FSRW: She's So Unusual - Page 3 — Parallax Forums
1356710
  • rokickirokicki Posts: 1,000
    edited 2009-07-18 22:17
    Fixed; the top post now has fsrw22.zip which fixes this bug and also makes FAT scanning faster. (The latter
    significantly helps the case of writing a file when the volume has a lot of space already, and also speeds up
    all the "pwrite" numbers by a nontrivial percentage).
  • RaymanRayman Posts: 16,388
    edited 2009-07-18 23:05
    Hey guys: What license would you call that? It looks like MIT, but I don't see "MIT" in there..
    My Prop Info&Apps: ·http://www.rayslogic.com/propeller/propeller.htm
  • lonesocklonesock Posts: 917
    edited 2009-07-19 02:05
    We were definitely aiming for the MIT license for OBEX compatibility (and the fact that it is my favorite license is nice too wink.gif. If we messed up on the text, I apologize. I will add an explicit comment "Licensed under the MIT License" to my code, might be tomorrow before I get to it, though, sorry. Tom, feel free to step in and modify my code before then if you wish.
    thanks,
    Jonathan
    lonesock
    Piranha are people too.
    edited 2009-07-19 02:09
    Thanks. I'm a big fan of MIT license too...
    edited 2009-07-19 02:36
    The license is the explicit text that was posted several years ago as the "standard"
    license to use for all ObEx code. I thought it was the MIT license.
    edited 2009-07-19 03:10
    Here's a v2.2 test with a 1GB card with 32K clusters.
    Waiting for key press to start tests
    Mount tests first
    First mount.
    Succeeded; stopping cog.
    Second mount.
    Succeeded.
    Reading block 0 (should be a boot block)
    Read finished; checking for boot block signature
    Boot block checks out; unmounting
    Third mount.
    Succeeded.
    Reading block 0 again (should still be a boot block)
    Boot block checks out; writing it back
    Write finished; unmounting
    Fourth mount.
    Succeeded.
    Block layer seems to check out
    Now speed tests
    How fast can we write, sequentially?
    Raw write 3968 kB in 2405 ms at 1649 kB/s
    Do a single non-sequential write...Done
    How fast can we read, sequentially?
    Raw read 3968 kB in 3919 ms at 1012 kB/s
    Now the filesystem tests
    Trying to mount
    Mounted.
    How fast can we write using pwrite?
    fsrw pwrite 992 kB in 2142 ms at 463 kB/s
    How fast can we read using pread?
    fsrw pread 992 kB in 1477 ms at 671 kB/s
    How fast can we write using pputc?
    FSRW pputc 127 kB in 3803 ms at 33 kB/s
    How fast can we read using pgetc?
    FSRW pgetc 127 kB in 3195 ms at 39 kB/s
    Repeating all the speed results:
    Clock: 96000000 ClusterSize: 4096 ClusterCount: 247506
    All done!
    edited 2009-07-19 03:31
    Mike Green said...
    Thanks for testing, Mike! Could you do me a favor and check the cluster size again? The quoted test is reporting a 4KB cluster size.
    thanks,
    Jonathan
    lonesock
    edited 2009-07-19 03:57
    It could be initialized with 4KB clusters, but I was sure I had redone it with 32KB. I don't have a PC set up and my Mac won't tell me. Sorry.
  • AleAle Posts: 2,363
    edited 2009-07-19 06:09
    Mike: you can create a directory and use the ls -l command from the terminal to find out its size.
    Visit the home of pPropQL: propeller.wikispaces.com/pPropQL
    pPropQL020: propeller.wikispaces.com/pPropQL
    OMU for the pPropQL/020 propeller.wikispaces.com/OMU
    edited 2009-07-19 06:29
    I have to provide OMU with a filesystem, the problem is that FAT is not at all useful for unix and it is written in Spin and I will call it from assembler. All that is simply messy, calling spin from assembler using the wait for "command" method. So I was thinking of integrating the block driver together with the filesystem, at least reading to load the kernel image. Now my dilemma is which kind of filesystem ?. I'm doing most of this development in Mac OSX so the only alternative would be Apple's UFS if I get enough info about it... If I were in linux it would be ext2 or maybe minix. While there is a ext2 implementation for Mac OSX it proved unstable when the filesystem was uncleanly unmouted, something that seems to happen quite often with thumb drives, even if I use the unmount command every time ! [noparse]:([/noparse]
    edited 2009-07-19 08:20
    Scratch what I said, I will implement a filesystem in 68K assembly/C and use the propeller to only provide blocks.
    Now a question: The size of the card is never checked. What happens if the fs is bigger than the card size ?. Block numbers are never checked for validity.
  • heaterheater Posts: 3,370
    edited 2009-07-19 08:26
    Gosh Ale I forgot about your 68000/Prop and OMU. How is it going?
    Why not write one big contiguous file to a FAT formatted card to hold the OMU file system?. Like Cluso does for CP/M.
    Or Kye has an SD driver with support for partitions.
    edited 2009-07-19 08:58
    Well it is not going that fast as I have to develop the Propeller parts: Video (text) is working, ROM emulation too.
    IO prop is well a bit skinny: Serial does not seem to work yet, keyboard does and SD well I'm implementing it now.
    On the 68K side I'm doing a loader for kernel but without the rest it just cannot progress.
    The hardware works, the soft needs. I am on it. I want to see it working. With 4 megs RAM loads can be done if I get a working loader... let's see. I'll post progress as soon as something is working (morethan prinitng on a monitor...)
    edited 2009-07-19 12:54
    I just noticed something very strange... The new fsrw hangs on "mount_explicit" unless the SD is first mounted with the old version!
    What it the world is causing that?
    I need to make sure I'm using the right versions of files here...
    Post Edited (Rayman) : 7/19/2009 1:01:18 PM GMT
    edited 2009-07-19 14:59
    Rayman said...
    Hi, Rayman.
    To be clear, if you cycle the power on the board or eject/re-insert the card and run our test code it hangs? I think the only reasons it could really hang in the block layer are:
    1: I have a waitcnt...I can't think it would be an issue unless you were using RCSLOW
    2: Maybe the cog did not start for some reason?
    3: A command timeout is failing (e.g. readblock or writeblock)
    I'm attaching a special version of mb_spi.spin. It gives extra clock pulses to the card on init, and it has extra checks to trap the cog not initializing in a timely fashion. You should see _some_ kind of response within 8 seconds. Please use the fsrw.spin from the fsrw22.zip, and this mb_spi.spin file. Please try the test.spin after a power cycle, and then a few more times back to back. If that fails please post the log (unless it just hangs again!), and i it succeeds please try it then in your PSM audio test app.
    thanks, and sorry about this,
    Jonathan
    lonesock
  • hover1hover1 Posts: 1,929
    edited 2009-07-19 16:06
    @all
    Test results for fsrw2.2. Parallax Demo Board @ 80Mhz
    Kodak 2GB MicroSD Card #1
    Clock: 80000000 ClusterSize: 32768 ClusterCount: 62293
    Raw write 3968 kB in 3215 ms at 1234 kB/s
    Raw read 1920 kB in 2093 ms at 917 kB/s
    fsrw pwrite 2016 kB in 3228 ms at 624 kB/s
    fsrw pread 2016 kB in 3292 ms at 612 kB/s
    FSRW pputc 63 kB in 2136 ms at 29 kB/s
    FSRW pgetc 63 kB in 1895 ms at 33 kB/s
    All done!
    Kodak 2GB MicroSD Card #2
    Clock: 80000000 ClusterSize: 32768 ClusterCount: 62294
    Raw write 3968 kB in 3241 ms at 1224 kB/s
    fsrw pwrite 2016 kB in 3236 ms at 623 kB/s
    fsrw pread 2016 kB in 3286 ms at 613 kB/s
    FSRW pputc 63 kB in 2269 ms at 27 kB/s
    FSRW pgetc 63 kB in 1890 ms at 33 kB/s
    All done!
    PNY 2GB MicroSD Card
    Raw write 3968 kB in 3258 ms at 1217 kB/s
    Raw read 1920 kB in 2094 ms at 917 kB/s
    fsrw pwrite 2016 kB in 3181 ms at 633 kB/s
    fsrw pread 2016 kB in 3289 ms at 612 kB/s
    All done!
    I'll rerun tests at 100Mhz later today.
    NOTE: This test did require pullups (used 20K). I could only get it to run about 1 out of 20 tries without them.
    (The older fsrw_speed.spin (4_1_2009) work every time without the pullups.)
    Jim
    Post Edited (hover1) : 7/19/2009 4:17:12 PM GMT
    edited 2009-07-19 16:22
    Jonathan,
    That's what I'm seeing... Somehow something needs initializing by the old code before the new one will work...
    Guess I didn't notice before because the app in EEPROM starts the old fsrw...
    Tried you file, but still hangs on trying to mount...
    edited 2009-07-19 16:30
    It's hanging on this line in Mount_Explicit:
    tmp := send_cmd_slow( CMD0, 0, $95 )
    edited 2009-07-19 16:40
    I've traced it to here:
    PRI busy_slow : r
      ' send out a multiple of 8 clocks
      read_32_slow
      text.str(string("j"))
      ' then check
      repeat while r <> $FF
        r := read_slow
        text.str(string("k"))
        if( (cnt - SPI_block_index) > (clkfreq << 2) )
          text.str(string("l"))
          crash( ERR_CARD_BUSY_TIMEOUT )
    Added some text output to trace the problem...· I see a lot of k's flying by and then one l...
    edited 2009-07-19 17:50
    I can get to work by skipping the busy check like this:
    PRI busy_slow : r
      read_32_slow
      ' then check
      return  <------------------  It works if we don't really check...
    edited 2009-07-19 20:13
    hover1 said...
    Jim
    Thanks, Jim. I am currently tristating the pins between when the Spin code does the initialization, and when it hands those pins off to assembly engine for data transfer. I will work out a more robust handshake which does not require the tristating in the interim.
    thanks,
    Jonathan
    lonesock
    edited 2009-07-19 20:24
    Rayman said...
    PRI busy_slow : r
      read_32_slow
      ' then check
    Ouch! If the card is ready to accept a command it should be outputting all 1's.Can you do me a favor? Change the "busy_slow" routine to look like this:
    PRI busy_slow : r
      text.dec( read_32_slow )
      ' then check
        r := read_slow
        text.dec( r )
        text.str(string(","))
          text.str(string("T"))
    That should log all the values that come back (though there may be a billion of them in 4 seconds). Hopefully whatever is coming back from the card will give me a clue as to what state the card is in. If the log is huge, could you zip it up and email it to my gmail account (same username as on this board)?
    Is the timeout occurring the very first time the CMD0 is issued? If the app is aborting, the test output log should have a list of Commands and Responses, that would be helpful to browse. If the first CMD0 is causing the hang, then there will be no Command => Response log.
    thanks,
    Jonathan
    lonesock
    edited 2009-07-19 21:42
    Hmm...· That's probably my issue too!· I don't have any pull-ups...
    lonesock said...
    hover1 said...
    Jim
    thanks,
    Jonathan
    edited 2009-07-19 21:51
    Tried that code and it filled the screen with zeros...
    Sorry, I don't have an easy way to do a log file (without the SD card [noparse]:)[/noparse]
    thanks,
    Jonathan
    edited 2009-07-20 06:26
    Hi, All.
    OK, here's the update: Attached to this post I'm including a new version of mb_spi.spin, which I'm asking anyone who can to try out. Here's what's different.
    -- There are extra debug checks (long aligned raw block access, etc.), so this version will be slower (maybe about 10% slower)
    -- I worked over the handing of the reins (pins) from the Spin init sequence to the PASM block driver, no tristating, so hopefully it works without pullup resistors now (thanks for the heads-up, Jim!)
    -- I modified the send command structure for Rayman, hopefully it works now
    -- I modified the "stop" behavior of the block layer to specifically exit the current multiblock mode. Some cards simply refuse to be re-initialized if the card's state was interrupted during a read or write in multiblock mode. Of the 7 cards I have available for testing, 6 will re-init using the current sequence, but one will not. Adding in this exit code is probably just common courtesy for the card [noparse][[/noparse]8^). (btw, I could not find any documentation on re-initializing a card left in multiblock mode. The recommended procedure in both the SD and MMC specs just don't work, hence the current init sequence which attempts in special cases to stop read and write modes). Anyway, now if you call mb_spi's stop routine, or fsrw's unmount routine, the block layer will leave the card in a nice pristine state.
    Thanks for your patience, everyone. If this test version works on everybody's setup, then I'll start stripping out the extraneous debug info and bring the speed back up.
    Jonathan
    lonesock
    edited 2009-07-20 10:08
    Works! Thanks...
    edited 2009-07-20 11:06
    Rayman said...
    Works! Thanks...
    Awesome! You're welcome.
    lonesock
    edited 2009-07-20 15:48
    Test results with latest mb_spi.spin and NO PULLUPS
    • PNY 2 GB MicroSD - Propeller Proto Board - 80 Mhz - NO PULLUPS
    • Waiting for key press to start tests
    • Clock: 80000000 ClusterSize: 32768 ClusterCount: 62293
    • Raw write 3968 kB in 3338 ms at 1188 kB/s
    • Raw read 1920 kB in 2115 ms at 907 kB/s
    • fsrw pwrite 2016 kB in 3282 ms at 614 kB/s
    • fsrw pread 2016 kB in 3314 ms at 608 kB/s
    • FSRW pputc 63 kB in 2137 ms at 29 kB/s
    • FSRW pgetc 63 kB in 1893 ms at 33 kB/s
    • All done!
    • Kodak #1 - 2 GB MicroSD - Propeller Proto Board - 80 Mhz - NO PULLUPS
    • Clock: 80000000 ClusterSize: 32768 ClusterCount: 62294
    • Raw write 3968 kB in 3393 ms at 1169 kB/s
    • fsrw pwrite 2016 kB in 3444 ms at 585 kB/s
    • fsrw pread 2016 kB in 3308 ms at 609 kB/s
    • FSRW pputc 63 kB in 2278 ms at 27 kB/s
    • FSRW pgetc 63 kB in 1891 ms at 33 kB/s
    • All done!
    • Kodak #2 - 2 GB MicroSD - Propeller Proto Board - 80 Mhz - NO PULLUPS
    • Raw write 3968 kB in 3343 ms at 1187 kB/s
    • fsrw pwrite 2016 kB in 3291 ms at 612 kB/s
    • fsrw pread 2016 kB in 3311 ms at 608 kB/s
    • FSRW pputc 63 kB in 2136 ms at 29 kB/s
    All done!
    Nice work Jonathan!
    Haven't got a chance to do 100 Mhz tests yet.
    Jim
    lonesock said...
    Hi, All.
    Jonathan
    edited 2009-07-20 17:19
    Test Results - Proto Board - 100Mhz - NO PULLUPS· (My first 100 MHz Program!!)
    PNY 2 GB MicroSD
    Clock: 100000000 ClusterSize: 32768 ClusterCount: 62293
    Raw write 3968 kB in 2855 ms at 1389 kB/s
    Raw read 3968 kB in 3493 ms at 1135 kB/s
    fsrw pwrite 2016 kB in 2710 ms at 743 kB/s
    fsrw pread 2016 kB in 2649 ms at 760 kB/s
    FSRW pputc 127 kB in 3435 ms at 36 kB/s
    FSRW pgetc 127 kB in 3054 ms at 41 kB/s
    All done!
    Kodak 2GB MicroSD #1
    Clock: 100000000 ClusterSize: 32768 ClusterCount: 62294
    Raw write 3968 kB in 2915 ms at 1361 kB/s
    Raw read 3968 kB in 3494 ms at 1135 kB/s
    fsrw pwrite 2016 kB in 2695 ms at 747 kB/s
    fsrw pread 2016 kB in 2647 ms at 761 kB/s
    FSRW pputc 127 kB in 3578 ms at 35 kB/s
    FSRW pgetc 127 kB in 3049 ms at 41 kB/s
    Kodak 2GB MicroSD #2
    Raw write 3968 kB in 2866 ms at 1384 kB/s
    fsrw pwrite 2016 kB in 2597 ms at 776 kB/s
    fsrw pread 2016 kB in 2653 ms at 760 kB/s
    FSRW pputc 127 kB in 3438 ms at 36 kB/s
    Flawless @ 100 MhZ!!!· YipEEE
    Jim
    lonesock said...
    Hi, All.
    Jonathan
    edited 2009-07-20 17:24
    hover1 said...
    Flawless @ 100 MhZ!!! YipEEE
    Jim
    Awesome! Thanks for testing at 80 & 100MHz! I'm really glad it's working for you, even without pull-up resistors.
    Jonathan
    lonesock
