POLL: Propeller I/O options
Oldbitcollector (Jeff)
POLL: (There are a couple of us interested in this statistic)
QUESTION 1:
What type of video connection do you use most often with the Propeller?
VGA
Composite (TV)
LCD display (not counting those supporting TV-in)
Other (specify)
QUESTION 2:
Do you use a mouse with your propeller setup?
OBC
New to the Propeller?
Post Edited (Oldbitcollector) : 6/17/2009 1:56:56 PM GMT
QUESTION 1:
VGA
Composite (TV)
Other (specify)
QUESTION 2:
POLL RESULTS AS OF: 6/17/09 VGA :********** COMPOSITE TV :***************** LCD :****** OTHER :************* MOUSE :****
OBC
Eccles : How do I open the door?
Bluebottle : You turn the knob on your side
Eccles : I haven't got a knob on my side!
VGA - it's hooked up almost all the time
TV - with a wire stuck out the RCA jack --- it'll transmit > 3 feet to the rabbit ears [noparse]:)[/noparse]
Other (OK USB does count, I guess)
LCD
2. yes, about 50% of the time
Got Electrons?
Q2: No
Searider
Q2: No
QUESTION 2: Haven't really found a use for it yet, but do use a keyboard from time to time (Femto Basic)
Jim
As to the mouse I must admit that I have not used it other than for demos but I keep my options open there too. Besides, the standard PS/2 connector can have either mouse or keyboard plugged in and I had an older laptop that had a single PS/2 connector and if you wanted to use both an external keyboard and external mouse then they had a splitter that you could use. Normally there are two unused pins on the PS/2 connector and it quite common for these to be a secondary PS/2 port en.wikipedia.org/wiki/PS/2_connector . Personally I just use the other two pins for the I2C bus so that I can at a pinch plug in external I/O onto the PS/2 which BTW could just as easily use the PS/2 CLK & DAT.
*Peter*
Q2: Rarely use mouse.
I use a PC for things I might need a VGA/Mouse for on Propeller. One of my goals for end of June was to have a VGA/Mouse textured GUI demo though. Guess this response kind of shows how far I am with that [noparse]:)[/noparse]
--Steve
Propalyzer: Propeller PC Logic Analyzer
http://forums.parallax.com/showthread.php?p=788230
Q2: Never
John Abshier
Haven't used a mouse yet.
Rich H
▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔ D Rat
Dave Ratcliff· N6YEE
A2: First time was this past week.
LCD rarely
7-Seg display digits, sometimes.
TV never
Mouse never
never on mouse
······· "What do you mean, it doesn't have any tubes?"
······· "No such thing as a dumb question" unless it's on the internet
2. Yes
2. Mouse only occasionally.
To question 2: I use a mouse because it gives me the ability to drill through menus on the VGA and to display data and to change the values of variables on the fly.
Thanks so much for caring.
2. Not yet.
If only the forum poll function were enabled...
2) Mouse and Keyboard
* addtl. feature for 2x20 and 4x20 LCDs
* extra ports available
PC via USB 98% (PropPlug equiv with PropTerminal, PST, PropTool)
VGA 2% (used for testing)
TV 0% (but tested it works)
LCD 0% (never)
Q2. Mouse
no, never tested
Keyboard 2% (used for testing)
However, with more time I expect to use VGA and Keyboard for standalone operation (PropDOS, CPM & ZiCog, Flex or OMU & MoCog, and maybe Apple //e)
· Home of the MultiBladeProps: TriBladeProp, SixBladeProp, website (Multiple propeller pcbs)
· Emulators: Micros eg Altair, and Terminals eg VT100 (Index)
2. mouse yes but rarely
Sometimes LCD 2x16 or 4x20
Mouse, not so far.
Q2: no - but I recently found this little cutie http://www.csd-electronics.de/data/pdf/MiniTrackball.pdf
····· PS: Do mouse wheels count? I plan to rip off two mouse wheels from old mice and connect directly to the prop. Gives me a nice x/y input device (menu navigation).
Post Edited (MagIO2) : 6/16/2009 9:50:11 AM GMT
I too have considered trying to replace the VGA connector with something smaller. I wanted something that could be purchased (cable) rather than having to make it. I have not had any luck. While I like the RJ45, I think it is more likely in future we are going to see ethernet on the pcbs and this will confuse people. However, I would like something that we could standardise on.
Using the RJ45: cables can be bought readily. The RJ45 to DB9 unpinned socket can be bought fairly easily. The VGA DB15 is the same size (and if readily available - I haven't checked) could be substituted. The only issue is the multiple ground pins - are they all required??
The new TwinBlade (when I finish it :-( ) will have...
One PS2 socket with both Keyboard and Mouse on it. If you just want one, then plug it in. Otherwise buy a splitter cable on eBay cheaply.
The TV will use the 4 way 3.5mm audio/video socket (from DigiKey - the smt version is nicer and easy to solder onto a designed pcb). There are various pinouts for this. I have chosen the Apple iPod/iPhone format (defined on the wiki). It contains composite video and stereo out. A splitter cable to RCA (red, white and yellow) can be obtained cheaply on eBay.
Q2: Can you connect a mouse to the propeller ?
Visit the home of pPropQL: propeller.wikispaces.com/pPropQL
pPropQL020: propeller.wikispaces.com/pPropQL
OMU for the pPropQL/020 propeller.wikispaces.com/OMU
Q2: never
Q2: No
Nyamekye,
Mouse, on occasion.
Keyboard, frequently.
I've ran VGA twice. Once to see the demo Linus wrote, and the other time to run his pre-demo work. I've ignored it otherwise.
For me, the problem is portability. VGA doesn't travel well.
Chat in real time with other Propellerheads on IRC #propeller @ freenode.net
never used mouse or keyboard.
Q2 - Yes
'Necessity is the mother of invention'
Those who can, do.Those who can’t, teach.
