What size cap for 6 Mhz xtals?
Hi
What size caps shoudl I use to load the crystal on the propeller?· This is for a 5 Mhz xtal.
I don't see any on the prop demo board but use them on the AVR's xtals I also work with.
Chris
Chris
· -- Carl, nn5i@arrl.net
See this page - http://mikronauts.com/products/mikronauts-625mhz-crystal/
Toward the bottom of the page is some Q and A that might be helpful. Is this what you where wondering about?
If not, What·are these caps for?
Whit+
Post Edited (Whit) : 9/2/2009 7:20:11 PM GMT
As I purchase my xtals from Parallax when I order chips, I would assume they would be of the correct type for this application.· I guess I better check into it a bit more just to be safe.
Thanks guys,
Chris
Your assumption is correct:
www.parallax.com/Store/Components/ResonatorsCrystals/tabid/153/CategoryID/18/List/0/SortField/0/Level/a/ProductID/341/Default.aspx
