPropQL020
    OMU for the pPropQL/020 propeller.wikispaces.com/OMU
    edited 2009-11-24 12:37
    Is it a single clock per instruction cycle? That would buy us 10 instructions per bit. The current USB receive code uses 11 instructions per bit for 1.5Mhz NRZI encoding with bit unstuffing. It might be a bit tight at 120MIPS for a 12MHZ bit rate, but then I'm sure someone could make the receive code more efficient than I have.
    edited 2009-11-24 12:41
    BradC said...
    It's single-clock instructions.
    How about those pull-ups? We could put those in the pin driver and then have just two series resistors on the outside (no third pin and 1.5k resistor, then).
    Chip Gracey
    edited 2009-11-24 12:43
    The spec says 1.5k to 3.3v. I think I used 1.2k as it was all I had handy. The USB signals are all 3.3v, so a perfect match for the current I/O pins.
    In this context, speed for the pullups is completely unimportant. The pullup is like the on/off switch for the interface. Turn it on, sit and wait for the host to throw us a packet. When we're done with the interface we drop the pullup to tell the host we are no longer plugged in.
    edited 2009-11-24 12:44
    This PullUp needs only be 1 time switched on when the USB driver is ready, and switched off when the USB driver stops, so no need for speed.
    Attached is a good understanding USB description, on page 6 is a schematic of the host - device connection. They say 1.5k +-5%, but I think 15% is also OK, perhaps make it 1.4k Ohm then.
    Andy
    edited 2009-11-24 12:45
    That's what I was getting at with the little schematic I posted. The USB spec is pretty specific on the pullup being on the port end of the series resistor, not at the driver end. I guess when you are whacking 12MHZ down a line the termination is pretty important.
  • LeonLeon Posts: 7,620
    edited 2009-11-24 12:47
    Central pads like those on the proposed package are normally reflow soldered with solder paste. The stencil needs to be made with a grid pattern so that the chip doesn't float on the molten solder. For hand-soldered prototypes the technique Chip mentioned works very well - I often use it with QFN packages using a single 2 mm via. For a large device like the Propeller II you will need good soldering equipment, like Metcal, to get adequate heat transfer.
    Leon
    Amateur radio callsign: G1HSM
    Post Edited (Leon) : 11/24/2009 12:53:49 PM GMT
