What size cap for 6 Mhz xtals? — Parallax Forums
Chris_DChris_D Posts: 305
edited 2009-09-03 12:20 in Propeller 1
Hi
What size caps shoudl I use to load the crystal on the propeller?· This is for a 5 Mhz xtal.
I don't see any on the prop demo board but use them on the AVR's xtals I also work with.
Chris
  • Carl HayesCarl Hayes Posts: 841
    edited 2009-09-02 12:04
    That will be specified by the crystal manufacturer. or by you if you're ordering custom crystals. A typical value would be about 18 pf.
    · -- Carl, nn5i@arrl.net
    edited 2009-09-02 14:28
    I thought the Propeller had selectable internal load capacitors?
    edited 2009-09-02 15:11
    You don't use external caps with the Prop. You need to select a parallel-resonant crystal rated for the Prop's load capacitance at the appropriate drive level. For 5 & 6MHz, this would be about 18pF.
  • WhitWhit Posts: 4,194
    edited 2009-09-02 19:13
    Chris_D,
    See this page - http://mikronauts.com/products/mikronauts-625mhz-crystal/
    Toward the bottom of the page is some Q and A that might be helpful. Is this what you where wondering about?
    If not, What·are these caps for?
    Whit+
    Post Edited (Whit) : 9/2/2009 7:20:11 PM GMT
  • Chris_DChris_D Posts: 305
    edited 2009-09-03 11:00
    Arghhh - fat fingers.· I meant 5 Mhz not 6 Mhz!
    As I purchase my xtals from Parallax when I order chips, I would assume they would be of the correct type for this application.· I guess I better check into it a bit more just to be safe.
    Thanks guys,
    Chris
