CNC services needed - can you supply or recommend?
Hey everybody,
I'm building a new robot using our #27971 and #28971 kits. It's a round base from AL6061, 1/4" thick. The diameter is 16" and it includes a few cutouts for the motors and numerous drilled holes. Finish is to be grained; no anodization required.
This is too big to fit on our CNC milling machine, so I'm looking for somebody who can do it for me next week. We will pay you or trade hardware, or a combination of both (your choice!).
Can anybody recommend a company to do this for me?
Post Edited (Ken Gracey (Parallax)) : 9/12/2009 1:03:12 AM GMT
Sounds fine. I'll ring him tomorrow, or Monday, and get my files to him ASAP.
In California, so that's a bonus.
Thanks!
Ken
Your part has mirror symmetry (assuming the holes go all the way through). You could easily do this on your machine by making two identical pieces and scarfing them together:
One of my companies, FlexCIM Services Inc. can handle your needs. We have complete machine shop CNC milling, CNC turning, CNC punching facilities as well as automated electronic assembly.... surface mount robots as well as thru-hole stuffers. On top of that we have 4 plastics injection molding machines ranging from 35 ton to 300 ton capabilities. We are what you would call a "one-stop-shop" where we use solid modeling design programs, Solid Edge and Solid Works, and then go on to produce the products.
We'd be thrilled to produce some of you parts for you. please see www.flexcimservices.ca
Cheers,
Peter (pjv)
Thanks for all of the great suggestions. @Phil & Timmore: I understand and I have used this method in the past. It works but I don't prefer it due to setup time. I'd much rather see this milled in one piece and wait a few days.
@Peter: okay, will send you the files instead. I'd rather work with our customers whenever possible.
Ken
