Caster Wheel for Boe Bot
william chan
Hi,
The ball wheel that comes with the Boe Bot seems to slide when then robot is turning.
This limits the payload of the robot.
Is there a easy way to change it to a caster wheel?
www.fd.com.my
www.mercedes.com.my
www.fd.com.my
www.mercedes.com.my
www.fd.com.my
www.mercedes.com.my
The ball does not provide enough friction on almost any surface to keep the robot straight if the servos are not calibrated. In fact, the ball is so slippery on most surfaces that I cannot think of any way it would cause enough friction to be a problem unless the robot was over weight as mentioned above. The amount of payload it would take to cause such a problem would also be an issue for the servos themselves.
Chris Savage
Parallax Engineering
We all weighed in on this a while back - See this thread - http://forums.parallax.com/showthread.php?p=753679
If you really want something else - check the ball caters at Pololu - http://www.pololu.com/catalog/product/66
I stand by the proven sucess of the the original BoeBot design...
Whit+
Post Edited (Whit) : 4/30/2009 3:44:38 PM GMT
This ones from Kornylak Corporation Wheel Division.
www.omniwheel.com
Or, maybe find something smaller.
They're 2 inches in diameter though but still a possible option.
Post Edited (NinjaTech) : 5/2/2009 9:58:11 AM GMT
