EEPROM verify error on COM7 — Parallax Forums
PyrotomPyrotom Posts: 84
edited 2009-10-11 01:25 in Propeller 1
When I try to load any program longer than a simple motor test into the EEPROM of my Stingray, I get an "EEPROM verify error on COM7" message. What does this mean? Is it something I'm doing, or a bad EEPROM chip in my Stingray? The same program loads fine into a virgin Demo board.
    edited 2009-10-03 15:05
    It's probably a bad EEPROM chip, but it could also be due to a drop in supply voltage during writing or verification or noise in the power supply. Given that this is a new product, you should contact Parallax Tech Support. They may want to have you send in the controller so they can do some investigating.
  • PyrotomPyrotom Posts: 84
    edited 2009-10-03 15:09
    Thanks, Mike. Just to eliminate the voltage problem I just tested it poering the board from a wall wart - same problem. I guess I'll have to contact Parallax Tech Support. Sigh.
    edited 2009-10-10 17:32
    It does sound like a bed EEPROM. Tech Support is expecting a call from you if you haven't contacted them already. Take care.
    P.S. - Please post subjects in only one thread at a time. This was also mentioned in the robotics forum. Thanks.
    Chris Savage
    Parallax Engineering
    50 72 6F 6A 65 63 74 20 53 69 74 65
  • WhitWhit Posts: 4,194
    Chris Savage (Parallax) said...
    Chris,
    That was my fault. He asked this on a Stingray thread and I told him he might get an anwser on the Prop threads. The error is mine. Sorry Pyrotom!
    Whit+
